Amazing job! Your post answered all the questions I had. Emma C is my first  true plank on frame build . I just  laid the keel and assembled the building jig. The main question I have is beveling the frames. I don't like Model Shipway's approach, and tried there way on there Bluenose kit and I didn't like the out come.
I used to live in Mystic Ct, ( early 90's) and would see Emma C. floating at her mooring, when I headed up the Mystic river to go chase Bass and Bluefish.
  • 3 months later...
Despite many other projects going on, I could not help but work a little bit on the model. Not much progress done, but I almost completed the bowsprit:
Twelve gaskets were installed to help fold the genoa (or gib):
The bowsprit bands are made with the supplied brass strips, soldered and carefully drilled with a 0.5 mm drill.
All painting is done with acrylic paint, diluted and brushed in many coats. The black is Black Gesso which is used to prime canvas with a black background and which presents the fantastic property to be very easy to brush and to have a perfect finish. in my opinion, it is the perfect way to finish whales and other black surfaces on a model ship.
Yves
The bowsprit looks good, Yves. Looking forward to when I can get the new shipyard set up!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Dirk,
Thanks for your kindness. I really appreciate your Syren and will use your Build Log when I start the kit which is sitting in my closet.
Yves
Wow!  What a great job!  Keep up the good work.   :)
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Yves - that bowsprit is just another example of your fine work.  I am fascinated by some of the hardware shown here and the general shape of the spar.  Keep up the good work!
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
  • 5 weeks later...
Don and Yves,
Regarding your transom questions, I had the opportunity to take several photos of the real Emma a month or so ago, maybe they will help?
http://modelshipworld.com/index.php?/topic/3221-emma-c-berry-photos-at-mystic-seaport-2013/
cheers
  • 2 years later...
Lawrence,
Thanks for the kind words. Yes, these framed ships are a regal to build and I need to get back to work on mine.
It is still standing in the same condition as the last picture published on the Blog.... which is pretty sad.
Personal issues in my life have not allowed me to make any progress, plus I am pursuing too many other projects at the same time.
I think I am going to try to get in the groove and resume the building of this lovely ship.
Yves
Edited by yvesvidal
After a long hiatus, some updates.
Since it may be a while before I have time to work on the boat itself, I told myself that at least the structure should be displayed. With that objective in mind, I decided to build a base that will present the model as it is today. Having the model on display (rather than a box) may motivate me to proceed with the build.
The base is made of two pieces of pine glued together. The overall size is 30 inches by 7 inches. The base is painted with black acrylic Gesso which is a wonderful medium to obtain a silky and very uniform appearance without too much sanding and painting. Ultimately, this base will be covered with fine dirt and I may turn it into a diorama as suggested by the Model Shipways cover picture.
http://imageshack.com/a/img633/2826/tQALl3.jpg
Since the shipyard uses leftovers from a nearby railroad company, the boat will sit on massive pieces of wood and railroad ties. The ties are made of 1/4" x 1/4" basswood (provided in the kit) and I have used miniature spikes in the scale of 1/32nd to secure the pieces of wood to the base and the pieces between themselves. The basswood is stained before assembly using the Brown Micro-Mark Age-it-easy fluid. The spike are driven into the basswood using a special spike pliers/driver and finished with a small hammer. Without the spiker tool (also available from Micro mark/Xuron), it is very difficult and almost impossible to drive correctly the spike into the hard wood.
http://imageshack.com/a/img903/989/riMfCI.jpg
The result is not too bad and will allow this base to sit in a glass enclosure, if I ever finish the model.
http://imageshack.com/a/img633/6307/79iNtZ.jpg
The boat sits gracefully on top of its Building Ways. My next little project will be to fabricate the lateral stands to stabilize the hull.
http://imageshack.com/a/img633/29/ccbtwf.jpg
Yves
Edited by yvesvidal
Yves,
I don't know if it's at my end or not, but none of the pictures are showing up on your post...I see pics on all others.
Maury
Hi Yves, I just discovered your build, Very nice, She's looking good, I will have to follow along
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Hi Yves, You are very kind, it was nice to see the picture, I had to show it to Kate, she loved it and likes your house.
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
  • 1 year later...
Hi Yves,
Emma C. Berry will be my next build after I finish my Benjamin Latham.
Have you made any progress since your last post?
Cheers
Stephan
Current Build: Hesper (kind of on hold), Wide A Wake
Completed Builds: Benjamin W. Latham, Le Renard, Smuggler, Bluenose, Pride of Baltimore, Alexandra, Jolie Brise, Marie Jeanne -1 and Marie Jeanne -2
  • 3 years later...
I realized that this thread has been idle for the past seven years..... 😴
Now that the Type VIIc submarine is almost completed, it may be time to resurrect this build log and do a smooth transition away from polystyrene and resin to the good old Basswood wood construction. Besides, there are not too many Emma C. Berry on this forum and this lovely fishing boat deserves more fame.
Yves
I just read through your build log, Yves, and I'm really happy to see that you've decided to continue with building this wonderful model. Seeing your excellent work so far has made me think that this model should be on my tick list as well. I'm looking forward to following along.
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Just a couple of pictures to situate where we are at this stage, of what is called End of Phase 1. The hull has been entirely framed and the covering board have been installed.
The texture of the basswood is really unctuous and I hope I will not make a disaster when planking it:
The scale of 1/32 makes for a nice and beefy model.
Here, you can see the famous well used to keep the fish fresh and alive, until the boat can be returned to the harbor. The hull has been "faired" but I will get back to it, before laying the first planks. I have never planked a hull, so this will be a new experience for me.
In parallel to the nice set of instructions and plans provided by Model Shipways, I also purchased that little booklet that tells about the restoration of the Smack Emma Berry in Mystic Seaport. That book is illustrated of hand drawn sketch which are very well done. I may publish a couple, as we go along.
Yves
The large scale will certainly make for an impressive model. I didn't realize it was that large.
Bob Garcia
Current Builds:
Nice to see you back at this model Yves. This is another that I have in my way too big stash. I’ll enjoy following along with your build.
I never knew Model Shipways had a plank on frame kit until I stumbled upon this log. I'll watch with interest. This is a model I might be getting sometime in the near future 😁
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
5 hours ago, Blue Ensign said:
As I'm currently into fishing boats Yves, I will follow your build continuation with interest.
She looks really good as you have her currently displayed, standing in frame only, and what an elegant setting.
Regards,
B.E.
Thank you Blue Ensign. I am an ardent supporter and admirer of your fishing vessels build logs and really enjoy what you are doing. It may be a while before I resume the Emma Build, but we will get there.
Yves
After many years of hiatus, I have decided to resurrect this Build log. I must confess that I have never planked a hull on frames (or bulkheads for that matter) and that prospect was blocking me from making any progress. But like many enthusiasts, until you try planking you will never know the ultimate satisfaction of wood ship building.
So, there we go, working on the "C" belt, as recommended by the instructions:
4 down.... 8 to go on the "C" belt.
Yves
I believe it is coming to no surprise for the members of this forum, but I am starting to like planking that hull. Very refreshing and relatively easy. Alsmot meditative in essence. Eight planks down and four more to go, for the "C" belt:
The planks are glued on the frames, with CA glue. Later on, I brush a mixture of white wood glue thinned in warm water to penetrate the basswood and allow some kind of adhesion between the planks. After some light sanding, the planks regain their soft and smooth surface.
Yves
Edited by yvesvidal
