Coming along well, Kevin.
Hint: always rest a plane on its side. Sole down on the bench as in your photo leads to dulling the blade faster with grit and debris on the bench top.
Is it getting easier?
Alan O'Neill
My iPad is giving  trouble this morning. The answer is yes. The only thing is the time it takes the PVA to dry. I thought of using CA with the PVA to speed things up but so far have resisted. .
Edited by Kevin Kenny
Spelling
Cumulative error is always an issue Kevin. A glued joint does add perhaps 1/2" to the thickness vs two dry fitted pieces so perhaps deduct 1/2" per plank in the next run and seem if that lands you closer to your marks.  Some builders also add a slight bevel to the inboard edge of the plank for a snugger fit but you have to be careful you don't expose gaps when final fairing.
BTW nice fix on that bow anchor stock plank.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Have fun. Think of the money you saved by not developing holiday snaps.
current build- Swan ,scratch
on shelf,Rattlesnake, Alert semi scratch,Le Coureur,, Fubbs scratch
completed: nostrum mare,victory(Corel), san felipe, sovereign of the seas, sicilian  cargo boat ,royal yacht caroline, armed pinnace, charles morgan whaler, galilee boat, wappen von hamburg, la reale (Dusek), amerigo vespucci, oneida (semi scratch) diane, great harry-elizabethan galleon (semi scratch), agammemnon, hanna (scratch).19th cent. shipyard diorama (Constructo), picket boat, victory bow section
