Eberhard, I can remember what it looked like and I am pretty sure that it wasn't made by Rolls Royce. I don't remember the make but I did try t look up the training centre on the web to see if i could find out what happened to it. Unfortunately I drew a blank. I do intend trying again.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you all for your comments and likes.
I am moving on by going back to the masts, booms and spars which were only partially completed earlier. They have all sorts of fitting and attachments which need to be made and installed before I get on to the sails.
I am starting with the main boom. You can see in the following photographs the blocks and strops.
Do health and safety at work regulations apply to yachts?
992320476_Screenshot2021-03-12at21_49_51.thumb.png.ae097d881881642e54044ffea1694efa.png
The rudimentary plans downloaded from the internet adequately define the attachment points
DSC01339.thumb.JPG.f5b340a8c0031d029be3a582c65f6393.JPGThese were marked on to the boom (on top of a piece of masking tape.
DSC01337.thumb.JPG.db0b6760221c4187e91bad9aced212f1.JPGThe blocks attach to the strops via brackets. These were probably forged from plate on the original. They are a bit small at model scale and so I decided to fabricate them.
I started with 2 squares of brass sheet drilled with a central hole and 2 other smaller holes.
The squares were turned circular. and a spacer was made.
The 3 parts were assembles and soldered on an aluminium alignment mandrel.
DSC01896.thumb.JPG.178549fa55f6f8d7310c61ef39c40a68.JPGI then made a filing button and used this to profile the outer shape.
Two brackets were then cut from the profiled shape.
The wire strops were then made from beading wire.
I spent a lot of time making blocks in 3 sizes and with single double and triple sheaves.
DSC01930.thumb.JPG.c4a07b5f2d6e99a72f03c18bf30b7e66.JPGSingle blocks were attached to the strops via the brackets.
Two further single blocks were attached.
DSC01910.thumb.JPG.034327f72d85ec58884ebc2ed32bdadf.JPGI am not sure what the purpose is of the long strops running fore and aft are, but these were added.
Much more to do.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Just catching up Keith and you have been busy.  Beautiful work as always - every bit of it.  That photo of the cabin is really cool.  It has a nostalgic feel to it, especially with the out of focus foreground.  That’s a keeper.
Gary
Completed Scratch Builds
Ditto above comments; just when you think it can't get better than....  well, you continue to provide such lovely detailed fittings.
cheers
Pat
Ah RR-apprentice at work - love this filing-button work, that shows the toolmaking approach.
I could think of two uses for these strops at the end of the boom: either they are some sort of footropes (well HSE rules apply, when you have a professional crew, but it may depend on the country of registration) or they are sort of bridles to grab and help the boom shift, when going through the wind.
14 hours ago, Bedford said:
How were the wire strops covered to protect the wood work,
Hello Steve
They have a very closely fitted leather covering.
1419301124_Screenshot2022-08-04at12_46_18.thumb.png.022fc23dadd50e2a05fce2f8c3c1125e.png
It is a bit too closely fitted for me to reproduce neatly.
Eberhard / Steve. I think the foot rope idea seems sensible. Given the mass and height of the boom I think that flicking it across would be better managed via the sheets and winches.
Gary, Druxey, John, Pat, Eberhard and Steve - thank you all once more for your supportive comments
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Amazing work as always Kieth. I’m still baffled at how you can keep hold of such tiny parts. You must have sticky hands, or is there something you’re not telling us. Personally, if I were working on pieces that small, the floor gods would be rich from all the parts I would have sacrificed.😁
-Brian
Current Builds:        Completed Builds:
Mississippi River Towboat Caroline N.                                                    HMB Endeavor: Artesania Latina
        USS Constitution - Cross Section: Mamoli
Non-Ship Builds:        HMS Victory - Cross Section: Corel
New Shipyard        King of the Mississippi - Steamboat: Artesania Latina
        Battle Station Section: Panart (Gallery)
In Dry-dock        Chaperon - 1884 Steamer: Model Shipways
USS Constellation: Aretesania Latina                                                       USS Cairo - 1862 Ironclad: Scratch Build
Flying Fish: Model Shipways
Brian - Eberhard is probably the expert. Watchmakers have a cloth on the bench that attaches to a chord around their neck. I just trust to luck and make a few spares. Thank you for your kind remarks.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Here is a better photo. Given the strops start level with the transome I think the foot rope idea makes the most sense.
Unfortunately they were not great at safety. One young crew member fell to her death while working aloft in March 2017.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
1 hour ago, Roger Pellett said:
real cat’s cradle!
Hi Roger - yes - not quite sure why they couldn't find a more aesthetic solution.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Today I had a big productive workshop plan. Then this arrived and insisted on helping.
She said that she needed to do her work so we did a bit of nailing practice (see hammer and wood block). Then we learned masking taping before progressing on to drawing boats. I have high hopes that she is destined to become a ship modeller. Needless to say I didn't get much done.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I disagree with not getting much done.  Her expression says it all.
Funny, both of my granddaughters love to help out when they come over and I’m in the shipyard. I’ll give them a piece of wood and some sandpaper and let hem go to town. Tickles them pink and warms my heart.
-Brian
Wonderful Brian, I hadn’t thought of sanding practice.
I obviously missed the “training productivity” aspect of her visit, thanks to all of you for pointing it out.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Is that Splodge? I remember you hanging a much younger photo of her below deck. What a precious child, you're a very lucky man, Mr Keith.
Edited by Keith Black
Keith, I had assumed a snug leather covering on the strops and of course that's impossible to recreate at this scale, have you considered just painting them in a suitable colour? A few heavy coats would pass for leather to a blind man on a galloping horse.
Keith, can you get heat shrink of this small a diameter (and right colour)?  Might make life a little easier for simulating the wire coverings.
I love that photo of your helper (dockyard assistant) - looks like she is well on her way to lofting plans ;)   Hopefully I can encourage both my granddaughters to help :)
cheers
Pat
Edited by BANYAN
Watchmakers and jewellers indeed use aprons. Watchmakers generally use cloth, while those of jewellers are made from leather. The latter clip to the underside of their workbenches, so that they can recover precious metal filings. It also protects them when silver-soldering.
I have been wearing aprons in the workshop for decades. However, I found that small pieces mostly either bounce off, or just drop besides ...
19 hours ago, Keith Black said:
Is that Splodge?
Well remembered Keith, indeed it is, although she hasn't been called Splodge for a while now. At nursery school they all use her given name of Eve but in the family she answers to Bean. I think "Bean" will stick with her forever.
Her mum brought her to the workshop to show her Germania. I pointed out the picture of Maisie (the Dalmatian) in the porthole and I removed the deck house to show her the picture of Bean. She then rushed back to the lounge and reappeared with Nanny to show her the pictures. It was after this that she decided to stay and do her work.
Steve I will do a test piece. My guess is that acrylics will flake and enamels will form beads. The wire is covered with clear plastic (which looks and feels a bit like nylon) and i am dubious about the adhesion.
Pat - Yes you can get small bore heat shrink. The wire is .020" diameter and the problem is that small bore heat shrink seems to have a reasonable wall thickness. It more than doubles the diameter of the strops and this makes them look unnaturally heavy.
Thank you Eberhard for the apron explanation.
Thank you all for the nice Bean comments - unfortunately she is not for sale.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
The clear plastic on the wire is a problem.  I'm not sure if there's a chemical way to remove and burning it off would be nasty.
 Acetone should remove the wire's plastic coating.
Mark - it burns off quite nicely. You set fire to one end and then it burns almost like a fuse. It does create a molten blob so the trick is to blow out the flame and then quickly draw the wire between the thumb and fore finger to remove the blob. Then you utter an expletive and remember next time to wear your gloves. The problem is the burning discolours the wire strands in a way that isn't easily rectified. Really you need the wire to retain its shiny stainless steel look.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
