Everything posted by mtaylor
48th Scale imperial rulers. Where?
mtaylor replied to John Murray's topic in Modeling tools and Workshop Equipment
Here's a PDF file of rulers in various scales and are not metric. I print, verify that it matches a standard ruler and then cut out the one I want and glue it to a slab of wood. After rechecking that there's deformation, I trim the now wooden ruler to size. ImperialScales.pdf -
MRAP ATV by CDW - FINISHED - Rye Field - 1:35 Scale
mtaylor replied to CDW's topic in Non-ship/categorised builds
Great to hear that the you two are safe. I hope we hear good news from others in the area. This one seems to one all time nasties from the reports. -
A guide to using MSW
mtaylor replied to James H's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
Clear all the browsers. Also, check the "history" on each one and remove MSW from there. Each browser is different so you'll need to "settings" on each one. Chrome does has "reset" which seems to do the same thing. -
Not an uncommon thing about the "potential" captains. Seems to still be going on with all navies with politics and "friendship" counting more than experience. This is most notable at the admiral's level. Same for other branches of military service.
- 17 replies
- Book
- great britain
Grumbling and facepalming are part of the process, Bruce. Looks like you're on the right path.
- 43 replies
- mediator
- first build
I have a suspicion that the gaff rigs were insurance such that if the engines failed, they could still have some steerage control by taking over fairly quickly. But then, the transition period between pure sail and pure power is something I know little of.
William Sutherland's concept of ship hull design, 1711
mtaylor replied to Waldemar's topic in Nautical/Naval History
Just curious if this was an actual build plan or a proposed design and used to get support for the project? -
Looking very good and the pictures make it seem a lot larger than it is. As "other things getting in the way"... that's life.
SOLEIL ROYAL 1669 by michel saunier
mtaylor replied to michel saunier's topic in - Build logs for subjects built 1501 - 1750
Well said and I'm in total agreement. -
Timber-framed outdoor kitchen - Cathead - 1:1 scale
mtaylor replied to Cathead's topic in Non-ship/categorised builds
Looks good. Have a great week of trips and relaxation. All of you working on this deserve it. -
Welcome back home, Brunel.
Have a look here: Basically the same as a kit to open a log. The only difference is area and some details in the title. Use Cathead's topic title as an example. For refreshers... there's pinned topics here: https://modelshipworld.com/forum/47-how-to-use-the-msw-forum-no-modeling-content /
- 113 replies
- Cairo
- BlueJacket Shipcrafters
I believe you are right about the anchor "sloop". Worked like what everyone else did for landing craft... drop the anchor on the run in and they use it winch of the beach.
- 200 replies
- Transport No. 103
- Hasegawa
(and 4 more)
https://www.usatoday.com/story/news/nation/2022/09/23/3-000-year-old-canoe-found-wisconsin/8090198001/
I'm in also. Interesting plan and I'm looking forward to following along.
- 200 replies
- Transport No. 103
- Hasegawa
(and 4 more)
I can see a lot of shaping of the hull as the stern area isn't rounded but made with a series of straight cuts. As for the "huh?" piece.... that is weird unless it's supposed to go on the bottom of the hull. But then cuts in the two pieces don't match. Send Mr. Bluejacket a PM to have a look here on your log and advise.
- 113 replies
- Cairo
No need for a mill to do gratings actually. Two ways... 1) buy some grating blanks. OR.... 2) use a small table saw and slot your own. There's ways shown here on MSW how to do this.
Considering that in England at least, the carpenters took the plans and then blew them up (measuring not photographically or any other modern way) and chalked the frames on the loft floor. As for the floors and everything else, it was again... take a stick, mark it up and use that to show where to point it. So... IMO, the designs will get you "as designed" and the real ones would get you "as built". Toss a coin as as either way is not exact for some value of "exact".
