So I got my q galley templates mocked up tonight and boy what a nail biter. I found that my stbd template held a nice shape where my port one is a little warped, both are in nearly identical positions down to .001”!!! yet the port one really throws the eye off due to the warp. I’m going to sleep on this one and possibly print the port template out again tomorrow, if anyone that’s been here sees anything jump out please let me know!
JJ
             Portland Scale Ship Co.
I was just reading about this on Chuck's topic and he gives a good explanation about it on page 15.
Completed.... Charles W. Morgan,Sea Horse,USS Constitution,Virginia 1819,San Fransisco II, AL HMS Bounty 1:48
L'Herminione 1:96
Spanish Frigate,22 cannons 18th C. 1:35 scale.Scratch-built (Hull only)
Cutter Cheefull 1806 1:48 (with modifications)
Current Project: Orca (This is a 35" replica of the Orca boat from the movie Jaws)
Hello JJ:
I think the placement it is perfect.  The lower portion of the template corresponds to the first horizontal piece. The fore line is the tip of that first piece once you add the trapezoidal cover where the freeze is placed.  The aft line is where the horizontal piece for the window goes.
I highlighted the box the I marked on my build and the position looks exactly as yours with respect to the last gun port.
Hope this help,
G
Thank you for the input Guillermo, it’s always nice to have another set of eyes on something. I’m going to measure and double check a few more times and begin proceeding.
JJ
I also temporarily tacked pieces in place with rubber cement to check placement and alignment prior to permanently gluing in place.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
No problem,
That first piece needs to be beveled before it is glued.  Once you add the cover and the molding, the fore tip of the Q gallery will be ahead of the fore line.  Also once you add the columns, the fore side of the column will touch the fore line.
I glued the first piece, and worked the second lower piece with the model upside down.  It is easier to work the aft bevel of that piece, the bevel against the hull, and to glue it parallel to the first piece (better perspective when you look from the top; both pieces match).
Best,
Thank you for the comments And advice guys, I’ve gotten underway and so far it’s looking ok. Everything is measuring out pretty even so that’s good.
JJ
that looks really good JJ
Rusty
Little progress update, been chugging away slowly at the Q-galleys. Going back and forth between P&S sides. Got all the windows for the q-galleys fitted but not permanent yet. Fitted the drops on both sides and those turned out well, needed a little sanding. Got the port side q-galley Roof tiles finished Today and started working on the moulding and frizzie placement. Still working on the moulding profile that I like for the middle moulding, definitely sacrificed a few pieces of boxwood strips in the process but I’ll get there. Happy so far with the results.
JJ
So I pretty much finished up the port side tonight aside from a few minor details. Scraped and fit the lower moldings and Added some WOP, that stuff really brings out a pretty color on the boxwood that looks great with the cedar.
 I’ve had constant anxiety for the last week thinking about how to get these mouldings on perfectly parallel and keeping with the sheer line and it just dawned on me about two hours ago to just clamp on a plank that perfectly follows the middle moulding and simply glue on from there. Seemed to work pretty well. Hope someone else can find it useful when they arrive at this stage.
JJ
Very nice JJ. Great tip on the molding. I'll try to remember it next time around!
Rusty
Thanks for the Likes and comments guys! Hoping to get started on the stbd side tonight, I always Find the second side harder to do as you have to replicate everything as close as possible so a lot more measuring/worrying/double checking  goes on.
JJ
Beautiful work, JJ.  Your moldings look perfect.  I have a question for you and I think I know the answer: Is your cellophane "glass" installed in your quarter gallery windows?  It's hard to tell, but I think it has to be there by this point.  I'm early in chapter 3 and will be starting the Q galleries soon.
HMS Winchelsea 1:48 (Group Project)
Completed Builds:
Virginia 1819 Artesania Latina - 1:41
Thanks Matt.
no actually they are not installed on the q-galleys yet but I plan to do it very soon. The roof tops are also still loose. I won’t glue those on or the windows probably until I finish fairing the insides, that way I can clean the q-galleys out prior to sealing up.
JJ
No need to rush on the glass...they will get dirty and collect dust.  You can wait up to the very end to install the glass.  In fact its better that you do.
Thanks Chuck, I probably will wait longer then. Seems there’s always some kind of sanding going on nearby the model. She’s going to get a case right away.
The stbd side was indeed a struggle, I won’t get into it too much but there was a lot of printing going on and some additional scraping and possibly some vocabulary, but it all worked out. Starting the transom this week and hoping to finish up chapter three within a couple weeks.
JJ
7 hours ago, Nunnehi (Don) said:
Very nicely done - beautiful work!
I agree with everyone else -- beautiful work & craftsmanship......
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Thanks for the likes and comments guys. Moving onto the transom tonight, have a few corrections to make back there before I can proceed, should  smooth afterwards.
JJ
That is some great workmanship!
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                           Iron Clad Monitor (complete)
                           Sardine Carrier which I will Name Mary Ann (complete)
                           Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
                           Light House Tende Beech (complete)
Great workmanship JJ.
Rusty
Thanks guys, but most of the credit needs to go to the University of Chuck! I’m just following directions.
JJ
