Everything posted by mtaylor
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
It's great to hear everyone there is doing well, Nenad, including Rhea. Looking great on the plug. As Carl said: "You can start your production line."- 4,152 replies
- cutty sark
- tehnodidakta
Just an update, nothing to report. Very slow going removing the forest from the hull as I don't want to break anything or pop off any planks. Still fiddling with the Deathstar but I think that problem is nearing the end. And life just keeps getting in the way, lately. Thanks for the likes, the comments, and the interest in this build.
Cathead, Check your local library for an interlibrary loan. When I lived in a small town in Missouri, the local library (and all the ones arouind us) were able to use it.
The only thing I know that's out there for Granado is the Anatomy of a Ship book. It's basically just plans.
Hello From David - A new member
mtaylor replied to David of Berwick's topic in New member Introductions
Hi David, -
Hi Jed, Welcome to MSW. Go with Anja's advice about the model. The manufacturer... that's horse of a different color. There's been a lot of discussion on intructions, etc. here: http://modelshipworld.com/index.php/forum/24-wood-ship-model-kits/
Nice metal work, Jack. Just tell anyone who asks, that the welder was an apprentice. Seriously... looks very good from here.
- 250 replies
- willie l bennett
- model shipways
It's great to hear from you again, Remco. I think we were all beginning to get worried. As for "cheating"... no such animal in my book as the results are important. Laminating isn't cheating, IMO.
- 1,215 replies
- sloop
- kingfisher
Lovely work, Vince. That breast rail is perfect.
- 593 replies
- royal william
- euromodels
It's sad, Lextin. But at least it will be protected while you're out having an adventure.
- 366 replies
A Lorch Micro-Mill that never was ...
mtaylor replied to wefalck's topic in Modeling tools and Workshop Equipment
Pure engineering artistry, Wefalck. -
Here's links to the build logs I found... http://modelshipworld.com/index.php/topic/11080-hms-endeavor-by-hof00-artesania-latina-whitby-cat/ http://modelshipworld.com/index.php/topic/2917-hmb-endeavour-1768-by-olopa67-artesania/ http://modelshipworld.com/index.php/topic/92-hmb-endeavour-by-greg-lester-finished-artesania-latina/ http://modelshipworld.com/index.php/topic/2773-hmb-endeavour-by-bankie-al-160-circa-1768/ I hope this helps....
No problem... Here in the States, this is a hidden movie. I was looking for it and there really wasn't much out there. I don't do Netflix, so I'm even more in the dark.
Need advice - what should I build after the AVS?
mtaylor replied to pdx_matthew's topic in Wood ship model kits
Personally... I'd go with the Triton or Echo Cross-Section to get a feel for full-framed builds. Echo is a bit more complex than the Triton so that's a toss up. -
We've had at least 4 topics on this.... Do a search from the main page using "Ruyter" (without quotes) as the keyword. It's true.. not much if any press in the US on it.
Kurt, I'm still sorting things out myself. I've found that if I can use it in my scroll saw, it'll work in the jewelers and fret frames.
By best, what do you mean, Kurt? Blade selection is based on teeth per inch and ensuring at least 3 teeth on cut at all times. I tend to use Sawbird's blades or Olson's... depending. Side note: Some blades for the scroll saw are reversed tooth at the bottom of the blade to reduce the chances of tear out.
If you are planning the gundeck, I would think that's what the holes are for.. might be wrong. I did the gundeck on my Constellation and it required a lot of rework of the kit to accomplish. I'm not sure how much rework you'd need to do but it can be done if you want it bad enough.
- 742 replies
- constitution
- frigate
Ah.... I see. That probably explains the Wiki list then. If I were a betting man, the 2 100-pounders were probably pivot guns as was the 60 pounder. They did mix things up abit at times on the main gundeck so it's possible the 8" and 9" were in the ports. So after the refit? <shrugs> I'm not sure where to go for info... A quick Google goes no where fast on this... I wish I could be more help but I'm not sure where else there might be info.
