Restoration of Bassett Lowke "Albertic" by michael mott - FINISHED - Scale 1:100
This image from Vallejogallery shows an obvious change or repair. if you look at the shrouds you can see the new brighter wire.
I have been doing some further tests with the new brass wire.
the top and bottom cables are from the aft funnel the second cable from the bottom is as close as I have come yet to replicating the Bassett Lowke cables it is made from
a) 4 sets of 34 gauge non tarnishing brass colored wire
B) each set is 15 inches long twisted with 80 turns clockwise
c) the 4 sets are then combined and twisted with 50 turn anticlockwise
The second cable from the top is made from 3 lengths of 28 gauge brass non tarnishing brass wire wound clockwise 80 turns and given a smear of brown Pebeo Vitrail stain for colored glass, I dipped the wire then immediately wiped it off once with a tissue it leaves an tinted aged look to the brass.
Michael
Link to comment
Share on other sites
Michael, suggest you label each trial cable so you can duplicate it later on.  I've got several small coils of rigging line labeled for number of strands of what initial size, just in case.  3 X 4 of .008  or # 5 linen, or whatever.
Link to comment
Would gentle heating of the wire 'tint' it?
Druxey that was a brilliant Idea.
I got up this morning and while waiting for the kettle to boil, I laid a length of assembled cable on the ceramic top of our kitchen stove set the burner to low and watched the heat cycle on and off as it does after about 5 cycles the wire did in fact turn a tint of a more aged look.
top-untreated
middle-heated
bottom-off the ship
The photograph shows the effect clearly, now it just becomes a matter of adjusting the timing.
Carl as noted above the heat works well and is a lot less messy than any form of dipping or coating.
Thank you very much gentlemen for your suggestions.
Michael
Link to comment
I have a hot-air soldering gun that I use for this purpose. One can set the desired temperature,
Wefalck can you provide details of your tool, manufacturer etc?
Michael
Link to comment
Michael, looks like you have a winner.  Well done.
Bob
Current build:  SS_ Mariefred
Link to comment
it will even hold the 'twist' better .............definitely a super idea  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks for all the positive comments and feedback.
I am now satisfied with the color and the lay of the wire to match the Bassett Lowke cables
This is the final lay up
And how I achieved it first wind up the 4 sets of 3 in clockwise direction
next set the wound sets onto the hook
then wind up the set of 4 anti clockwise
These beginning lengths of 15 inches shrink down to 12 inches of usable cable for the funnels, after the ends are snipped off.
There are only 2 aft mast shrouds that need replacing, so I will need to make a couple of longer lengths for those.
Michael
Link to comment
Michael, I fished it out of Chinese waters from the well-known bay. Not sure, who the manufacturer are. Here is an identical example:
These hot-air soldering stations are used for what is called SMD (Surface Mount Device) soldering of circuit boards. You can get them for around 60 USD/EUR and they have temperature range of 100°C to 450°C. Apart from soldering, of course, I use mine e.g. for blueing and tempering small steel parts and for producing oxidation colours on other metals, such as brass and copper.
Edited by wefalck
Link to comment
Wefalck, thank you for this. I have not seen this type of tool before, I will definitely look into getting one.
Michael
Link to comment
Michael, I originally bought it with the idea of 'contactless' soft-soldering, i.e. that one does not need to touch delicate items set-up for soldering, but now use it for all sorts of heating purposes. I even use it a full power to heat up bigger items for hard-soldering and hardening before going at them with my gas soldering-torch. Saves on gas and allows more even heating.
Link to comment
No, had no need (yet), but I think it would be good for such things as well. As the lowest temperature is 100°C it could be also used (judisciously) for heating plastics for bending. I also use it for loosening they stuck lids of paint tins, for heat-shrinking etc.
Link to comment
I had a look at the paint on the funnels today in the natural daylight, following Druxey's suggestion of cutting through the top layer(s) of paint this is what I found.
So some history is revealed, this is a guess.
Working up from the lowest layer which seems closer to the top color.
a-bottom original
b-middle possible smoke discolored or an off coloured repair, I am open for other opinions on this.
c-top a last repair working to match the original.
The top color is pretty close to the original but the person doing the repair looks like they used the same brush that they painted the fence in the back yard with.
And yes to be fair, initially I used a rather heavy sanding stick.
Michael
Edited by michael mott
Link to comment
Opinion? Strip all the paint and repaint (with airbrush!) to match the original color. Keep photographic record of these archaeological stratae to go with your treatment report. Overpainting yet again is not a pretty option.
Link to comment
perhaps a paint stripper might be better than sanding.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
The best possibility is acetone - ventilate well, please! Sanding is a bad idea as there are bands and rims on the funnel to deal with - lots of fine corners.
Link to comment
Yes and no. There could be some wood-filler underneath that would go with the acetone/paint-stripper, then requiring a big puttying and sanding job. I would try to remove all metal-work and then sand to a smooth finish. You then can spray-paint directly on the remaining paint. If you intend to use a solvent-based paint, you should also test for compatibility before spray-painting on the old paint.
Link to comment
Druxey this is the direction I was leaning in. I do have an airbrush, the funnel is entirely metal pretty much all brass.
I will after stripping give it a fine coat of Zinc Chromate primer before applying the colors. All of the stay eyes are through holes then bent on the inside so all of these will also be removed.
Would an air eraser be too aggressive?
Roger, I do not have an air eraser and do have acetone which on brass will work well enough and if it has difficulty with any of the paint I will use Lacquer thinner which I also have.
Thank you all for your suggestions and input, it really is helpful to hear your opinions and Ideas on this area.
Yesterday before we went into the city I glued up the boat deck.
After setting overnight I just removed the clamps to see the next milestone achieved.
An additional thank you to all who are visiting quietly it is encouraging to see the interest in this project.
Michael
Link to comment
This collective modelling brainstorm is a true joy to read! Thank you for sharing with that level of details!
Link to comment
looks great Michael!   the crack is virtually gone!   there are a couple small chunks missing.......how are you going to fill them?
this is such a huge undertaking........the interest in this alone is enormous!
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
