Very nice, fine detail work there, OC.
Looks great!
Thanks mate,  I did slightly chicken out of making the PE 20mm compete guns though :rolleyes: just to small and fiddly to bend those tiny parts, so i resorted to using the kit plastic ones with just the PE shields.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Did you notice in the "what did you receive" topic that some fellow modelers are acquiring those stereo microscopes? That may be just the ticket for these very small PE parts. Normal magnifying lenses just are not quite powerful enough sometimes.
Like you, I have so far procrastinated on building all the 20mm single guns for my project. A certain amount of dread in building so many and so small, tedious.
bunny1954 ( ;) ) beat me to it, but you might consider adding a pair of stronger eyes to your own. It will certainly ease the headaches and the pressure on your eyeballs. I know it did for me! I don't know how Greg and you do it, but my eyes would be bursting by now ...
Cheers
Carl
Cheers
I have to take my eyes out every now and again - just i struggle to find them afterwards :D
OC.
Current builds
Completed works.
They would be small at that scale OC; but to me the driver would be the quality of the kit part.  If it holds definition and shows the correct detail, stay with it; otherwise... :)
cheers
Pat
Oh I foregot to mention - I have left the ammo cover's open on the boxes - you can just make that out in the pics, but also put a choc bar wrapper inside the bottom(only joking) :P
OC.
Current builds
Completed works.
OC,
If you want to show off with your details, you'll need to improve on your picture quality. At least macro ;) I can't take my eyes out, I can only add a layer to them ... ;) You must have very sensitive fingers :P:o;)
Carl
OC,
Its just an old Sony Ericcson mobile phone camera to be honest, thats all I have as my other cam that had macro died a death.
OC.
Current builds
Completed works.
Sorry to hear about its premature demise, OC. Then we'll have to make do with what you've got. A pitty though, now your marvelous details are a bit fuzzy
Carl
A bit more time on the bench(table) today inbetween wrapping presents,  I managed to put a few coats of paint on the 20mm Tub, I started with light greay on the inside followed by the outside, then a coat of black on the machine gun then............she was glued into position followed by a light touch up with top coat.
A couple of pics again slightly oof due to the cam phone but I think it gives an idea.
OC.
Current builds
Completed works.
Two more pics folks - I didn't like the first attempts above so despite it being night time here, I took the ole girl into the kitchen(more light there)  and took a couple of shots at a slightly further distance as I was to close with the others.
Here they are -
OC.
Current builds
Completed works.
I'd hate to be manning that bow position if the main guns were firing forward!!!!  :pirate41:That would make your ears pop :D
HMAV Bounty 'Billings' completed
HMS Cheerful - Syren-Chuck' completed :)
Steam Pinnace 199 'Billings bashed' - completed
HMS Ledbury F30 --White Ensign -completed 😎
HMS Vanguard 'Victory models'-- completed :)
Bismarck Amati 1/200 --complete  👍
HMS WARRIOR Billings just started
That rear 20mm tub is on the stern she never had one on the bow, but get where you are coming from.
OC.
Current builds
Completed works.
Ha ha of course I should have spotted it was the stern, serves me right for sneaking a look on my phone in work
More updates folks this time on the two hull side rear deck 20mm Tubs,  these are slightly different as they both have a lower rim on the front sections, this was done using a fine file and sanding stick(very carefully as the resin is very thin)   next  I worked on building two PE boxes by the same method as before, these where glued in place along with a door each, next was a thin rim that I made from some wast PE strip.
Here are a couple of pics showing the pre painting stage with the two Tubs.
Current builds
Completed works.
Next was to give both Tubs a couple of coats of light grey, of note is the lack of 20mm machine guns as they were not carried in certain Tubs during D Day, I would imagine this was due to the channel having UK and American air superiority over those areas, hence less need of fire cover.
Here is a pic showing the light grey paint finish on the Tubs.
OC.
Current builds
Completed works.
Not much to say so I will let these photos say it all - port and starboard Tubs fitted.
OC.
Current builds
Completed works.
glad to see your sticking with it OC..........your doing a great job so far.   hopefully,   Santa will bring you a spanking new image duplicator under the tree  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I havn't left folks just a bit disstracted by my new toy :dancetl6:  "whooopeee"
OC.
Current builds
Completed works.
NICE, OC!!! Got a tripod with it? You will be hard pressed to keep that from shaking .... Whats the zoom?
Cheers
Edited by cog
Carl
Greetings
Well done, still excellent work. My camera is a different shape to yours. But I am not jealous of yours, because my Box Brownie does not need batteries and yours does. !!! DAVID
Hi there,   Thank you for having a look at my build :)
OC.
Current builds
Completed works.
Cheers
Its a Fixed length prime lens  300mm  f4   none Vibration Reduction  but fine if used with a shutter count over 1/500sec  hand held.
OC.
Current builds
Completed works.
Looks really nice, but I know next to nothing about cameras.
Looks like quite a lens on it.
Yep  300mm  quite average size these days but the camera helps having 24mp.
OC.
Current builds
Completed works.
no excuses now..........I'm sure that silencer is removable  :D  :D   we expect A+ pictures from you for now on  ;)  very happy for you! :stunned:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I only have the one telescope i meen lens for it, so im affraid we will have to do with my cam phone pics.
OC.
Current builds
Completed works.
You can stand on a chair, and shoot from that distance, will look like close-ups :)
Edited by cog
Carl
Hi OC
Nice camera.
I have just purchased a new one myself, Canon 7D Mark ii with a EF 100mm f2.8 L  Macro IS USM lens.
The only thing is cannot download the photos to my computer, it will start but then it stops about half way through, and that is using the Canon software that came with it..
The comp has 8gb ram and still got 680gb space left on the hard drive.
Denis.
