Wütender Hund by ccoyle - FINISHED - Shipyard - 1/72
I am jealous.  I am about the same place but mine is crappy less good.  Also, you are doing a better job of documenting.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, John Smith Shallop
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch 1/4 scale-Model Shipways plans)
Link to comment
Share on other sites
Well, a plank here, a plank there -- slowly the work is progressing. Here is the progress to date:
Mostly I'm making this post to document for other builders a problem that I have been having with the planking at the stern. I've been running into a lot of trouble with closing the seams where planks overlap -- but only at the stern. Hmm. Here's a shot of the bow:
As you can see, everything looks nice and tidy.
But now, here's the stern:
You can see that there's stubborn gaps forming as a result of needing to bend the planks a certain amount in order to make them align properly. Of course, the close-up photo makes the problem look much worse than it actually is, and a person would have to view the finished model from a very awkward angle to see the open seams, but still I'm finding it rather annoying to try and correct.
Two more strakes, then it will be time for the first application of stain.
When you have to shoot, shoot. Don't talk.
- Tuco
Current builds: Brigantine Phoenix, Hawker Hurricane
Link to comment
Link to comment
Perhaps, while you pre bend your wet planks to fit the hull, you should also try to edge bend them a bit with your hot iron. Attach (glue) them only if they lay perfectly on the hull - that way you will avoid these gaps.
Also, earlier on, you were right with those Polish markings: the letter L in Polish means strona "Lewa" (left) and the letter P means Prawa (right) side of whatever.
I still remember my Polish, after leaving the country 40 years ago (!). So, if you have any problems with understanding your instructions, ask me and I'll try to translate this fragment for you, OK?
Link to comment
Looking good!  Will you pencil dot your nails later or leave them as they are?
Chuck Seiler
Link to comment
Looking excellent...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Link to comment
Hadn't thought about it. It would be a lot of work, and I subscribe to the "less is more" school of thought on treenailing.
- Tuco
Link to comment
When all is said and done, by the time you get the stain and no pencil dots, the existing 'nails' will be visible but sufficiently subdued so as not to overwhelm the model, like on mine.
Chuck Seiler
Link to comment
Next milestone reached
After eight nine strakes of lapped planking, the instructions call for staining prior to installing stanchions. The Polish name for the suggested stain color wasn't translated, but in the photos it looks something like golden oak. I went instead with golden pecan, which has a redder tone. I like the result.
- Tuco
Link to comment
@Chuck Seiler Chuck, I hope you like gluing in false frame extensions! I finished up the starboard side -- all 37 of them. Now onto the port side!
- Tuco
Link to comment
For me it is more than 37...or maybe 37 with complications.  Since I am having to cut some of the planking pieces and inserting longer planks (see above)(edit...oh wait, this is your log, not mine...see my log for discussion on planks) I need double thick frame extensions at the point where the joint is.  So far so good.
Chuck Seiler
Link to comment
Ah, yes -- I forgot that some are doubled, so really only 34 per side. It went pretty fast, though.
- Tuco
Link to comment
My decks are wood and I gave them a coat of Wipe On Poly.  On my first extension, it stuck to the planks but not the deck.   :angry:  For follow-on extensions, I had to rough up the spot on the deck a little.
Chuck Seiler
Link to comment
That looks really nice - very well done!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
I used Golden Pecan either for the interior or exterior of my PHILADELPHIA.  It's a great color...good choice.
The nails look good without the pencil dots.
Are you staining the interior as well?  If so are you using oil based or water based.  My concern is for the glu-ability of interior frame extensions and other support lattices.
Chuck Seiler
Link to comment
Yes, I stained the interior, though the reverse side of the ply doesn't take the stain as well. I had to go with oil-based stain only because the local stores had a pathetically small selection of water-base colors to choose from. Home Depot had maybe two, and I think Lowe's had none at all, at least not in the small cans. I'm not going to buy a gallon of stain for one model. Anyways, I have not had any problems so far with gluing the frame extensions.
- Tuco
Link to comment
Last night I finished installing the frame extensions -- all 68 of them (bleh). No picture at this point, because despite the sheer number of parts, it doesn't represent a huge leap forward in progress. Planking the bulwarks will be the next significant task.
- Tuco
Link to comment
Beautiful work, Chris! I think this puts you, Chuck, and myself roughly at the same stage. Only, I've had a lot of unrelated issue get in the way that's pretty much halted my progress for the past month or more. Hope to get some progress going again, so I don't fall too far behind you guys!
Clare Hess
He's a -> "HE"
Link to comment
Next update: Frame extensions and the last planking strake that goes with them completed, along with the remaining interior framing at bow and stern. One issue to look out for, albeit a very minor one, is that the the last three interior frames at the stern had the left and right labels (L and P, in Polish) reversed. Not a big deal, since the parts are identical, but using them as labeled will result in the reverse side of the ply facing out, if that makes a difference to anyone.
The fit of the frames isn't as perfect as the next photo suggests; some of the frames extend slightly above the bulwark (how much above depends on how good a planking job one does) and must be cut and sanded flush with the top edge.
That takes us through p. 17 of the hull construction.
- Tuco
Link to comment
Upper decks planked and hatchway installed. I had to stain a few bits off the model, so I went ahead and also stained the existing interior framing, along with the last plank that I installed. Looks pretty sharp, I think -- it's kind of growing on me.wh21.thumb.jpg.4479eb43e2070eef2bc2329d246d4551.jpg
- Tuco
Link to comment
That’s looking really nice.  Great job!
Mike
Link to comment
Further progress. I'll call this first shot a pic of the "kinda looks like a windlass thingy," even though I know it's not a windlass. Bit more of the interior bow framing added as well. Heads up @Chuck Seiler: That pseudo-windlass thingy took quite a bit of fitting to get it in there right. I had to remove some material on the starboard side.
And I also got the port-side interior bulwark planking done. When I originally did the outer planking, I was a little worried, because they didn't have much in the way of gluing surfaces. But once all of the interior framing and planking is added, the hull is actually quite sturdy.
Onward!
- Tuco
Link to comment
The thing up forward?  I have seen it described as an above deck, athwartship deck beam...as opposed to the 4 or 5 that are below deck.  They all end up sticking out the sides like an old adobe house in Santa Fe, New Mexico.
Fore warned is fore armed.  I am about a week away from that.
Chuck Seiler
Link to comment
3 minutes ago, Louie da fly said:
That shape is much rounder than I'd ever thought - very suitable for carrying cargo.
As I mentioned in my log, pretty clunky looking but it did the job.  It didn't have to far or fast but it did have to haul the goods.  Later, when speed became more important, the length to beam ratios changed.
Chuck Seiler
Link to comment
Interesting model Chris and you're doing a beautiful job.  Nice clean work and I really like the interior framing at the stern and bow.  Looking good!
Gary
Completed Scratch Builds
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
