Battle of Waterloo Attack on La Haye Sainte Farm by Old Collingwood - 1/56 (28mm)
Whew, that's too close, mate. Glad you patched it up quickly. Sometimes we are our own worst enemies. :huh:
Ken
Started: MS Bounty Longboat,
Link to comment
Share on other sites
9 hours ago, Old Collingwood said:
.............guess where this is going??????
Yep...........the clamps gave way  and the whole  base fell Three Feet  onto the floor............🤬
Yep, Been there, done that!!! The best laid plans and all that... It happens brother, altogether too often on my part... Good to see that your structural building method was strong enough to come out with only minor damage...
We dodged a bullet my friend...  Looking forward to a great recovery...
Quote:
Link to comment
You very nearly saved the French a messy assault! Well saved!
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Indeed  Ken.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Indeed brother  - was a close call.
OC.
Current builds
Completed works.
Link to comment
The modeling gods obviously smiled on you as when I started reading I was thinking the whole thing was destroyed.
Link to comment
I think if it had been a weaker construction  - there would certainly been more damage, good job it landed on its bottom also  as most of tha damage was vibration  from hitting the fllor.
OC.
Current builds
Completed works.
Link to comment
Evening all,  I  kick myself  into doing some more work  on this to day,   first  I made up a couple of joining strips to cover the gaps on the main wall,  just Two srips of wood  painted and weathered  than glued in place.
I then decided to make up a hay cart,  and  proceeded to  destroy it then  weather it,  this is one of the defences the KGL  put out  on the road way  to try to slow up the French.
OC.
Current builds
Completed works.
Link to comment
11 minutes ago, king derelict said:
The buildings are very realistic. The last photo of th eright side of the front could be a real farm building. Just the right amount of dirt and weeds. The hay cart is a beautiful detail.
Alan
Thank you so much Alan,   trying to keep it as real looking as I can  - adding bit and pieces as I go.
OC.
Current builds
Completed works.
Link to comment
1 hour ago, king derelict said:
I'm very happy the mishap wasn't worse. I would have hated to not see this reach a splendid conclusion
Alan
Me too mate  - me too, my heart was in my mouth  when it hapened.
OC.
Current builds
Completed works.
Link to comment
glad to hear that you were able to save the dio.........would be a shame indeed! :Whew:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you Denis,  yep it was a tense moment  and the air was  "Blue - Green and Purple"
OC.
Current builds
Completed works.
Link to comment
just love what you are doing on this subject
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Thank you so much Kevin  - that means  a lot mate.
OC.
Current builds
Completed works.
Link to comment
Hard trials and great tribulation with this build, OC. Perseverance pays off.  I really like the damaged cart there in the road. Looking very good.👍
Ken
Link to comment
Thank you  so much  Ken.
OC.
Current builds
Completed works.
Link to comment
Evening all,  some more work around tha hay cart,  I have Two resin barrels  and an extra cart wheel, these were painted and weathered then glued to the cart, I was then able to glue the whole assembly to the base.
Working  some brick sections that where hacked out of the wall, when painted/weathered  they will be placed against the bottom  of the outside wall.
OC.
Current builds
Completed works.
Link to comment
55 minutes ago, king derelict said:
Just keeps getting better
Alan
Thank you Alan.
OC.
Current builds
Completed works.
Link to comment
"Hot off the press"   I might do some more figure work  later to day..............:dancetl6:
OC.
Current builds
Completed works.
Link to comment
Just read about the accident. Great that it was recoverable, after so much work it would have been a blow. Keep going, the farm and the latest addition look great.
Cheers,
Dan
Current build : Mayflower - AL 1:64
Completed non-ship builds : Spitfire MK I - 1:48Arado 196B - 1:32, Sea Fury - 1:48F-15C Eagle - 1:48Hawker Tempest Mk.V - 1:48F104S Starfighter - 1:48
Link to comment
Cheers,
Dan
Thank you Dan.
OC.
Current builds
Completed works.
Link to comment
Evening all,   bricks  painted and placed,  and as  promised  - a fresh group  of  2nd KGL  primed.
OC.
Current builds
Completed works.
Link to comment
Sorry  that I have been slow on this the last  few days   (need a kick up the bum)   to  be honest  I aint been so good, I suffer from  Angina  and  the last few days  I think I have a chest infection    - tight chest  when coughing  breathing in or out,  I am on  anti biotics   to clear it up.
I will  so a bit more  as the boredom is driving me nuts.
OC.
Current builds
Completed works.
Link to comment
You take care of yourself brother, and as much as we would like to see more, as long as we have patience, in good time we will I'm sure...
Don't push yourself....
Quote:
Link to comment
As EG said, in your own time brother!
We'll all be here waiting 😉
Current builds;
Completed:
Link to comment
OC, get well. Your health is way more important than a nice model.
Ken
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
