Everything posted by Kevin
lol thinking hard about re-naming her, the green is just not working for people, any suggestions?
- 273 replies
- panart
- amerigo vespucci
welcome to the best forum please start a build log, plenty of help and advice here,
i use flory stuff all the time, as my modelling skills are quite bad this is a couple of the colours grime, rust, grey, sand are on this test peice for my St Nectan build, i use grime a lot as its water based it can be made up in layers or watered down, desigbed purposely for plastic as it can be wiped of when dry, obviously not with wood having said that though i painted my mast tops in black primer
Good evening and than you, yes i did, all metal is now being soldered, lol i should get quite good by the end of this build
- 273 replies
- panart
- amerigo vespucci
im having the same issue on the Amerigo getting 20 pins into a rail where the kit has provided room for 7
coral fishing boat by maurino
Kevin replied to maurino's topic in - Build logs for subjects built 1901 - Present Day
thats a very nice build -
good afternoon everyone still a few fittings to sort, but i now have possibly a ladder im happy with,amother 3 to go but will all be slighly different in the way they are rigged if in the long term i do make it again, i will use the original idea of more brass, but for now this is staying
- 273 replies
- panart
- amerigo vespucci
good evening everyone must admit I never realised just how much extra work i have given my self i am still working on the first of 4 accommodation ladders, and every time i look at @schiffebastler build i see more detail to be added. i was asking about how to cut brass tubing into small sections to make the Stanchion supports and found out if i put small lengths into a rotary drill i can score the lenghts quite accurately with a x-acto blade
- 273 replies
- panart
- amerigo vespucci
stunning build, and made even better with decent clear photo,s well done
- 950 replies
- syren
- model shipways
good evening everyone ladders continued i made up a second set of platform supports, but had to reposition the lower platform slightly to allow the upper ladder to rest on it the lower ladder is lowered and raised by a block and tackle derrick so a couple of brackets made up to support it made up a chain spreader the chains are to long and blocks oversized and the spreader could do with being not quite so wide or i may make the platforms a little wider, which might be the best option a messy desk tonight
- 273 replies
- panart
- amerigo vespucci
Building a Medieval fortress - by Waitoa - Del Prado 1/87
Kevin replied to Waitoa's topic in Non-ship/categorised builds
thats lovely -
Thank you Yves that's a real compliment from you
- 273 replies
- panart
- amerigo vespucci
