Old Collingwood
  1. Evening shipmates, more progress with the cabin bulkhead - I fitted a wood facier around the curved roof section, and while this was sticking I decided to attack the door frame, this has a curved top but after several attempts at bending some 2x1mm strip against the grain with water and heat tool - no good, so plan number two was to do the sides sepaerate and the top by two pieces joined together then sanded to shape. While this was setting I turned my attantion to building the first of four windows - I went with square windows but decided to fit some clear plastic behind to simulate glass - this was done by laying the plastic sheet on the cutting mat and adding each window frame in turn to the sheet, then with gorilla glue and seven frames later a window was formed. I touched up the rear of the window with black paint then when dry glued the first one in place on the bulkhead, next of I added some wood trim to the top that follows the line under the curved rail. So next off will be three more windows - A few pics to show the progress. OC.
  2. Yep, thats the pearl after she was altered for the last film - she has had anothe layer added ontop of here poop deck kind of a "Poopy poop deck" OC.
  3. A shot of the actual ship curtosy of Hawi'i magazine shot in 2011 for one of the later films. OC.
  4. Good evening all, today I started working on some of pearls details - in the kit the molded rear bulkhead that contains the captains cabin door and windows is wrongly shaped infact even the door is best suited to a mouse as its way to small, so first thing to do was a bit of butchery by cutting out the curved section, I found using my sharp scalpel was best to do this, after cutting it away I decided to apply some heat with a hairdryer to the piece removed, then on the table I was able to flaten it, then after trimming some of the ends I was able to glue it back in place (but as a flat bulkhead not rounded). Next was to increse the size of the mouses door so humans could use it, I filed it till it gave me a scale size of abut 5.5 ft tall and 3 ft wide, this will have a double door attached to it after I make them and also a few windows. I also decided it would be fitting to make the bulkhead fitted with wood planks - so I set about measuring-cutting and fitting these - I have gone as far as a plank or two from the deck - I think its a nice improvement over the plastic bulkead. Here are a few pics showing the instructions with the wrong curved bulkhead and the flatened fitted bulkhead then the planking going on. OC.
  5. Wowzer! no good asking me I know as much about sprayers as I do Rap music. OC.
  6. I love Sushi - but I get them to cook it through propper first, and coat it in breadcrumbs. OC.
  7. That would have been very cool if I could have run them off tiny solar pannels hidden inside the roof window, as I wouldn't want wires running outside the hull. OC.
  8. So no time like the present I opened it up and made a start putting some paint on the upper hull parts and other hull parts, I chose a slightly grey/black color that is supposed to simulate a burned wood affect. I will be building her (very slightly differently - well A lot) from my original plan, as I will be using the Fantastic kit as a base but adding many wood parts including - masts and spars, decking, details and rope shrouds and all running gear. I am not sure if she still belongs here in the scratchbuild section (modes let me know what you think) I am really looking forward to this build as the kit is Fantastic and aided with extra detailing it should be a stunning ship. "Oh Arr me hearties" OC.
  9. Good evening all, Day started off as normal till the wife told me there was a parcel waiting for me (A very large parcel) I wasn't expecting anything so I opened it and to my complete supprise this was inside it - 🤩🤩😀😀 OC.
  10. I love your keel supports denis - very well thought out, being able to move it along the length of the slipway is a great idea. OC.
  11. A bit more TD work in Paint - I have the frames sorted now and scaled to 1/100scale same as the keel, I will try to get these printed off as they will give me an accurate plan to work off. OC.
  12. If I was sensible I would just convert the plan to the correct 1/100 scale in windows paint, then save it as a 1/1 pic file then print it out on some 20inch paper, but I have no ink for my printer. OC.
  13. Great to have you onboard its shaping up to a good crew and a four legged hand. OC.
