mtaylor
Moderators
Everything posted by mtaylor
  1. Denis, I'm not worried about the cracked frame as it will be cut down the planking level. Thanks for keeping an eye on things.
  2. Look at the other build logs then would be my advise. I hope you can get an answer. You might also ask this in the Building, Framing area.
  3. The Netsuke PDF is excellent, as is Bill Short's CD. I've also referenced the Lumberyard's carving guide also as it has a lot of the basics.
  4. I think you're right on the dimension. As I recall, most of us just matched the drawings for dimensions.
  5. Hi Bob... from a former Buckeye.
  6. There's a series of DVD's (or maybe it's CD) by Dr. Micheal, Russian Master on a lot of their techniques. I don't know if he goes into finishes though as I've not seen the videos.
  7. Bill, The Russians do a lot of that using bitumen or a compound there of. I've heard of it and seen the results but haven't a clue how it's done. However, the results are incredible.
  8. I'm in for the learning and the wisdom. There's many here who are masters but finding the knowledge in one area is tough. Then there's the pucker factor... FEAR. One needs to get one's feet wet sometime... so.. diving in.
  9. Rob, A good reference source for all things tall ship is zu Mondfeld's "Historical Ship Models". Much is explained by pictures and text including rigging. It may not be accurate for specifics but it is an excellent reference (and reasonably priced) to have around.
  10. I really don't have any comments. I hit "like" because I like what I'm seeing. You're doing some interesting models and some innovative techniques. Keep up the good work.
  11. Congratulations on a major milestone, Dave. A mind-numbing one at times, but a major one.
  12. Thanks for the comments and "likes". I have the mast partners cut out and the wood ripped to size for the carlings. Now start fitting them. As side note, i'm only doing the carlings along the center for the hatches and to provide a landing place for the partners. These are supposition based on cross-section and the way the French did their hatchways.
  13. Looking good, Alan. Yeah, it's harder than it looks but the satisfaction when things start coming together makes it worthwhile. Right?
  14. Les, Soak them in acetone. Depending on how long the CA has cured and how much, it may take awhile.
  15. Steve, That's lovely bit of work for the spotlight. The control is very realistic.
  16. It's great seeing you back and building. I hope all is well.
  17. Patrick, I used a ball mill and the mill with my fixture for doing profiles. I think I posted this once before but here it is again. Hi Vivian, Thanks for the comment and it's great to see you back. I hope you can get back to your models.
  18. Minor update to show that all is not folly and folderol... The waterways are completely in and the beams marked with the centerline, the carling locations for hatches and mast partners, and also for the line where the center thick stuff will end and the normal deck planking begins. (See the first photo). I also ran a test using cutoffs from the beams, I made a "fixture" for lack of a better word. I cut some 1/8" cherry and tacked it to the beams to see if there's any issues using the laser to cut the planking. Nope... even leaves a nice black line for the caulking (see the last two photos) and with care, I should have some better planking than if I tried to sand/plane in the taper, etc. . Also there's a bit of waterway to show the profile. Tomorrow (or however long it takes) will be devoted to cutting and fitting the carlings.
  19. So I'm taking it that it was either shipyard preference or whatever the rigger felt like that week? I think you have and had your work cut out for you, Chuck.
  20. Well done on the portholes. They look like they're supposed to be that way.
  21. Fascinating build, Greg. I didn't realize that the Yamato had a hanger deck.. almost an aircraft carrier in addition to being a battleship.
  22. I had to go back a few pages to see what you meant. Oh... blue air time in my neck of the woods. But it's a great recovery you're making and the stack looks great. To steal David's line and add to it.. a Master Brasssmith your are.
