This morning I did the radical re-do without any problems.
Removed the necessary planks and frames.
Sanded everything and glued in the frames.
Glued in the planking and for extra strength, drilled hole through plank and frame and hammered in a toothpick.
Tomorrow I will sand lightly on the outside, add some more frames to the area and make sure there are no more drastic re-do's.
Marcus
Current Built: Zeehaen 1639, Dutch Fluit from Dutch explorer Abel J. Tasman
Unofficial motto of the VOC:
"God is good, but trade is better"
Measured many times the heights of the different decks.
Meaning of the colorful push pins:
Yellow and red is for the waterline.
Green and blue is for the lower deck
which will not be visible.
White and clear is for the main deck, and decks I don't know the names for.
1364115945_FluitZeehaencolorcodeddeck1.thumb.jpg.9a188d94e106739e2acb8dbb80698ffa.jpg
1138645980_FluitZeehaencolorcodeddeck2.thumb.jpg.658e592484f75ff7c16f567a75ec4749.jpg
This is the lower deck that will be completely hidden. I have put it in anyway because I will use it as a guide for the beams for the main deck and other small deck.
What is the deck called under the poop deck (where does that name originate from?).
Does the forecastle deck have a focsle on top of it?
Please feel free to set me straight or steer me to a location where all decks are defined on any ship. I have books that have some explanation of decks but they are not complete.
Thanks
Marcus
Looks like a good plan and execution, Marcus.   As for "poop deck"... Google is our friend:   "The name originates from the French word for stern, la poupe, from Latin puppis."
The interior and the decks and their naming are dependent of the sort of fluit. As you know the type was extremely versatile and the internal devision varies just as much. In the case of the Zeehaen, a VOC fluit, it is very much like the usual devision.
A - Hold
B - Cable tier
C - Hell (small compartment used as detention space)
D - Cheese and bread room
E - Powder room
F - Lower deck (in Dutch: overloop. comp.: orlop)
G - Gun room (In Dutch: konstabelskamer)
H - Upper deck (in Dutch: verdek)
I - Forecastle (in Dutch: bak) covered by the 'bakdek'.
J - Steering stand (in Dutch: schans or stuurplecht) covered by the 'halfdek'
K - Captain's cabin (in Dutch: kajuit)
L - Upper cabin (in Dutch: hut) covered by the 'campagnedek'.
For the simple mostly smaller cargo variant the lower deck was called 'koebrug'. It was only used for storage of goods which have to be kept dry and was not accessible for the crew. The crew's quarters are behind the koebrug and behind that is the cabin, which was used by the whole crew. The skipper used the upper cabin above. On such ships discipline was much different from men-of-war or East-India-men. The crew was small (about 12 men), of which most of them were very familiar, originating from the same village or region. Food was better too and not rationed.
I hope this explains it a bit.
Edited by Ab Hoving
I don't know if these will be of any help, but I just came across them browsing the Net. This one's a black charcoal sketch in the British Museum, museum number  1836,0811.609 - no mention of artist or date, but obviously a fluit.
The other is from a newspaper item about a 17th century shipwreck find - https://www.dailymail.co.uk/news/article-3547510/Rags-bottom-North-Sea-belonged-member-Charles-s-household.html - unrelated to the picture itself, but at the top of the picture it says where it comes from.
It might contain some details of value?
Steven
Thanks, Steven,
The 1st picture shows how the rudder and the tiller are positioned. The more pictures I see from that the better.
I have seen similar pictures like the second one. It always looks like the over do on the curvature of the hips.
Marcus
A pleasure, Marcus.
Here's another I found - a fluit by the French artist Diderot, dated 1779 (which I thought was a bit late for fluits to still be in operation)
Steven
 Back from India. The 3 day wedding was actually a 5 day wedding. It was a show of opulence. The groom arrived on an elephant.
Several things that left a mark in my brain were:
- The sheer amount of people, from dawn to dusk it is shoulder to shoulder everywhere you go. The country has 1.3 Billion people. (and I thought Amsterdam and Chicago had a lot of people)
- I thought I knew what poverty was, due to living in South East Asia and West Africa, but it is nothing like that at all. It was an eye opener.
- Three Traffic Rules: Have a working horn. Have good working brakes. Have  some luck.
Use your horn when you want to pass, when you are passing and when you passed.
Use your horn when others: cut you off, going too slow, Anything you can think of. Everybody does this and it is very noisy.
Constant fender benders. It happens, check it out, continue with your journey.
Police and ambulance drive in both directions all the time.
All in all the trip was a lot of fun, didn't get sick by drinking the local water and learned a lot about the culture and history of India.
Back to the Fluit.
Marcus
20 hours ago, Ab Hoving said:
This is probably a copy of an older image. The spritmast dissappeared after 1750.
Quite right. It did seem to be from the wrong era.
Steven
Have been doing some ship building but the last 3 weeks it has been mostly outside. Getting the edible garden ready for spring planting and pruned all the fruit.
So I cut away excess wood from the railings.
1531430042_200FluitZeehaenadjustrailing.thumb.jpg.5c0450c76e97eb739551e6703063cc3f.jpg
541426656_200aFluitZeehaenrailingsshaped.thumb.jpg.886017f4e089a60ccbf87bdb8bc51e96.jpg
Still need to remove the wood to where the tiller goes into the ship. It is curved.
Dry placed the decks on stainless steel rods.
Through carefully sanding the inside of the hull the bulkheads have been thinned in thickness.
My present dilemma is with what do I need to dress up the inside of the ship?
As is.
168281814_202FluitZeehaeninsidew.veneer.thumb.jpg.7844fe7f15a546785ba3d61e2e6de3b6.jpg
Veneer.
1260624412_204FluitZeehaeninsideveneerw.spaceddowel.thumb.jpg.f9eb3e5b7d8795a9d56d75cf2241d784.jpg
Veneer with spaced dowels.
1875163194_205FluitZeehaeninsideveneerplankingdowel.thumb.jpg.b15305a23b4bb73e899599390288c0d1.jpg
Layer of veneer with 0.5mm thick planking on top of that and spaced dowels on top of the planking. The last option seems like the best option.
All advise is appreciated.
Thanks
Marcus
Marcus,
Maybe the hull of a fluit was planked on the inside.
Then the frames are not visible
7 hours ago, Backer said:
Marcus,
The pictures in the 17th century Dutch merchant ships book show the outside of the hull planking and on the inside long vertical square dowels. It seems like the ship was built shell-first.
I am going to do veneer with 0.5mm planking on top with spaced square dowels on top of that. Making it look like frames.
Marcus
Created little deckbeam holders and glied the with a combo of glue and sawdust to the inside of the hull.
225711881_207FluitZeehaendeckbeamprocess.thumb.jpg.a9dfd0a8e7ca823cae27e0f257af3521.jpg
157792434_208FluitZeehaendeckbeamprocess.thumb.jpg.a8b4d72c4f881cf6e7b69be0fdfccf1f.jpg
1220798296_206FluitZeehaendeckbeamprocess.thumb.jpg.f94eec31976ccc3bd3975aa6e3bc1fa8.jpg
The beams are dry fitted in the slots.
1806833721_209FluitZeehaendeckbeamprocess.thumb.jpg.4d3dc47d56aed3a38dece70ea17fee51.jpg
You won't see any of this when the main deck is in.
Once this is completed I will start on dressing up the inside of the hull. It is the area that is exposed.
Marcus
On 3/24/2020 at 12:49 PM, Ab Hoving said:
You are really capable of creating a tremendous mess, Marcus.:-)
Can't wait to see the rest...
Ab
The mess will be hidden. You won't see it.
Marcus
I am stuck. I have difficulty visualizing the transom/stern area (maybe it's me).
I do have help from a Dutchman on modelbouwforum.nl who has built the Zeehaen in a smaller scale and his looks really good.
I'll just go back to his build and stare at his pictures from the stetn area 😀
Marcus
2 hours ago, ccoyle said:
Marcus, I somehow missed your catboat build that you provided the link for -- that one came out very nice!
Yes, she turned out pretty nice. My sister and brother in law love the build and she is proudly displayed on a side table in the living room.
Marcus
OK Marcus, here you go...
Remember that lousy sketch I drew you?
1987891737_Scan1.jpeg.65cc67d1fdcaab5616d9d1a914e953f3.jpeg.2f4e1f6f051685852a004954066261ba.jpeg
Grab that batten you screwed to the sternpost and place it where you had it. Now you have the right position for the taffrail. Make it from card first to get a good fit and then glue your wooden version between the ship's sides, tight to the front side of the batten. Now you can remove the batten and the excess of the planks sticking out backwards.
Then show me a picture again.
Best of luck, man.
Thanks, Ab.
Once the taffrail is installed, I need to cut out a round area just below the taffrail. I think that once the taffrail is in then that should be easy to do. Just follow the curve of the carvings tbat will be installed at that location.
Marcus
Did what Ab mentioned in his post #174.
First I dry fitted the taffrail to the batten that is screwed to the post.
901545400_145FluitZeehaendry-fittaffrail.thumb.jpg.2deb18cb47d8c5743c437724bc9c6d21.jpg
729189266_147FluitZeehaentaffrailscaledin.thumb.jpg.4fb0d43339769d4dd70d8f6260b6d467.jpg
Glued the taffrail in place.
1386448894_148FluitZeehaentaffrailglued.thumb.jpg.884f7d09d8a94642466259cabe7d608a.jpg
After glue is dry remove the batten holding the taffrail and the excess of the planks sticking out backwards.
Marcus
Edited by flying_dutchman2
Spelling
