Sailor1234567890
Everything posted by Sailor1234567890
  1. That bowsprit fitting is properly called the cranse iron.
  2. I'd say pick the one that's closest to being done and concentrate on her. Then move to the next closest. Oh, and don't start any more new ones until you're at least closing in on the last one remaining.
  3. Does anybody know how nippers were passed in those days? I know we do it differently now than what' you've got shown here and was wondering if anyone knows for sure how it used to be done?
  4. I'd be inclined to put the lifeboats upright and the captain's jolly boat upside down. It wouldn't be used often whereas the lifeboats need to be ready at a moment's notice.
  5. Ed, As usual, your work is exquisite. I have a question about that lower top'sl truss. Are you taking it from drawings, scaling of photographs? A rigging plan? I can only imagine the stresses that piece must have been under as the lower top'sls were the last sails handed when stormy weather came so were therefore often the strongest sails in the ship. Still, that truss looks bulky to me. How does one determine who much structure is required to meet stresses of hard usage but not overdo it and add unnecessary weight aloft or make it "look wrong" in the process?
  6. What's the purpose of those hooked scarphs the whole length of the wale? Why not simply use straight planks?
  7. Have you tried soaking them in tea instead of using paint? Tea stains can look pretty convincing.
  8. By this period in time, most tops'l sheets were chain with a block and tackle out of rope. The wear around that block on the end of the yard and then the block in the middle of the yard underneath was quite severe. Theses ships rarely handed topsails as they were the last ones to be brought in so the sheets needed the best abrasion resistance they could get and chain was it.
  9. The more I watch your builds progress, the more impressed I am with your skills. Any idea what your next build might be?
  10. Those little wooden structures fore and aft are properly called "poppets". I like the idea of displaying her that way. Adds an element of realism to the whole thing.
  11. All the wood bending information I've read says 1 hour per inch of thickness. Seems to me for pieces the size of our ships, 1.5 hours would be much too long. I've never bent wood at this scale though, I do mine much larger.
  12. Another thought... Are the blocks rove or laced? With Triple blocks, there's a process to reeve them so the last part, the tailing part, comes out the middle sheave. This will allow for you to be pulling on the middle of the block rather than one side which might tend to capsize the block. This is called reeving the block. Otherwise, starting at one end and simply filling in the sheaves, it called lacing the block. Not optimal.
  13. I would tend to think having the working part come out of the lower block or at least a lead block on deck before going UP to the pin rail would be most logical. Firstly, you mention more men tailing on it which is important but also, I think it best to have tension compressing the uprights for the rail rather than trying to pry it off the deck pulling upwards. I'm designing just such a system in my boat and all leads will come up from the deck to make fast to the pin rails in order to keep everything under compression.
  14. I might need that PDF, I cannot picture what you're describing at all. I'm not familiar with the intersection feature and that may be why.
  15. Sorry to be keeping you up for 2 days straight Ed. It just struck me as odd how it was laid out. I've got some experience sailing square rig (not with Stunsl's though) and I quickly picked up on that little discrepancy. I Googled the Barque Picton Castle, admittedly a much later vessel. She is however extant today and has stunsl's. The gear is set up funny in that instead of a straight bar from the yard to the ring of the iron, it's a curved bar starting on top of the yard behind the jackline and curving forward so the ring is located where yours is. Outer boom iron isn't an issue as it's located outside the earing and does not interfere at all.
  16. I have underhill's book. It really is a goldmine. I purchased plans to a boat last year with the intention of building her. She's a 57 footer with a number of different rigs. I would love to put the Hermaphrodite Brig rig on her and if I can, I will include stunsl gear. Underhill has been invaluable in planning her rigging work. I have a few other sources like D'Arcy's book and a couple of others. Maybe the uppers were the only ones hauled up bunt first and I was mis remembering seeing a lower hauled up that way. I know the smaller like moonsails, skyscrapers and such were often hauled up on the yard.
  17. Are you including the lashing to ensure the booms don't slide out? normally they would have been lashed together at their butt ends to prevent them sliding out as the ship rolled. There's a tackle rigged to haul them out and a lashing to keep them secured together when not in use. I love stuns'ls and find the rigging of them intriguing. Sure you won't include some in your model?
  18. My understanding of square rig has it done as follows. Bending sail was done, as you say by hoisting the sail up, stretching it along the yard and making the robands fast to the jackstay. It wasn't hoisted with the bunts and clews though as far as I know. The reason was that for upper sails, those lines are not even close to long enough to reach the deck. Even the lowers would not quite be long enough to reach the deck as the sail was above the deck height and having more line than necessary to work the sails was wasteful. It was hoisted by a single line made fast to the bunt of the sail. This was hoisted from well above the yard in question. In other words, the sail would be prepared on deck then folded in half, hoisted bunt first up higher than the yard then lowered as the earrings were hauled taut to the end of the yard and robands made fast. I don't see how the head of the sail could be lashed tight to the jackstay as you've got the images of your model. The booms were triced up and the inner irons were hinged as you show but how do you get the head of the sail lashed up tight against the jackstay with that boom iron in the way? There would need to be a slot in the sail. I'm better versed with more modern yards and ships like Cutty Sark where they generally had two jacklines and the boom irons were often below the yard to keep them out of the way a bit more. I guess the questions remain.
  19. Looking closely, I have another question. The boom iron is shown on the forward 10 o'clock position or so in that second last image. It's significantly forward of the jackstay. The jackstay was used to fasten the sail to so how was the sail bowsed up tight to the jackstay if the boom iron was so far rotated forward of the jackstay? Or was the sail not lashed tight to the jackstay?
  20. Question about how you've temporarily rigged the bridles. Were YA's sails furled to the bunt or the yard arm? I ask because you've got the bridle about mid way out the yard which would not be proximal to the edge of the sail if it's furled to the yard arm and may or may not be if furled to the bunt, depending on how the sail ends up furled. I tend to think that if the sail was struck below, she wouldn't have the bowlines rigged at all. I may be wrong though.
  21. It would have been more a useful move for the French than the English. The French aimed high to damage rigging. The English aimed low to damage hull and crew.
