Everything posted by mtaylor
Walter, Try asking that here: http://modelshipworld.com/index.php/forum/34-cad-and-3d-modellingdrafting-plans-with-software/ There's also a lot of CAD discussion regarding lofting, etc. here: http://modelshipworld.com/index.php/forum/13-ships-plans-and-scratch-research-general-research-on-specific-vessels-and-ship-types/ in the Scantlings discussion. How's the Meridea coming along?
Lessons learned at this point on framing, fairing, and planking.... I guess I should say that it's not that I lacked the courage but more of the knowledge of deciphering the plans, supplementing them with the correct information and translating it all in my head to a course of action. And then I got side-tracked... anyway, after working through the side-track for the last 30 days, I'm re-focused and back on course. Solution.. try not to get side-tracked by new toys... think further ahead.. instead of 10 steps or 20 steps... look 100 steps. The problem stems from not fairing the aft frames as far as the Hahn frame drawing show and the lack of knowledge on my part in setting up the transom timbers. I guess I should have done a better documented ship first.... Same goes for the garboard strake.. I wasn't thinking that far ahead when I did the rabbet. I've been working through the problem and have a better result which should show when I put that strake in. Seems I didn't get the bevel quite where it should be in the aft section. Next update will be after I get everything re-faired and sorted out and the now four strakes of wide planks replaced... If you hear foul language from the west coast, ignore it.. it's just me sorting out things and venting to myself. But it will be fun.
What a great link, Clare.. it does 60 languages which is amazing.
- 106 replies
- Japanese boat
- Wasen
Impressive work as always Matt. I love the aging of the wood and all the bits and pieces going on.
George, you'd need an OCR program for that. It might just work... try translating something using Google into Japanese and then scan and see if it translates back.
- 106 replies
- Japanese boat
- Wasen
I like the way you fixed it, Dave. Looks super nice.
- 962 replies
- sovereign of the seas
- ship of the line
Great to see you back, Kevin. I've heard mojo is contagious. Given the summer doldrums have set in, I think we all can use some.
- 1,319 replies
- caldercraft
- Victory
Thanks for the birthday wishes. I'm going to avoid Version 3.0 at all costs. I'm comfortable with ripping things apart and putting them back together. As a footnote, I'll probably open a sub-log like Danny did for the ship's boats but not until the first one is nearly done. I want to try to use Chuck's method but at 1:64. There's three boats, the longboat, the cutter, and the barge. Keel's are 1/16" thick cherry, frames are 1/32" cherry, and the planking is 1/32" holly. I hope I can pull those off. It'll be a bit as I'm making the drawings (as well as for what I need for the main build) and testing on the laser cutter.
Good question.. maybe one for the research sub-forum. My first answer was: they pulled the gun out and used it as a hot tub!... but.. that's not the right answer is it.
- 456 replies
- finished
- bomb ketch
To quote Shakespeare's King Henry V: "Once more unto the breach, dear friends," Or maybe Daniel (Dafi): "Mass Destruction!!!! hihihihi!!!!" Bottom photo is the mod to be made... I need to arc more. Planks are stripped, power sander and sanding sticks at the ready...
Thanks for the wishes, my friends. Druxey, there is indeed a fairing issue. I've studying this and it looks like the low transom piece is the culprit. Giampiero pointed this out also. I've been scratching my head, double checking the plans. The only way to fix this is to rip off the last three (maybe four) strakes at that stern and re-fair. I was hoping to avoid that, but... what needs to be done, needs to be done.
Looks super, Grant. Like Mobbsie, I'm not a fan of redheart but you done well with it.
- 456 replies
- finished
- bomb ketch
Looking pretty darn good there, Popeye. I hope you don't make her sink.... Good admirals are tough to find. Keep yours happy..
Interesting project, Clare. I hope you don't mind if I follow along.
- 106 replies
- Japanese boat
- Wasen
Need help with rigging on the French Chebec Indiscreet.
mtaylor replied to DougM's topic in Masting, rigging and sails
Ah.... forget anything with English ships. Your's appears to be the French Le Requin. I should have checked.. and yes, you're right... possibly that's the way his instructions say to do it. What do your plans show? My reference (since I don't have the ANCRE monograph) is The Art of Ship Modeling by Frolich and even that doesn't really have much detail as to parrells, etc. It does show the massive halyard blocks at top of the masts. -
Hi Doug, Welcome to MSW. As Robin suggested... Google Chebec and also separately Xebec. Here on MSW, there's only one that got the point of the rigging being completed: http://modelshipworld.com/index.php/topic/5126-xebec-160-scale-scratch-build-by-mij/page-3 The pictures might help you out. -
- 572 replies
- constitution
- frigate
Brig Eagle by robnbill - 1:48
mtaylor replied to robnbill's topic in - Build logs for subjects built 1801 - 1850
Allen's paper is in the database also... under the Furniture section. http://modelshipworldforum.com/ship-modeling-articles-and-downloads.php I guess I should have mentioned it.... -
Dave, Here's a set from the database: http://modelshipworldforum.com/resources/furniture/stove.PDF
