awesome process Kees  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
The chimney has a simple shape at first glance but I got some drawings of it and then you find out its a rather complex shape. There are some curved, round shape which run into each other. And there are some details which form a nice challenge to me.59ca73c5ea65b_Pelikaan(119).thumb.jpg.66be5360d0b1ec01bf5864291bd383a3.jpg59ca73c25382a_Pelikaan(118).thumb.jpg.a4e9675664fc4510a7857c0bc4c41579.jpg59ca73be6d2c4_Pelikaan(117).thumb.jpg.804ba2b6850285cde3837906105d1592.jpg59ca73baf22f3_Pelikaan(112).thumb.jpg.dfc9b806277ba819a83106c3598263d9.jpg59ca73b6d3024_Pelikaan(111).thumb.jpg.a39337a39b674f7136f01e1af29ac5e8.jpg59ca73b34e6f8_Pelikaan(110).thumb.jpg.4800640b1593f16c99f2a2037645559c.jpg59ca73af8dc51_Pelikaan(109).thumb.jpg.f5324a127d19bbe059e59b8cdac249d1.jpg
offcourse I will add the details later
Edited by kees de mol
Fantastic stuff Cees.  This mold making thing is a mystery to me, lots to learn yet.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
awesome process Kees!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you all for the motivations guys. I like your work very much too. This is a great forum!
Now on with the building. Next week I will focus me on the details because I missed that last week.
(I am currently also building the moulds for the GRP-hull. But **** that polyester smells bad :o And glassfibers irritates so mutch! )
Hi Kees
Thanks. Your comment about the fumes from the polyester reminds me that safety is paramount when using these materials. Hopefully, you're doing it in a well ventilated area?
Cheers
Patrick
Yes I laminate with two windows fully open. And to keep the temperature high (15 degrees celcius) I've placed twee electric heaters next to the mould. Then after laminating I close the door (which is air sealed with rubber strips.) But the smell is there anyway. Its even in my workclothes so I have to leave them in the hobbyroom. Better is to work outside but the temperature is much to low
When I worked with epoxy I never had any problems beacause it has so little smell but I found out epoxy is way more harmfull for humans than polyester.
Here I made a start with the winchhouse. I couldn't build this without the original drawings I got. The polyester hull is also a bit closer to completion but I will post the photo's when I have some more results.
To be continued
Super and very inspiring work Kees,
it`s lovely to watch the experience you gain with this material and its possibilities for shaping / resembling model steel structures
Nils
Current builds
-Lightship Elbe 1
Completed
I went building on the chimney's. They needed lots of detaills after I had cast them. They are finished for 75% now so I have some work to do yet.
See you with the next up-date
I finished the searchlights. Lot of parts and very small to make. I also used the lathe to make some signal lights (the glasses) There are 13 glasses per chimney. I made a toolbit to make the pattern in the clear plastic.
59ca74b206141_Pelikaan(143).thumb.jpg.fb6ee7d931142ca66e3b205d7417eb4f.jpg59ca74ae624dd_Pelikaan(142).thumb.jpg.e1cc54f767914f71d6625ebe6c2ea464.jpg
Next update i hope to show the finished chimneys
sweet looking search light  ;)   you make your own decals too?    what program do you have?   I have the Testor's  'decal it' standard edition {it's put out by  'sure thing'}.  they come out nice,  but this program has a sort of transparency issue.  I don't have the means to darken them, or adjust the pixels.  so,  it limits where I can use them......mostly on light colored backgrounds.   I can change the background to match the color I'm using,  but there are so many off shades and hues,  it tough to get a good match.   does the manufacturer have a web address?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Very nice work on the search light Cees.  All that mold making and stuff is just a mystery to me, you are a genius.
Cheers,
                       VOC Ship Surabaya
I used a programm Paint.net to scale down the pictures. And I also use Testors white decalpaper. I dont know much about it and just tried it and it worked okay.
Cheers,
I am sure you can do it too. I am not much of a genius. I have just a lot of fun building like you all do with your wooden ships.
 I don't have the talent to follow Kees
:huh: I think it's right to say I have some talent (Thank God) but to say you can't follow me that's a bit exaggerated. There is so many talent here and I enjoy all the buildinglogs. Building with wood is for me a very big mistery
Kind regards, Kees
I use photo shop......sounds like they're pretty much the same.   I also use the Testor's decal paper,  both clear and white.   knowing that printers don't do white,  I've been able to print white decals by altering the background color,  like I did with the Andrea Gail.  white decal paper would be a good choice,  since the white decal film will act as a backing for the image and produce a bolder finish.   the only problem I see there though,  is that laying the decal on a different color surface,  would create a 'sign'  effect.  I saw this while trying to do the depth markers for the Cutty Sark {this build started me doing my own decals}.
I think you'd do well with wood Kees........you have the eye,  the skill,  and the talent.  most of all.....imagination  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
marvelous work Kees,
you sure know where to place all those lovely details  :rolleyes:  :)
Nils
Current builds
-Lightship Elbe 1
Completed
Today I did the last things to the polyester mold. I cut all the edges sanded and everything. Then it was time to find out if both halves of the mold wanted to separate. First I very carefully put a chisel between the halves and into the gap I tapped wooden wedges. It took some time and effort but suddenly The first halve separated from the wooden hull and after some tapping the other half released.
I am very happy because it was quite a lot of work and it was very exciting if everything would work the way I wanted.
59ca754eb5be8_Pelikaan(184).thumb.jpg.9a57598f04f8e1a97dfb8df08d53f865.jpg59ca754a5744f_Pelikaan(181).thumb.jpg.f489dcd70bd7edfe84850c064a821e03.jpg59ca754724ea5_Pelikaan(180).thumb.jpg.28633e4e2fd705d80f9a177361e232ea.jpg59ca754264e35_Pelikaan(179).thumb.jpg.e812e6eda31dd3eda4782d7503125b87.jpg59ca753f291f5_Pelikaan(178).thumb.jpg.30a879076e3d181653dbb30a41c67c18.jpg
Nice work, Kees. Breaking off the mold is always scary.
Looks like a great mold Kees.
Michael
WOW!
Cheers,
                       VOC Ship Surabaya
You should be proud of such a nice mold.
Bob
Current build:  SS_ Mariefred
