Everything posted by vossiewulf
I'm betting he duct taped the phone to his forehead and used his nose to take the photo.
- 969 replies
- hahn
- oliver cromwell
I'm in Charlottesville, I've seen a few other VA modelers.
Thanks Mark, you have a nice setup and process there, much better on the organization of the blades than I am. I think I might borrow the way you're doing it. Also I am unhappy with my bench pin as well, I will go look at the Knew Concepts one, I haven't seen that before. For everyone else reading, stop by the Knew Concepts shop and take a look around they have very good tools, as Mark is showing you can do some very good work with them
Welcome John! Ships are kind of the final boss on the modeling tree, the challenge ranges from "hmm that's tricky" to "OMG I think my eyes are bleeding" Have fun and go slow and read others' build logs to see what tools and techniques they're using, there are some extraordinarily good builders here.
Neverland Hobby - is this a legit model manufacturer?
vossiewulf replied to bruce d's topic in Plastic model kits
Chris the problem is as I pointed out at Drydock Models there are new manufacturer names popping up. If the NRG is serious about its stance it needs to one track manufacturers and identify the pirates and two keep the published list up to date. -
Greg could you use a small tubing bender on the copper?
- 288 replies
- Santos Dumont No. 18
- hydroplane
They're made of thin spring steel coated in diamond abrasive, making their lifespan essentially indefinite when used only on wood. So they're a bit fancier than a strip of sandpaper.
- 22 replies
Actually I think it's fine if you have a build log for the locomotive here, it just has to be in the Non-Ship/Categorized Builds Forum, look under The Crew's Lounge.
I buy the big 8oz bottles of glue from Bob Smith Industries and keep them in my fridge. I just had to replace them all because I moved, but the previous bottles had lasted for 8 years. I'm very careful dispensing glue from the bottles to my tattooist ink cups, and generally a quick wipe from a finger or a piece of cloth removes any excess.
Thanks I'll check out Line of Duty!
- 714 replies
- lady nelson
- victory models
First, Second your English is just fine Third, looks like you've made a good cautious start!
- 11 replies
- Sherbourne
- Vanguard Models
As long as the shorter base is reasonably stable, I see no reason to lengthen it. And lengthening it would just draw the eye away from the boat, where you want it. Well wait only thing that I'm questioning about this base is it seems the overhang of the model on the base is longer on the bow than the stern, although that may just be parallax in the photo. If the overhang is not equal, I'd suggest making a base with the overhang symmetrical, as that would be most pleasing to the eye.
