I am really enjoying all the detail you are doing.
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
Hi Popeye, I've been wanting one for a long time, and procrastinated about getting it, finally broke down and ordered one....hopefully I can get some decent dowels out of it......
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Augie, the Tryworks is all brick and metal work......panic is striking......gotta build a sink type cauldron, and a brick firebox....of fun......that is why I went aft to build the Hurricane House, and everything that works forward  so I could see progress before getting tied down to the Tryworks...about time to pay the Piper....
John
Hi Lawrence, I haven't taken a break because I haven't started them yet.....excuse is waiting on my Byrne's Drawplate.....
John
Thanks Grant.....
John
Thanks Scott, it's the little details on these things that set them apart.  This group of guys on these builds demand and expect it....Kidding, but of course it does seem to prompt this......keeps me trying to perfect things.......
John
Well, one thing about waiting for something in the mail, is that you get to do a lot of fiddly little stuff.  So, today I made 2 bits, a small ladder, added bucket hangers, made the anchor chain pipes, cut and trimmed the anchor chains and wrapped them around the windlass and back to the anchor chain pipes for stowage below decks.  Next I have been studying the dreaded Tryworks.  I started with the foundation framing for the Tryworks which is where I am right now.  The anchor chain is larger than the kit chains, so I couldn't use the cast Brittania parts that came from MS.  I took a dowel, and drilled a hole in it, then filed it to where the walls were thin, yet allowed the chain to go through it.  Tedious in that I had to drill them by hand, cut with a razor saw without breaking them....same for the frames.....needless to say this took quite a lot of time....and about 8 trys before I got it done.  I'm not sure what I'm going to do when the drawplate arrives...I guess I'll stop and make enough harpoons and lances to fit in the racks under the Shelter Roof, then put on the roof and then come back to the Tryworks.
John
These are pictures on deck withe the anchor chains
John
Here is a couple of overall shots
John
Still overviews
John
Starting the Tryworks....
John
wonderful progress John........interested to see what the tryworks is all about
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Admiral Augie.....the details have been fun, and it does start adding some life to it...more to come....
John
Hi Popeye, thanks for the comments.  This is my third attempt to post this one.  The last two times I got the text of what I wanted to say and when I went to download pictures AOL lost everything and rebooted....this happens more than I  like.   So, I will try again.  The Tryworks is actually an onboard Whale Oil Refinery.  It consists of a Fire Brick Oven with two cauldrons built in over the fire.  When a whale is being processed, the blubber is cooked in the cauldrons, there is a workbench for cutting up the pieces, a bench vice, a stone grinding wheel, and then the oil goes into a cooling tank and then into wood barrels to be stowed down below in the holds.  Then the scraps go into a copper scrap bin to be discarded later.  There is also a Duck Pen as part of it.  This is where the masonary "hat" comes into play.  As I have said before, it's amazing how many skills or trades we incorporate into these things.  Masonry, welding, and soldering hats will be utilized for this one.  Here are some pictures of the real one onboard the Morgan in Mystic.
John
John,
Nice update. I note that you really get around and have visited several ships, very nice. Good for you. One day I need to get to the East coast, several ships that must be great to board.
Michael
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
thanks John........that brick is going to be tough to mimic.   look in model train layout supplies to see if they have anything like this....either a paper or wood texture.   look forward seeing this develop :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
It does indeed. Check your scale however. It is tricky to get the 'just right' look. The sheets are formed in brick red color and you wash in the gray mortar paint for the total brick wall effect. Maybe it was my technique but I was not very happy with these results on my build - I was going to use brick for the camboose floor but shifted away for 2 reasons: 1) with research it appeared to be a floor of lead or weathered copper and 2) I failed to achieve the brick effect described.
Hello Dave and Popeye,   I just thought I would share with you what I decided to do.  I have been researching this for some time now knowing what I was instore for.  I've looked at the Evergreen bricks, model railroad bricks and several others.  None would be right especiall in scale and effect.  So I decided to make my own bricks and lay them like real ones.  I've done this in real life before, and surprised myself.  That's what I mean about different hats depending on the job.  So I build the framework, cut about 300 bricks from 1mm x 2 mm stock at 5mm lengths using a jig and my Amati Chopper.  Then using a Miller Lite box, I cut thin strips of cardboard to use for mortar.  It is .65mm thick.  I will then fill in the areas between the brick ends to create the affect I want.  I'll then paint the mortar areas white, and then the bricks I'll paint a flat red.  I'm using copper strip to frame the doors, and I'll construct the cooktop from copper sheet.  Here's how it looks right now as I build the brick oven.  Thanks for all your suggestions, I greatly appreciate it.  This is probably just an area you just have to make from scratch......hmmm, I hate to use that word around here.....
John
Still a couple of more to show progess
Edited by texxn5
John
and the up to date ones
John
Hey John,
Oooooooooh - - - scratche-ing!!!!   The dark side is calling, calling, calling calling.  Hear the siren song John????  ;)  ;)
That looks really terrif!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
ohhhhhhhh........what your dooooiiiiinnnnngggg.    I thought I could hear a thud behind me.......off in the darkness
the base looks good.......are you going to be standing the bricks on their sides now?  what are you going to use to simulate the mortar?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
John,
You might try painting your bricks and mortar before gluing them in so there's no bleed over.   Once glued, weather.   As always, test first.  ;)
Ah yes.. I sense it.. the force is strong in this one. The darkside has cookies... post-76-0-37696500-1386381494.gif
John........I had an idea for getting 'texture' in your bricks.  If you have a hobby store nearby, they sell a thing called 'Microballoons'.  It's a colloidal (very fine) grade of silicon dioxide (sand).  It's white and fluffy.  We mix it with epoxy to make a workable paste for certain aircraft applications.  I was thinking of mixing some in my paint to give it a stone-like texture.  Haven't tried it yet.  I know it will thicken the paint as you add it so you would need to thin it out quite a bit.
Just a thought.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Popeye, yeah man, I already started while I await the mail...thanks for the input though.  The bricks are pretty much to scale, and they lay just like real bricks.  The mortar is cardboard strips about 3/16" wide set back away from the front edges of the previously laid row of bricks, then it just progresses upwards one row at a time.  I'll probably use MS's primer paint to fill the gapsbetween the bricks, since I can't get cardboard inbetween them real easy.  Then I'll paint the white and flat red colors.  I'm pleased so far, just tedious getting everything straight without the levels and string battens you would use if laying real bricks....
John
Hi Mark, I had thought about pre painting all of this but I don't know yet......I've started a couple of rows of bricks, and will experiment with a couple of areas before I move too far along.  The lower levels won't show as much so it's a good place to play.  Some of the sides and back will be covered with wood once the brickwork is finished.  The real pictures above show the sides as she is now, and as all references show.  Thanks for the advice, and I'll see how it works out.....emmmmm, I love cookies.....especially with ice cream.....like maybe "Cookies & Cream".......darkside temptations.....
John
Hi Augie, yeah, I'm familiar with that product.  I think it's used in model Railroads too.  At 1 mm thick I don't know if it would show that much or look much different than the Flat Red paint.....I'll be playing with it.  Good idea though, but I have to drive about 15 miles to the nearest hobby shop which is Hobby Lobby...It's 33 degrees here all day so I'm not going to be getting out.....this is your kind of weather....too early for us.  If it doesn't get to 45 it wil break a record that is over 105 years old.......brrrrrrrr.......
John
