Difficult to explain the glue swelling, Paul.  Titebond II is a waterproof glue.  I paint acrlic over it all the time.  Could it be the sanding sealer?  Curious problem.
Ed
I am wondering if the water has somehow affected the wood strips (ie.e swelling when wet, shrinking when dry) while the glue remains unaffected.
Assuming your wood strips swell first and take the glued edges with it.
Then the wood shrinks (drying of water) while the glued edges remain in position?
Not sure if i am making sense here, but just a thought.
Heghlu'meH QaQ jajvam
Slainte gu mhath
L.H.
Hi Ed, I'm not sure either, I'm using Liberon sealer which is a spirit sanding sealer containing ethanol, resin acids and rosin acids??
Hi landrotten I don't think there was enough water in the paint to make the planks swell and shrunk but could be wrong, personally I think its something to do with the sealer as Ed said, but again not sure
It is quite a nice look though however it came about and actually looks like I caulked the seams properly !!
Thanks all for the likes and comments
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
100% chance of rain all day today guess where I will be all day
Made a centering marker out of some pieces if boxwood I had in the stash after reading on another log somewhere about them
Also found a use for the spare handle I made for the wife
Regards
Paul
Previous builds-
Among others 😁
Decided it was time to start the channels as I am working around the ship, cutting the rebate into the waist rail in situ as I hadn't done them when building the Hull as a bit perilious but going slowly I managed
Fore channel being shaped from a piece of pear
And having the edge scraped
Regards
Paul
Previous builds-
Among others 😁
After one coat of sanding sealer
I cut the pearwood both ways with the grain and as this one across, from a strength point of view I should be using the other piece but the grain on this looks awesome and as I'm not going to be doing rigging on the model should be strong enough, I'm going to cut the edge off and file in the rebates for the chains
Regards
Paul
Previous builds-
Among others 😁
Thanks Druxey, I'm thinking the same, I might stick some plank together and see if I can recreate the problem
Regards
Paul
Previous builds-
Among others 😁
Air gaps have been sanded into the back, drilled for fixing bolts, test fitted to the side
Regard
Paul
PS thanks all for the likes
Previous builds-
Among others 😁
Cutting the mortices in the breast beam for the stanchions
The cross piece will be cut in half making the two sides but I'm keeping whole until all mortices etc are cut to keep the spacing
Port Side morticed in starboard still ti cut in, After dropping two stanchion down into the depths I thought I had better cover the gun deck before i lose it
Regards
Paul
Previous builds-
Among others 😁
I also started on the main channel using cross cut pear same as the fore channel, look at the grain beautiful isn't it
Regards
Paul
Edited by paulsutcliffe
Previous builds-
Among others 😁
Its amazing now the addition of a few pieces makes it all start to look like a ship and it starts to come together, all starboard channels are now made and have bolts nothing glued as yet as I have to work out how to make the supporters
From the bow
Mizzen
Main and stool
Fore
And a little test with a boxwood deadeye, I noticed some scratches on the fore channel and removed it to refinish, this is what I'm using for polishing up the pear to a smooth shine from left to right finishing with 0000 wire wool
Regards
Paul
Previous builds-
Among others 😁
Experiment to try and recreate the caulking lines as per the Cheerful, four beech planks all have had three coats of sanding sealer smoothed inbetween
Right hand side(bottom) also had some oil rubbed in and then painted on top, I'm sure the colour doesn't matter as its still acrylic
Left hand side is straight paint well watered down as per landrottens suggestion
As yet no reaction like my cheerful Hull, only difference is this is beech and the Hull is holly, could that have anything to do with it??? And still needs a few more coats of paint
Regards
Paul
Previous builds-
Among others 😁
Of course you are correct Druxey, I didn't think the wood would matter as seemed to be something to do with the glue, however I will do again tomorrow with some holly strips
Thanks
Previous builds-
Among others 😁
It's the mix of all the items you used that may be the problem. If other wood species do not cause the effect you had, it would have to be the combination of the holly and other items in the stew!
Holly strips are glued up and ready to go, meanwhile I made the two steam gratings for the forecastle
Coamings are ebony and boxwood grating, cambered to match the deck planking, knees on starboard also finished and bolted, work on the waterway has also started with its lovely curved scarph
Regards
Paul
Previous builds-
Among others 😁
Second plank experiment, Holly strips, titebond dark glue with 3b pencil highlights, two flats of sanding sealer flatted between, so far no raising of the lines
Also at the bottom first and second attempt at belfry roof in ebony and one coat of sanding sealer
Thanks
Paul
Previous builds-
Among others 😁
Ebony has been polished down to 5000 grit sandpaper and second coat of sealer added
Regards
Paul
Previous builds-
Among others 😁
Nice work on the ebony Paul.
Michael
Regards
Paul
I like that scraper ('s). Gonna have to learn about that.
Jim
Hi Jim @Jimt
The scraper is just a hacksaw blade trimmed to different shapes with another saw and files where necessary, I even have the ends trimmed for doing a bead in awkward places
Regards
Paul
Previous builds-
Among others 😁
I have also started turning the legs for the belfry, according to my plans they are only 2 ft.(12mm) High, 6"(3mm) wide at the base, I can't quite get the taper yet but I have got the shape down from the plan, I also scraped around the edge of the roof, could only manage one line though in the space.
Regards
Paul
Previous builds-
Among others 😁
Paul, what are you using for sanding sealer?  There are many varieties.  Titebond glue is resistant to most finishes, but as we know, our favorite "ungluer" - isopropyl alcohol - will soften it - and probably swell it in the process.  Perhaps the sealer had this effect.  Also, if the glue joints on the curved hull were not tightly fit and the gaps filled with glue, that would be different from your tightly matched straight joint lines on the test piece.  Another possibility: you mentioned dark glue.  Is this purchased as dark glue or coloring mixed into the normal Titebond.  If the latter, what is the colorant?  Which grade of Titebond?   Just some other things to consider.
Ed
Added note: Apologies, Paul, I see you have already answered some of these questions and I missed that.  I would say that the alcohol-based sealer is a prime suspect, especially if the joint gaps were filled with glue.
Edited by EdT
Thanks Ed, I have another piece of Holly strips on the go to experiment on, hopefully done exactly the same as the planking
Meanwhile as its -2 outside in the garage I managed to persuade the boss to allow me to bring the rope rocket inside to do some more practise on the rope making
This is with the dmc ecru no 40 thread supplied by chuck with the rocket
Regards
Paul
Previous builds-
Among others 😁
Called in at the local auction place last week and came across these, just had to bid
Two perfect condition engineers vices, my humble Proxxon drill stand has just gone terminator
Regards
Paul
Previous builds-
Among others 😁
Work on the belfry has continued, not my finest piece of work and needs a lot of clean up, made the bell from the end of a brass cannon from a previous model
Regards
Paul
Previous builds-
Among others 😁
2 days in the shipyard and a lot achieved for a change
Port lids have hinges, channel supporters fabricated and attached on mizzen, dry fitted on main ready for painting
Previous builds-
Among others 😁
2 chains fitted on the main channel to work out the lengths to make the rest of the chains and where they line up on the Hull
Previous builds-
Among others 😁
