I continue with the paneling boards, paper templates again..
Surfaces created on the ribs..
Gluing with long-term glue D3, fitting takes a long time..
First board..🔥
I wish modelers all over the world a lot of peace and time to build models in the new year 2024. Ondras
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
I continue on the work boat. Bending workshop..
According to the paper templates, I create more rows of boards, the edges highlighted with graphite..
The third row already has an extreme side bend. After a good soaking, the 0.8x3.5 mm strips can be bent well, just persistence. Step one - side bend..:default_wallbash:
Step 2 - after drying, bend into the shape of the torso, then fit.. I will save material against carving from wood plates..👍
The last part, closing the bottom. Too small, the bottom will not be visible, I helped myself by assembling the moldings from two parts. Otherwise, it would not be possible to do it well..:default_wallbash:🔥
Ondras.
Another milestone behind me, the body of the boat finished, sanded and cut from the hoof with a razor saw..🔥💥
Again I used the option of dispersion glue. The sunken place on the bow after removal is wetted and pushed from the inside into the correct place..:Whew:
A preview of the boat on the ship's deck..😍
Now clean the ribs and arrange.🔥
Ondras.
Beautiful work!
hamilton
On 1/9/2024 at 9:52 PM, hamilton said:
Beautiful work!
hamilton
5 hours ago, Theodosius said:
Masterclass!
3 hours ago, Rock_From_Korea said:
Looks amazing!
Thank you friends, your interest pleases me and moves me forward.:imNotWorthy:
Ondras.
I continue on the boat..🔥
I found beautiful photos of the Willem Barentsz boat replica. On the website of the modeler Heinrich. shipsofscale.com/sosforums/threads/high-hopes-wild-men-and-the-devil’s-jaw-willem-barentsz-kolderstok-1-50.8662/page-100
The tops of the ribs have been cleaned, the ribs have been cleaned inside, the top edge has been ground flat..
brouenvnitnchtn.JPG.e101ec75441642ec4b4f4b0879ccc82b.JPGbrouenhornhrany.JPG.7fb0246dbd42d0616f07f27a7ab21d33.JPG
Completed the last rib and bottom of the boat..
frzovnzadnhodna.JPG.b2501edce8cbebf5d85c394de291a3f1.JPGzadndnolunu(1).thumb.JPG.331f8dfc58ddc4dda529db370b21a03e.JPG
Outer hull and bottom of boat waxed..🎨
navoskovantlolunu.thumb.JPG.7091ef4cf7ed2667e8b5a2c0299cf72a.JPGnavoskovandnolunu(1).thumb.JPG.9a19987f873788c2e0aab449af2234f1.JPG
Now the railings and benches..🔥💥
Edited by Ondras71
Ondras.
On 1/14/2024 at 12:54 PM, Baker said:
Amazing
Home made saw?? 😉
Yes Patrick. A tool created from a shard of a razor saw. I enjoy creating tools that won't damage the finished ship!🔥💥
Ondras.
boat: bench and railing...
It's only 10.3 cm...:default_wallbash:
Now for accessories...🔥
For those interested in a competition or model exhibition : https://wchs-c-2023.eu/en/news/id:11798/czech-championship-of-section-c-2024
Edited by Ondras71
Ondras.
The boat is ready, just the rudder and place it on the ship...🔥
The 1:60 scale is still demanding on details..:default_wallbash:
Ondras.
Dne 2. 2. 2024 v 18:11 ccoyle řekl:
Nádherný!
Dne 3. 2. 2024 v 16:21 Hubacův historik řekl:
Naprosto mistrovské, Ondrasi! Loď vaší lodi je sama o sobě v jemném měřítku!
Děkuji moc přátelé, děkuji za další lajky.😍
Kormidlo hotovo..🔥
Loď vypadá na palubě dobře..
Udělám stojan a pevně postavím loď...💥
Edited by Ondras71
repair
Ondras.
On 2/18/2024 at 10:31 PM, FriedClams said:
Fantastic work on that boat, Ondras!  Beautiful!
Gary
On 2/19/2024 at 1:37 AM, JFMJr said:
For a first time builder.. and new to this site...this looks amazing... awesome..
Thank you very much friends. thank you for the like.:imNotWorthy:
I'm continuing with the rotating chamber cannons on the railing, luckily there will only be four.
I found the current cannon in a book by Ab Hoving: Het Schip Van Wilem Barents and painted it.
Then the turning began. It is very small against already created cannons.
Created pockets for exchange chambers.
Of course, you need to start making a larger number, they slowly decrease during the work..:default_wallbash:
Added chambers..
Result OK..:Whew:
Ondras.
I finished the swivel cannons on the railing.💥
I created new smaller chambers..
After blackening..
The last visible detail, the chamber pins..
The last parts of the hull, chamber guns, placed..
And now I can rush to the rigging!!🔥
Ondras.
On 3/18/2024 at 8:31 PM, Baker said:
Very nice swivels, great work.
On 3/20/2024 at 12:03 AM, cbill said:
It's remarkable work.
I have never seen swivel guns with so much detail and so well done, congratulations.
Thank you very much friends, I am trying my best..😁
Finally the main lower parts of the masts..🔥
Temporary direction signs created for exact machining directions..
The tops are machined and holes drilled for the location of the lower tie-down points..
Finished lower parts of the masts..
(Manual dividing device)
Done..💥
Now tops and topmasts..🔥
Ondras.
I modified my lathe to clamp long sections of masts..🔥
Production of topmasts has started..
Add some details and I can start assembling..💥
Ondras.
Mast parts done. Topmasts supplemented with pulleys..
Making basket supports called Mast Cheeks. Again processing the glued and then soaked parts..
I have already reached model height..💥
Ondras.
Good day Ondras,
Lovely model and hjgh level craftmenship !!!
Like it very , very much!!!
Could it be happened  that designed "masts" happened to be  too small ( kind of proportional issue) for the size of the hull ?
of couse it is just my private opinion /impression after watching photo of your build log , I understood that everything made as per original  drawing , but... :)))
All the best!
ps
Could it be played in some comp. drawing programms , how general rigging plan  will be ooks like , if  masts , top- masts , etc...all will be  increased in length of  approx 5 to 10 % of original drawing size ?
Edited by kirill4
20 hours ago, kirill4 said:
Good day Ondras,
All the best!
ps
Greetings Kirill. Thank you very much for your response, you hit the spot where I was wondering about mast height. I calculated the masts according to the table in the book "Mondfeld - Historic Ship Models" and the dimensions fit the plan.
However, the lower parts (main mast, fore mast, mizen mast) still seemed short to me. I compared the masts with the masts according to the Zeehaen plan and they turned out to be about 10 percent longer. So the masts are raised.
The Main yard and Fore yard locations will now sit as well..🔥
Ondras.
Good day Ondras,
Now overall appearance looks much more proportional!
Nice job... follow your building with great interest!
All the Best!
Kirill
