I decided to start a new build log based on the classic Revell 1/426 USS Arizona. I will be creating a diorama of the USS Arizona as she is now with the Shapeways memorial scale model. I started by removing the decks from their sprue and assembling the basic model. I only need the two hull halves, the two primary decks, the first secondary deck, two turrets and one set of guns. I traced the outline of the inverted hull onto a piece of cardboard. After measuring the length and width, I printed the drawing that I will base my build on, on legal size paper. Now I just need to take my plan to a copy store and have them match the size for me. Once I have these copies, I can match up the model to the drawings.
Not an easy undertaking at all, so kudos for bringing this to small scale.
Ongoing:
strange.......I've seen pictures that appears that turret #2 was removed.  two of her turrets {the aft turrets} were removed and rebuilt on Mokapu pennsula and Kahe point,  as pillbox batteries.   the guns from turret #2 were removed,  relined,  and later installed on the U.S.S Nevada,  to be used in the war against Japan.
Battleship Photo Index BB-39 USS ARIZONA
there'a quite a bit of info here.   013923b.jpg.7dd1b4cb6dfb9b78b0cfc4ff67cd7348.jpg
the blast to her bow affected both turrets and the superstructure.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I have done some research ahead of time, probably more than a year, but this is the first time the model has seen the light of day in a very long time.
The explosion lifted the armored deck and when it came back down a lot of the ship was no longer there. This explains why the forward mast was bent at such an angle.
The port bow section is bowed out. The main deck much lower forward of where the superstructure was, and the keel must be fractured near the bow.
Edited by SigEp Ziggy
A gallant project. May I ask where you acquired the explosion diagram or is that your own work?
Will watch with great interest.
Thanks, Harley
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
you can also see diagrams in the link I posted as well.  if you need deck plans and such....look here:
Researcher@Large - USS Arizona BB-39 Booklet of General Plans Drawings
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I have done some work on the Arizona. I cut the hull as I had marked them, cut up the main forward deck, drilled holes in the nos. 3 and 4 barbettes, cut the bow off, removed the no. 2 barbett from the secondary deck. Also, I did a mock-up of the damaged ship.
I have been working on, and receiving parts in the mail for, the Arizona Memorial.
First I got the moorings from Model Monkey. Then I found a photo I will use for the diorama. And lastly, I started working on the no2 turret, the mud lines on the hull and received the Memorial from Shapeways.
Coming along nicely...
Rob
Current build:
Finished build:
Current build(On hold):
the added parts look super :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I ordered some 1/400 scale people from and architectural supply company, so there will be visitors on the memorial.
Worked a little on the destruction of the Arizona, I split the sides on the hulls to bow them, and started modifying the rear deck.
Hello Shane
I have taken some time to look at this log again, I love the way you have done your research, well done, that just goes to show that you are committed to your build.
Also well done on having the courage to purchase a kit then destroy it so you can achieve your desired effect.
Thank you for sharing and showing us your skills on this forum.
Jo.
IL Leudo - Mamoli - 1:34
FD10 Arnanes 701 Billings scale 1:50
"Good conversations are the ones you have with people you do not know"
Thank you so much Jo, it means a lot to me.
I have put off modeling for too long and didn't know how much fun it would be to share on forums and make new friends. This is GREAT!
This Arizona kit is very old and like Revell's Constitution many have built it before or many times. I wanted to build this diorama as the USS Arizona is now and as accurately as I can.
I did visit her in 1973, when I was 12, (opps, dating myself) and was deeply affected. So, many years later, I will honor that memory and those who served her.
Thanks for all the likes Gal and Guys
Thank you too Jo,
I have been wanting to work on her and it felt good to post to our forum!
I also worked on the Nina, however was not post worthy but close.
Hope see what everyone is working on soon.
Your Shipmate,
Shane
signature
