Well about time for another uupdate although not very much has happened. The weather has been very good for weeks in a row now so little progress.
But Starboard side I finished up to the 3rd whale. I had to do some correction on 2 gunports. Which is the second time but it was still not ok, I simply dont understand why as I checked tripple times before.
here the wrong situation: With the 5th port already a part of an insert for the correction. 5b45d3d599ebb_20180706_152932(Custom).thumb.jpg.3a19132118482fb6bbe81c6751bcf7be.jpg
And here after correction. After sanding it is hard to even see the inserts. I used insert pieces to lower the ports instead of replacing a full plank. I was afraid that removing a whole plank would damage too much.5b45d3d3e10ef_20180710_162529(Custom).thumb.jpg.ed682a8b3a05535475fe855bccdbe634.jpg
Nest steps are the portside planking and the 3rd whale.
Rgds Hans.
Edited by YankeeD
Well i am finshed with plancking up to the third whale on both sides now. Both sides had the same flaw with wrongly placed gunports which have been corrected now.
Below picture does not show the correction yet but the camera (GSM) also has some distortion and the angel differs from the picture below of the starboard side, so it is not as bad as it seems. In the mean time this side has been corrected as well.
Now I started working on the gunports and the rabbets. To make the gunports I made a sanding tool, 2 sides sandpaper only. It works great although slow but accurate. It makes it easy for me to make sure the ports are perpendicular (thanks google).
All the rabbets are oversized in lenght, so I will make them fit and than protrude them and sand them to follow the hull. Then I will have them fall back about 1.5mm and sand the inside equal to the inside planks. I will not fasten them until I am ready to move up and start on the upper deck.
But before starting the upper deck I have to decide how far I will go. Do I install canons or not, only a wooden model or closed gunports???? havn't made my mind up about that yet.
Secondly I still have to come up with a good working method to make the gunport hatches. including the dilution to fall into the rabbet.
So all in all a lot to do still.
Hans.
Edited by YankeeD
typos
Well its been more then a month, time for an update. I finished both sides with the gunport inserts/rabbits It took me the majority of the past months.
Still also some small corrections but I am happy withe results.
In between sides I stopped for some diversion to work on the gunport lids and hinges, just as a test. But I am not satisfied. I have to find an easier method to make them in qty.
For now the work will stop a couple of weeks for holiday. The next step I decided to do the rudder anew. I made that in an too early stage and I want to improve it and more realistic. I just became more and more unhappy with it.
Edited by YankeeD
added picture
Just a short update. Its been very quiet and I haven't done much.
I have had surgery on my hand and that takes more time as expected. I also neglected to take it easy and that put me back again a couple of weeks.
Also the motivation is low. The weather is cold and bad and I need to go outside to the shed.So I guess it will be untill next year before I will continue. Don't worry I'll be back :)!
Hans
sorry to hear that recovery is slow.   take care and let your hand heal........much more important ;)    looking forward to your continuance of this wonderful project.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hans, I just spent my lunch break reading through your build log and wow!! A very educational build indeed. Sorry to hear about your surgery and setbacks on recovery. Hopefully, that will turn around for you and your hand will heal up correctly. I look forward to watching you continue your work once you are healed and the weather is nicer.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Let it heal and don't push it, Hans.  Continue only when the doctor says you can.
Marvelous work Hans and take care of your health.
See you next year and have a great holiday season.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Hi all, (do not want to be gender specific....;))
I have returned to the hobby again after a full recovery of my hand. Thanks for all the good whishes.
Just waiting to get the right hand done, but that will be spring somewhere. not just yet...
I have started redoing the rudder as said. I am using mainly the method used by Drazen (Thanks for that!) I think the photo's are mostly self explanatory. Its a slow learning curve but I like it very much although progress is slow.
I made the rudded out of seperate parts of wood, taking care of the grain direction as to prevent as much as possible deformation. And I decided to do the hinges also from scratch. Previously I used Amati hinges.
In the background the Amati hinges from the previous rudder.
I had a big problem blackening the parts. I left them much too long in the solution and 2 were totally 'eaten' away. I did 4 pieces again.
I on purpose made the bolting a little out of line. I like the looking of this.
And now up to the counter part. I hope to finish today.
Edited by YankeeD
typos
Nice work on the rudder and hinges Hans.  Yes, Drazen's work is also great.  I have been following him as well. Why? you may ask - - - I love these Dutch ships!
Cheers,
                       VOC Ship Surabaya
I finished the rudder. I am really satisfied with it. I will not fasten i yet. Only in a later stage, just to prevent damages.
In the meantime we have advanced. I build a new clamping/workboard. As there is no longer need to hang the ship upside down and I want free space to work all around the ship.
The next steps are working gradually upwards now. I have to finish everything around the main gundeck before I can close the next deck.
A test with a 3D printed model of the emblem
Filling the gap to be able to add the planking
Then the gunport rabbits and hatches
Rabbit sanded to follow the hull.
And so far for the port side, now on to starboard side.1384331096_20190326_151256(Custom).thumb.jpg.39ded5a46081ec1511c66250f94afbc5.jpg
More than a month ago so maybe time to give an update. Steadily working through the gunport hatches, a tedious and boring job.
Fitting all in place..519701535_20190409_145010(Custom).thumb.jpg.55eba5d287885b9ea89ec3c91ee2d060.jpg
Working the hatches into place and adding the gunwale parts.523697745_20190412_160422(Custom).thumb.jpg.d6d09437692826fa483cbfdde3bcc4bb.jpg
But I am happy with the looks. Not too tight and perfect. I like it that way, as I am sure ships in those days weren't neither.1928273355_20190424_152117(Custom).thumb.jpg.4fd4fdf635567555ec9078b185141fe9.jpg
Then the insides grounding.
And I still like how it came about.. The next steps will be finishing the maingun deck so I added some loose parts that I build earlier for the looks. I guess any builder wants to see how it will look and cant wait to see the whole....??
Also I will be doing the final masts at least first parts, as I have been using too short counterfits. Below the right lenght cuttings ready for working on them. This I will do first as I will be happy to turn from the monotonous work of the gunports.
(Please ignore the deformation of the mobile lens.. it gives some strange angles here and there)1348740264_20190507_172319(Custom).thumb.jpg.37c61fb193406c548fa728eec8b7e3b7.jpg
Another month passed by so time for another update. Not much has happened as we were out to the sun for a couple of weeks.
As said I continued with the masts, below the 3 masts are the final masts outlined and all..
This was quite some ado to get them in the right angels in both directions... langscheeps and dwarsscheep... (Longship and sideships???)
Next step the ezelshoofd and hommer, the pictures speak for itself but there was some mindbraking involved to get what I liked.
As the mast were too long form mu turning device  I had to invent a workabout...
778138911_20190603_152621(Custom).thumb.jpg.7868fbc390d4a09fbd489dfdb0759563.jpg269096706_20190603_160626(Custom).thumb.jpg.3ee82685b7b5b8464ea5356a69cf8e7e.jpg
Very nice work Hans !!
a beautiful build...
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful work indeed.
-E.J.
catching up on your build.......so glad to see your feeling better!  I love the wood your using........stained or clear coated,  the grain is gonna POP! :)
great job on the rudder and the gun ports are awesome.  it will be good to see her totally planked
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
July, and the weather keeps good here, too good to be really busy. But some progress was made. I proceeded with the main mast, cap and top and also the formast. I enjoyed making the top (mars). I needed some workabouts to get the nice round sphere.
Fine tuning the size and shape.
here the hings holding the outer ring are still too bulky, I sanded them into a smaller outline by hand.
As you can se here. and the outer is glued and hold fast for drying by some tie wraps.
Coated and dry fit on the mast
The status as per today. Now the top for the foremast.
Also some experimenting with oil colour for the hull and decks. The smaller parts like masts gratings ornaments will be in 'beits' the colour as per previous picture.
Very nice work Hans.
Cheers,
                       VOC Ship Surabaya
1 hour ago, G.L. said:
Very nice maintop.
Is that oil paint for artist painters that you use to make your color?
Yes indeed. And I dilute it with pure white spirit. Learned in another thread here and on some other forum.
August. Not much progress, the weather keeps nice and warm so few hours to spend and also low motivation.
Finished the foremast and mars, same procedures used as foir the main mast.
Then I worked the planking up to the rahout. I am now going to find a way to get (router??) the right profile for the Rahout.
Not easy as it will be 5-6mm by 2,5 to 3 mm.
I really have to build something here and make my own router bit.... Not easy
September. As said working on the Rahout and getting the right routerbit. I offered a proxxon bit for this, diamond sanding it to the right profile.
20190816_151459 (Custom).jpg505360706_20190814_151521(Custom).thumb.jpg.73fc1941e80b7577a678920bee5b7914.jpg
This got me the right profile. I used walnut and not oak. I tried oak but that was to coarse to get a nice profile.
Finished fitting them.
Later on the difference in colour from the wallnut will dissappear after colouring.
Then the kaapstaander. I will now finish all the parts of this gundeck so that as I start on the next deck this one can be fully fitted. Although I have not yet decided on guns.
I am thinking to leave this deck with closed gunhatches and only fit gund where you can see them whole.
Rounding the squares pole was not always succesfull...
Edited by YankeeD
Beautiful work, nice progress.
Cheers,
                       VOC Ship Surabaya
