Hi everyones!
First of all I want to thank to Piet. His miniature diorama in some way inspired me to this mini project.
From time to time I have a desire to try their skills in the direction of further miniaturization of shipbuilding in bottles. Here, a short history of one of these small projects.
The flask with strange shapes, reminiscent of a heart with an asymmetrical arrangement of the neck, lying in a drawer of my desk for a long time, but I did not have any specific ideas for using it as a receptacle for the construction of a model in a bottle ... And then ... As always, the idea came unexpectedly - sea, rock, lighthouse, boat.
On this photo this flask is in the center
Choosing a boat and lighthouse prototypes came somehow by itself - I like this combination in a long time and I even tried to draw them.
So, I started this project with the building of boat. Based on the size of the interior space, the scale is around 1/3000.
I started to build a boat in almost the same technology as the rest of my models. First I made the deck from several small strips of pear, which I previously whittle away with sandpaper to 0.3 mm. The deck is also the basis for the above-water part of the body. Then I glued the boards of black hornbeam.
The nameplate ... I printed it on a printer, laminated tape and glued to 0.5 mm veneer. Then I made the frame from pear strips 0.5x0.5 mm and handled fine sandpaper.
Lighthouse ... I carved it out of bamboo and colored paint. Then I did the rock from epoksilin. I also cutted out parts of the pedestal from the pieces of pear.
I made the sea from two-component colorized silicone. This was my first attempt to use this material. I poured a few drops of the mixture in the bottle and after a few hours, when the mixture was a little dry, I put the hull of the boat in the sea.
After complete drying of the sea, I inserted the mast with folded front sail into the throat of bottle. Then I expand the front sail and glued its corner to the bowsprit.
Edited by IgorSky
sweet, sweet, Igor,
what was first, the shaped bottle (flacon), or the idea to find a mini bottle that fits a lighthouse ?
super work !
Nils
Current builds
-Lightship Elbe 1
Completed
Then I put the cork and sealed it. All - this model is complete! :)
Edited by IgorSky
sweet, sweet, Igor,
super work !
Nils
Thank you, Nils!
This bottle was me for a long time, but I did not know how to use it. :)
Well, Igor...just when I thought it couldn't possibly get any smaller, you come up with this teeny tiny beauty!!!
A little masterpiece!
Well done.
Cheers
Patrick
Many thanks, Patrick!
Each time, I also think that I has reached the limit... But then it turns out that we can go a bit further :)
What great use of an odd shaped bottle.  Your diorama is lovely.
Bob
Current build:  SS_ Mariefred
Unbelievable, Igor.  Your work is amazing.
Many thanks all who was enjoying this mini-project!
Subject of miniaturization long been interested in me. And gradually I am moving in this direction.
In the course of this project I had some new ideas that I will check later.
However, already a need to find other materials and other tools, other methods.
Thank you for your feedback, the words of encouragement and your interest!
Best Regards!
Igor.
Igor you are insane ;) What an amazing way to capture a sense of drama. The boat passing the lighthouse rocks nearby a shift in the wind all was ok.
Wonderful piece of modelwork.
