Everything posted by mtaylor
Beautiful work, Mobbsie. You're right about the redheart. I also splinters if you look at the wrong way but you seemed to have tamed that beast.
- 255 replies
- granado
- bomb ketch
That is a sweet little cutter, Ray. It looks great.
- 536 replies
- diana
- caldercraft
KP, As that in the Model Kit Questions area: http://modelshipworld.com/index.php/forum/26-plastic-model-kits-plastic-scratchquestions-and-reviews/ You might get more answers. I've only built 2 Hellers, one eons ago and then tried a Vic about 14 years ago. I wasn't missing parts but some of the parts were badly malformed.
- 119 replies
- la reale de france
- heller
Rookie needs help!
mtaylor replied to twebb's topic in CAD and 3D Modelling/Drafting Plans with Software
That's good to hear, Ted. I hope it goes well and you have fun. -
Since interest has been shown in this tool by many including myself, here goes a hopefully, full review. I will preface this by saying that this tool is NOT for everyone. To make it clear: if you are expecting out-of-box performance from this, stop reading and go do something else. I fear this is going to be rather long winded.... Background My scroll saw skills leave a lot to be desired and for repetitive items like knees, beams and even cutting small pieces for carving is an issue. So rather than stand in front of a scroll saw for hours and end up tossing 30-50% of the pieces into the scrap box, I thought about a laser cutter. The so-called “hobby lasers” seem appealing. Reasonably low power requirements, low costs, and relatively smaller size appeals to me. Research The caveats that I read about Laser Cutters and followed in the research are: Use a company in the country you are in or will provide support to you. Use a company that has been in business for more than a couple of years. I’ve looked at the imported China Lasers (~$500 US) but have found much wrong with them in the reviews. Extra costs of dealing with an import agent to get the unit out of customs and shipped to you, generally mediocre quality in the assembly, and then there’s the normal software that comes with the these products. Also dealing with a seller in China leaves you high and dry without support. I discovered two being “used” here locally. One is not working and hasn’t from the time he got it a few months ago. He’s in the process of replacing the PC board to be compatible with better software and fixing some damaged items like a broken laser tube. The other, I saw it work, and tried my hand but the software (MoshiDraw) is incredibly bad. The owner was running it on an XP PC as it wouldn’t run consistently in Win7 even in compatibility mode. I looked at another higher priced unit (~$4000 US base price with accessories adding up rapidly). The unit was high quality, made in the US with some Chinese parts including the main board. It used LaserDraw software and from what I saw, the performance was adequate. But as I was unable to sit down and try the woods we use, I can’t give a full report on it. The owners use basswood and thin veneers for creating dollhouses, model railway buildings, etc. The output seemed of good quality but again, it was not the woods or sizes we use. My observation is that this is basically a hobby machine upgraded to being a production type. The one I’m testing is the Micro-Mark brand (~$2000 US). It comes with a 30 day refund guarantee which, if I determine this isn’t what will work for me, I’ll return it. I read their claims that this machine is built to their specifications (http://www.micromark.com/html_pages/misc/the-micro-mark-difference.pdf) . I know that some of us (myself included) have issues with certain practices which I won’t go into. I will say that I won’t buy ripped off equipment. This unit doesn’t appear ripped off but an upgraded Chinese unit. I did not consider anything more powerful than 40W. Maybe I should have, but there's also a cost factor that goes with that. Pre-Order The unit uses CorelLaser as its cutting software using an industry standard HP Plotter Driver and also Corel Draw. I downloaded the manual and documentation from MM. I also ordered a copy of CorelDraw X6 from Amazon. CorelLaser works only with CorelDraw above version 13 so I bought a shrink wrapped, new-in-the-box program for $150 US. I would suggest you do your homework on this. X7, the latest from Corel is a subscription based program. In other words, you pay every month for it. I prefer to have a CD in my drawer just in case…. I spent a week or so refreshing myself on CorelDraw as the last time I used it was Version 5… yeah… been a few years. Unpacking and Set-Up I received this is 3 boxes, well packed in foam. Unpacking is pretty straight forward. I would suggest that the air pump and water pump NOT be removed from their bubble wrap as there is nothing on these items to indicate what they are. I wish that MM had put a photo or two in the instruction manual to identify parts. One thing that is needed is a GFI socket. I’m using a GFI adapter in case I wish at some future date, to move the cutter to a different place. Set-up is pretty straight forward following the manual. The hardest part was figuring out the exhaust setup without cutting a hole in the wall of the house. Also, do NOT secure the exhaust unit to the cutter with tape. Use #10 X 3/4” self-tapping screws. There’s bit a misfit between these parts and the tape will not hold it securely in place. Here's photos of the unit and all the accessories... Testing Started I used the factory settings and followed the instructions in the manual for the recommended passes and power. Not a happy camper using boxwood. The little nameplate is 1/8” thick boxwood. Took 9 passes to cut. Lots of charring. I discovered the mirrors were off. MM instructions are vague in the extreme and need some serious re-writing to be useful. I Googled and eventually found the information I needed here: http://dck40.blogspot.com/ Using other web sources, I discovered that the lens in the cutting head was upside down… WTF!!!! This really irritated me. After spending a day going back and forth between all three mirrors and adjusting them, and then resetting the focus for the wood, here’s the next round. I’m continuing to test and massage things. This will take time. I’m able to cut 3/16” boxwwod which requires multiple passes but as yet, not I’ve not tried ¼” boxwood. Overall Observations. The learning curve on this machine is a vertical, straight line. These machines are still in their infancy and not mature. Documentation is extremely sparse although there are forums out there for laser cutters, getting to the information you need for a particular type or model is a bit overwhelming and I consider myself a knowledgeable Googler. There is no guidance on power settings or cutting speed to cut various types and thicknesses of wood. Serious experimentation is required. This machine is finicky in that all mirrors have to be perfectly adjusted to make use of the power and they have to be kept clean. It is big, and sometimes smelly. It’s not a production machine and the bucket of cooling water will have to be watched. Running at “high” power (no definition from anyone on this or on the max water temperature) will shorten the life of the laser bulb. There is a focus issue and I believe it could cut with a thinner kerf. I’m trying to talk with MM about this…. The nameplate, I couldn’t even begin to cut something that tiny on the scroll saw. It’s now almost ready for carving. I do need to tweak the drawing some more to get a bit better spacing. The anchor stocks I’ve done, would have taken maybe 30 minutes on the scroll saw. Including drawing time, this took approximately 1 hour and no wasted/ruined pieces. However, all 4 are exactly alike and the bolt holes are ready to be cleaned of char and the bolts installed. No fiddling with the drill press, either. I have about 8 other parts ready for cutting and will do them as I go. The kerf size and charring are still an issue. I’ll say it again, it’s not for everyone. If you have the time and ability to Google and research and then to fiddle with it and get it running correctly and then to keep it running, it might be ok for you. The manuals are skimpy at best and a bit of creative Googling will need to be done to help sort things out. There’s still settings in CorelLaser that I have no idea what they do. There is an alternative to CorelLaser called LaserCut 5.3. I haven’t tried it yet and the documentation on-line seems rather sparse from what I’ve seen. Thicknesses of 3/16” and up are tricky to work with. There’s no tables or inputs from MM on this and the web is all over the place on using these “hobby” cutters. However, most folks who have reviewed similar machines are using basswood and thin woods. Doll houses and RR accessories seem to be the major uses along with etching for various things like signs, pendants, etc. I need to have a conversation with MM on the lens… I think it needs to be higher quality and damn it... there’s no excuse to have it installed upside down. Lastly, tech support. I emailed them late on a Sunday night about some issues. I'm still waiting for answer after 3 days… Since we’re talking tech support, it’s worthwhile to note that tech support hours are very limited… Monday through Friday, from 1:00 pm to 5:00 pm, EDT. I asked tech support before I ordered about using an extender cable and the answer was a simple: not recommended. The unit comes with a 9 foot USB cable so I had to seriously rearrange my workshop to get it closer to the computer. I’m testing a USB powered extender cable so I don’t have cabling running across the floor where it can be stepped on. Jury is out on this. The short answer for all this is: I wouldn’t recommend it unless you are tech savvy, not just with computers but also can tolerate a large learning curve. The quality of the cuts could be a lot better. Overall, it might better that if this tool is something you have to have then spend about double the cash and get a higher powered, non-China built laser cutter with some tech support. The BossLaser that Chuck uses runs about $5000 and has the higher power to cut thicker woods and is, I believe, also suitable as a production machine. I'll continue to test, adjust, fiddle, and tweak for now...
HMS Alert 1777 by Jaekon Lee - 1/64
mtaylor replied to Jaekon Lee's topic in - Build logs for subjects built 1751 - 1800
All I can say is: "Wow". Lovely work, Lee. -
Rookie needs help!
Ted, If you just want something to practice with, have a look at this article: http://modelshipworldforum.com/resources/plans_and_research/InterpretingLineDrawings.pdf Russ explains the meaning of the lines and there's a simple set of plans. -
Feel free to let me know, Jay. We're not traveling much these days due to the Admiral's health but we're both hoping that will change.
- 732 replies
- constitution
- model shipways
Yep... "Splice the Mainbrace" = "drinks all around" http://en.wikipedia.org/wiki/Splice_the_mainbrace
- 732 replies
- constitution
- model shipways
Either you splice the mainbrace or we'll do it for you and not save you any... :D She looks super nice Jay.
- 732 replies
- constitution
- model shipways
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
I'm beyond sad at this news, Nenad. I've been searching for words and there are none. Give Hothead and Princess large hugs and the three of you remember the good times.- 4,152 replies
- cutty sark
- tehnodidakta
Nope.. didn't think that at all... we're a patient lot for the most part.
- 97 replies
- macedonian
- frigate
Rivets, Augie? I'm waiting to see if Popeye will put glass in the portholes and maybe make some open... I wouldn't expect working portholes... or should I? Wonderful work, Popeye. That many portholes is like treenails... real dedication.
Missing parts Mamoli HMS Victory (moved by admin)
mtaylor replied to John Allen's topic in Wood ship model kits
JA, Are asking about the bands around the bowsprit? And possibly the masts? If so, consider just making them out of construction paper. -
I can't put a "like" on your post, Nenad... I'm very sad to hear about your mother. And the Admiral..????- 4,152 replies
- cutty sark
- tehnodidakta
