mtaylor
Moderators
Everything posted by mtaylor
  1. I'm with the others... not a "fun" injury due to location and nerve endings (not that injuries are fun but this has to be the most painful and the hardest to heal in my experience). Follow the doc's advice to the letter please.
  2. No rush, no pressure, Denis. I think we all understand the "chain reaction syndrome"...
  3. Congratulations, Jerry. She appears to be a fine sailor and very majestic. You ought to be popping buttons off your shirt with pride.
  4. Gaetan, Are you using direct light, diffused, or reflected light for the lighting the ship itself? From my 35mm photography days, reflected light off a white board minimized reflections. Diffused can also do it depending...
  5. Beautiful finish with the glass work, Grant. And you're planning on varnishing after the glass work? Side note, I've used plastic trash bags like the peel and ply but only for the final coat unless it's multilayer glass or carbon fiber. But I was also vacuum bagging as Sam mentioned. It gives a smooth, shiny surface unless you get a wrinkle in the bag. And no... I wouldn't think of vacuum bagging a wooden ship.
  6. Sam, I'm running at what I consider a medium low speed of 10mm/sec and power is at 9 mA which is about medium. Max speed is around 300mm for engraving so there's speed available, but the vibration at anything over 20mm/sec isn't worth the hassle as it introduces distortion on the corners and curves. For the power, the tube (45W) is rated at 23 mA but I limit that to 80% of that (18 mA) to improve tube life. Things go differently for different thicknesses of wood and also type of wood. The other thing is to watch the temperature of the cooling water... the colder it is (to a max low of 65 degrees F) the more efficient the tube is and thus needs less power. I'm not watching that close right now as these are short cuts (in time) and so my max temp is just above ambient in the house. You certainly don't want to run these things if the cooling water gets above 80 degrees F as that will burn out the tube. Probably more info than anyone wants to know....
  7. Very well done, my friend. I'm glad it worked for you.
  8. It's great to hear from you. What tech school are you in and what specialty are getting trained in?
  9. Impressive work, Mike. Looking from here, if you hadn't said anything, we would know it broke.
  10. I don't like that your back went out, Alan. I like that you have healed enough to respond. I'm just watching quietly and enjoying your build.
  11. Sheer genius on the pin and the mill. This is going into my bag of tricks.
  12. This is beyond amazing, Igor. So much detail on such a tiny ship. Marvelous.
  13. You have been busy. She looks good, Tom.
  14. Today's progress and the adventure continues..... much head scratching, much smoke blowing out the window... fed the scrapbox as I sorted out my approach but success I do believe. Rather than trying to attack the whole deck (center area) at once, I decided to break it into logical sections. So.. aft section first as that's my anchor point for measurements. I spent the better part of last couple of days setting up the drawings for this with the deck plan as a basis and adding reference points and checking and re-checking measurements. I finally produced a drawing showing what I thought I needed, printed it out, cut out the section and.. rats... off... Recheck measurements, reworked the drawing and repeated the test. Got it. Or so I thought. I cut a piece of thin basswood and the fit was pretty good. I then cut a piece of pear with etched in planking lines thinking... "one piece.. it should look good.". It does look good (first picture). However, not quite as good a fit as I'd like. I mis-calculated the kerf of the Deathstar. Different woods and different thicknesses affect the kerf. It's not a constant but a variable as thicker wood needs more power which gives a bit of a wider kerf... a "Doh!" moment. Back to the drawing board. I ran some cutting tests (3 altogether for consistancy) using pear of the appropriate thickness to check the kerf and then ran those numbers into the calculator WITHOUT rounding them and got the correct kerf. While I had the drawing in the rework process, I decided instead of one piece and trying to get it to conform to the curve of the deck beams, I choose to cut individual planks. Re-checked 3 or 4 times my calculations and it worked... (See pic 2). A light sanding to remove the ash but leave some of the char gives a nice fine line for the caulking. It's been glued down into position and still needs some more light sanding to remove a bit of smoke stain and also to smooth out decking's surface. Hopefully, tomorrow's efforts on the aft midsection (the next section forward) will yield good results. I think it'll go a bit faster once I get into the rhythm of things. It may seem like more trouble, but with the tapered planks on the deck I think this can produce a more uniform planking than trying to mark up the beams with the tapered widths and match them.
  15. Good grief that beast is huge... If you'd made it from metal it probably could haul cargo overseas. Or maybe use it as a rowboat? Seriously nice and complex work, Kevin.
  16. I have different heights depending the work station.. My main build table though means I have to stand as top of the build board is approximately 1 foot above the work surface yet it matches the other work areas. Top surfaces of all the work areas (including my build board) are 36". I do have a wooden "bar" stool that allows me to sit if I don't feel like standing.
  17. Lately it doesn't seem to work no matter how many times I measure and cut. The part is still too short.
  18. I think you made the right choice, Hamilton. Yes, plans can give you misleading info. As Grant said, find the 90% or better stuff. If it's not in the hardware store, look in the medical supply departments of some of the big box stores and/or pharmacies. Down here, it's usually either at Wal-Mart or Target and just about every pharmacy.
  19. Congratulations on another masterpiece, Bob. I too, am marveling at the details at such a small scale.
  20. Try a rotary brush on a Dremel??? I remember (again.. senior moment) someone doing that and it cleaned things up. But you will have to have a light touch.
  21. Patrick, The 1/8th inch is real measurement and not scale. At scale the difference is about 4".
