Guys the copit is built and painted looked like the resin pit was having alignment issue but I think I saw something tonight while I was in the shop all of ten minutes.I like the look and will have some pics for tomorrow night promise.I do not build much in jets but can see some more coming into play.;)
On 2/6/2022 at 4:49 AM, Javlin said:
I am back on top of this one fellas already working should paint the pit this week researching the past research.;)
Finally!
Looking good so far
Samuel Pepys notes in his diary on 19 July 1667: "the Dutch fleets being in so many places, that Sir W. Batten at table cried, By God,says he, I think the Devil shits Dutchmen."
Very good progress, you can see already its shape. Cockpit looks great.
Dan
Well after eight days straight of work then yesterday the Wife had knee surgery 9th day I finally got some time at the table.The fuse is glued up no open panels and it's less work.The two halves of the fuse have an ever so slight step from the wing root(WR) up maybe 1" no biggee .The wing is still not glued in place but the worst seam is the side you see now at the WR area I am thinking putty wipe with an alcohol swap and an 800grit scotch brite that is getting some wear.I have got to afix the front and rear parts of the pit research more on colors though.This one is going together easy peasy.;)
Not to cry in my soup but damn I have been busy as you know what lately.I got some work done the other night and started painting last night Alclad Primer,Alclad Gloss Black then some Airframe Silver wanted a slight shine on this one.I put some Beethoven #5 on the turn table started spraying some more and fook me :hsmack:I did not say one cuss word started cleaning the airbrush and try again tomorrow scotch(and a scotch now) brite and repaint that area and I saw another area I did not like so maybe theirs a reason? ;)
too much thinner perhaps?  the spots are tell-tail for spatter.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
This is were she sits ATTM I am on the fence the AirFrame Silver looks splotchy to my eyes and trust me I have laid several more coats with the same results it's how the light hits it.I have started doing some panels in the last week just playing around using a pointed Yamiya q-tip and buffing(SNJ)with a regular one no need to tape off in this case very close in color to the AF silver I think it lends itself for the most part better lighting on the R-side of the a/c.;)
Edited by Javlin
1 hour ago, shipman said:
You know it makes sense.
Just seems it would take to much time but yes it does look good.I have had some success with paint but it's a hit and a miss much like baseball life is like that but I digress.I am thinking it will work good in the end lots of decals let the future dry good enough with abit laid down might be able to use the Tamy wash this time :brickwall:used magnesium on the gun ports tried stainless looked frigg'in blue almost.;)
Okay She is finally starting to look like an F-86 :hsmack:This build has just about been a PIA as far as repainting goes though.I started applying the yellow band decals did the fuse first was on to the one wing when I noticed the fuse band was to far back arrgh!!So I pulled up the wing not dry yet but the fuse............will out came the tape and in the process broke off the Tailplanes :brickwall:OK not one cuss word I promise but their was some breathing happening in the long run made doing the decals around the tail easier without them there.I guess you have figured by now the bands are painted paint one paint all actually looks better but when does it not!The instructions from Kinectic have a bit to be desired on decals so anyone who builds this pay close attention the the fuse band it about touches the wing root. and notice the design of the bottom decal says alot.I think she will look OK when finished trust me I am ready for that word "Finished"..........two with flash two w/o.
Edited by Javlin
Hi Javlin,
it seems that you have tamed this build. From the latest pictures posted by you, your F-86 looks pretty good. NMF and decals/stencils are also very good. I cannot distinguish any blemish on the metallic finish. Unfortunately, I was late in suggesting a sheen steel finish for the machine gun panel. Now, with decals placed close to it, probably it would be very risky to try to correct it. But even with the present finish, it looks as a good model, so I do not recommend any correction for it.
Waiting to see the conclusion, best regards,
Dan
PS: didn't this type have an anti-glare panel in front of the windscreen?
That looks Good Kevin, scale BMF can be achieved with an airbrush of that there is no doubt...
And this was a very nice job... I think airframe aluminum was the right choice... (and I believe stainless would be the correct choice for the gun port panel which yes has a slightly blueish cast so it should be laid thinly over white primer to lighten it up a bit)
Nice work figuring out the airbrush technique...
Quote:
your near the finish line :)   silver....silver leaf......no matter how one does it,  silver can be a task and a half!   I wonder if aluminum paint would be a better choice.   she look'in good my friend......great job! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
That looks great my friend, I hope mine turns out half as well....
Very Nice...
Quote:
I am sure it well EG.The only problem with the Dura-Aluminum was through handling and I guess the acid from the fingers it changes color like dingy hence the photos outside in good lighting (inside/outside) she's a beauty.Hey,I can just say it's weathered naturally :D
awesome job ........it reflects very well in the sun :)   don't count yourself short  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Under the sun light it looks very nice. Metallic finish looks very realistic from here.
Cheers,
Dan
1 hour ago, Javlin said:
Thanks Phil she was bear of sorts doing a 1/48 ICM He-111 H-6 Africa Corp right now she is coming out Nice thus far let's hope I don't muck it up.;)
Edited... never mind my asking about a log.  It just popped up while I was typing.
6 minutes ago, Javlin said:
I figured I was getting close enough to the end to post Mark.;)
No worries, sir.
