Looking good, Nils.  I have my fingers crossed for you when you get to the propshaft area.
Many thanks for your words Patrick and Mark,...
and all the "likes"
Patrick,
Oh, and I nearly forgot to insert the stb. and port bilgekeels, (got some aluninium flat material for the keels), before the roundings are planked. They are going to be "sinked" radial a bit into the Frames in midship area for secure hold
Mark,
I knew that that area will cause some headaches, I`ve seen one or two models of this ship on the web, and the builders managed to do that beautifuly, thats quite tempting and encouraging
Nils
Current builds
-Lightship Elbe 1
Completed
John,
I thank you for your word, perhaps if I would have Talent in sculptering there would have been made some partial blocks carved out with sculpturers hammer an chissel, to be fitted in
Nils
Current builds
-Lightship Elbe 1
Completed
Patrick,
Nils
Hi Nils
Good luck with the bilge keels. Incidentally, I'm pretty super excited. Why? Because I just realised that this is actually the first build log of yours that I'll be able to follow from the very start of construction. For instance, I joined MSW when you were at least half way through your Pegasus build and your earlier ships were all finished. So, this gives me a good way of watching and studying every step of construction from a master craftsman!
All the best
Patrick
Edited by Omega1234
Just came across your build log...fantastic work and execution.  I'll be following along.  Great job.
Rob
Current build:
Finished build:
Current build(On hold):
Thank you very much Patrick and Rob,
and the "likes"
Patrick,
for the bilge keels I cut off some of the Aluminium Strip  width, but when mounting and considering the planking thickness, I should have left the Strip in its original width, in order to get a good hold in the hull. So get a new Strip back to start Position and do it over...
Rob,
welcome on board, ist nice to have you viewing the log, I hope you  will further like the Progress, and thanks for your complement
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
She's coming on well Nils B) Just a suggetion,would it be easier to plank,then cut slots to insert the bilge keels into?This is common practice with working models,it allows you to properly fair the hull,then epoxy can be used inside the hull to secure the keels.Ideally they should protrude though the hull a few millimetres.
Kind Regards
Nigel
Currently working on Royal Caroline
Kind Regards
Nigel
Thanks for your tip / suggestion Nigel,
it is much appreciated..
I also thought about the commen way, but on the other hand these bilge keels being appr. 40 cm long will be made from flat aluminium strip, so the won`t brake off, if by accident (when handling the hull so many times during planking and later on metal-plating) the hull knocks agaist anything
I wanted a safe anchoring into the 8 concerned Hull frames and do the outside planking around then. Fortunately there will not be much fairing necessary, plse. refer to enclosed handscetch...
cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Very nice work Nils, she's really taking shape
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
this will be the version for inserting the bilgekeels......
Nils
reinforcement to the 8 frames concerned, and slotting with a metal-saw blade
aluminium flat 2 x 15 mm, raw and bent over the high side, and slotted "bilge keel"
the bilge keels and the frames bear slots that interlock, (will either glue-in with epoxy or high viscosity CA
holding a scrap piece of plank against the bilge keel, to check the remaining standover outside the hull
my "nasty" area, but I have to "face it like a man"....
Current builds
-Lightship Elbe 1
Completed
Hi Nils
That looks like a good solution for the installation of the bilge keels. Once installed, they're going to be rock solid!
With respect to your "problem area", I've got no doubt that you'll not only face it like 'a man', but you'll also conquer it convincingly!
Looking forward to your next update.
Cheers
Patrick
Edited by Omega1234
Patrick,
thanks for the good words...
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Johann,
this will be my second coal-fired steam ship (in actual built and launched before 1900). I love These heritage steam ships
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils -- I've wondered where you've gone, and now I've found you!  It's quite a shift to go from the 18th-century Pegasus to this sleek ocean liner, the KWdG.  I have just read through your log and am as impressed with your work here as I have been on your other build.  I spent half an hour apiece just admiring those propellers!  I can't wait to see your engineering knowledge and your building skills come together (with a good splash of imagination as well) on this beauty.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Hi Martin,
welcome to my new Project, its nice to have you on board, and many thanks for your Kind comments.
In the Moment I`ll have to find a break to complete the "HMS Pegasus" as there is not so much to do on that Lady anymore, and of course the glass case for it.
For the new ship I had so much drive, just because I wanted to see if it would turn out as it appeared in my mind, and because I had neighther  proven build plan, nor intructions for doing it . You are quite right with your comment related to that "splash of Imagination", but I love to find Solutions that make me come nearer to my Imagination.
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 8
starting with the geometry of the hinge mechanism of the underwater- rudder.....
Nils
first the obligatory handscetch....
the skeleton of the rudder bears the frame and will be sidewise cladded with brass sheet
the other part (flat post) goes to the sternpost.
Here I pushed a 1 mm drill in as preliminary pivot-pin
The permanent fixed bilgekeels are mounted
four 13 mm planks are put on each side
will fit the raw, hinged rudder skeleton in place next, and then mount the tail cone filler pieces
Current builds
-Lightship Elbe 1
Completed
thank you very much Patrick...
Nils
Current builds
-Lightship Elbe 1
Completed
planking looks really nice on there Nils.   the admiral one days asked me why I don't try to make my own planking.......I'm always getting basswood flat stock sheets.  I told her that it's because I don't have that kind of saw  ;)  {is that subtle enough of a hint}   too late for father's day though  :D  :D
      I'm trying to get her over to the local hardware store  {Home Depot},  so I can show her.   going to be interesting how you'll do around the screw tunnels.  you could use flat stock fillers,  bent to shape.    I have no doubt that you will do well with them.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
well Popeye,
in that case you need some strong arguments, for saving money, and for making the planks in the dimensions you need (thickness, width, length, etc...      ;)
added are some pics I shot under my carport, where I do the plank sawing now and then.
The electric circular hand saw has a blade with tungsten teethtips, and I mount everthing on my mobil work bench. I`m taking in account, that the automatic shut-off is disabled when I "pull the trigger" with this big clamp-peg I put on it, when it runs.
cheers,
Nils
the raw material for cutting the planks from are kept under my carport roof
the handsaw "converted" to a table saw (mounted from underneath)
The desired width of the planks is subject to the raw plank thickness chosen for cutting from
to activate the trigger I have to reach under the workbench
This clamp peg I put over the trigger in the saw`s handle (for safety reasons this ca`nt be recommended, utmost caution must be given during operation !!   :(  :o​ )
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Please be careful when using your high tech saw. I shudder when I see that arrangement.
But be confident - I actually used to know a carpenter who still had all his digits after years on the job (he only cut some tendons on one of the fingers). :)
Take care
Peter
Beautiful Job on those Rudders Nils, Shes taking shape at a very fast pace Nice work
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you very much - Peter - Pete -  David,
and all the "likes"...
Peter,
Thanks, I know, I`m not so happy with that Arrangement, therefore I take utmost concentration and care when operating it
Pete,
thanks for your remark, yes, I think the raw-hull will be done pretty fast. It will be faired and a nitro-Wood-bounder put on it, to get the Basic smooth surface for the metal plating Job later on
David,
I´m trying to get the hull the way it Looks like in those old dock photos
Nils
Current builds
-Lightship Elbe 1
Completed
Mounting rudder to the keel heel.....
Nils
the brass reinforcement is glued in place with Epoxy 2 component glue, the 4 brass anchors are additionaly put on
The long ends of the anchors will be clipped off inside the keel outcut
Current builds
-Lightship Elbe 1
Completed
Nils,
May I offer a suggestion; instead of sanding the hull, why not try a spoke shave. It would save a lot of time and dust....
That is the way I fair all my planking.
Beautiful ship, thanks for sharing with us.
Larry
