Battle of Waterloo Attack on La Haye Sainte Farm 1/56 28mm
Great photos OC
Cheers,
James.
Current Builds
Airfix Westland Sea King HU.5 1/48
Microaces Scrappee Liaison Radio Controlled
Occre Polaris 1/50
Hong Kong Models 1/32 B25 J Mitchell
Completed
Airfix Supermarine Spitfire Mk.IXc 1/24
Airfix Avro Lancaster B.III (SPECIAL) 'THE DAMBUSTERS' 1/72
Airfix Titanic 1/400
Airfix King Tiger 1/35
In the hangar, dockyard or factory
Airfix Fairey Gannet AS.1/AS.4 1/48, Airfix North American P-51D, Mustang 1/48, Airfix Supermarine Spitfire FR Mk.XIV 1/48, Airfix MGB 1/32, ICM Gloster Gladiator 1/32, 5 Airfix Tanks, Airfix Blackburn Buccaneer S.2 C/D 1/48, Artesania Latina Zuiderzee Botter 1912 1/50, Airfix WWII British Army 30-cwt 4x2 GS Truck 1/35
Link to comment
Share on other sites
10 minutes ago, chadwijm6 said:
Great photos OC
Thanks James.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
57 minutes ago, king derelict said:
The photos really capture the feeling of the moment
alan
Thank you Alan,  I had  Two options  due to the  depth of field  -  focus on the  95th rifles  or the  French  3 feet away,  and  the  house window view  that  was  just  a bit  different.
OC.
Current builds
Completed works.
Link to comment
7 hours ago, Darius359au said:
Love the picture of the Rifle Men ,great scene with The Rifles doing what they did best and skirmishing the French!
Window view looks good too.
Richard
Thank  you kindly  Richard.
OC.
Current builds
Completed works.
Link to comment
6 hours ago, Canute said:
Sharpe and the Sergeant in action. 😁
Indeed  Ken.
OC.
Current builds
Completed works.
Link to comment
Hi there  all,   a bit more  progress, I have  re done  the wall  extension  (well  turned it over and added a  small piece at the bottom)  its  been  painted  White  and waiting to dry.
I also  added some of my  resin water  in puddles  in the ruts  on the  road way  and against the wall  (waiting for  these to  harden and  go  transparent)
I  have also  placed  a  few more  figures  in the shape of  Four  2nd KGL   casualties  in the  orchard.
OC.
Current builds
Completed works.
Link to comment
Morning all,  more pondering s  -  I decided  to  play around with  my  water gel  product that  I made my pond  with,  the  idea  was  that  the  wheel ruts  in the  road way  would  probably  still  had  small pools  of water   sitting in them, - so  (not thinking about colour)  I  brushed  in a  bit  into  a  few of the   wheel  ruts,  its  thick and  White at first  but  after  about  Ten hours  it hardens  clear.   The problem  is  it  just looks  like a  clear  line  not  a  slightly  coloured water  like it should  have been.
Its  got me thinking  if I could  do a  very thinned  dark  wash  all  over  the  base - roadway  etc  (Yep  includes  trying to  get in with a brush  around all  the figures)  -  then  if I could  go over  the top  later when the wash  has dried  thoroughly   with  my  dry brushed  sand  dust  colour as a  high light.
Yep  would  certainly be a  job and a half  -  but  it might  work to  blend  it all  in together.
What  do  you  think?
OC.
Current builds
Completed works.
Link to comment
Or........perhaps  I could  ease out the  set  gel water, and  re  do  it  but using  coloured  water gel  -  with me  adding a  few drops  of wash  to the  mix  before  brushing it back in.
I could still  do the  dry brushing using  the  dust - sand  in areas  I can  reach.
OC.
Current builds
Completed works.
Link to comment
Evening all,   so  here  is  my water  wheel ruts  and  wall extension.
OC.
Current builds
Completed works.
Link to comment
And a bit  of dry brushing  catching some of the  rocks.
OC.
Current builds
Completed works.
Link to comment
16 minutes ago, Canute said:
That muddy rut turned out well, OC.
Thank you  kindly Ken.
OC.
Current builds
Completed works.
Link to comment
56 minutes ago, king derelict said:
Your dry brushing brings out the roadway texture very nicely.
Alan
Thank you kindly Alan.
OC.
Current builds
Completed works.
Link to comment
Just as a  little teaser  -  I  have  placed my  Two  British Cavalry  figures   on the  roadway  just  in front of the  Two 95th rifles,  I will  take pics  of them  later.......
So  this side of my dio  is  getting close to being finished - I will  also add  some  loose left items  like  - muskets  -  backpacks - hats perhaps even a shoe or Two,  then I will  be turning the dio around  and starting to  work on the scenery  on the other side.
OC.
Current builds
Completed works.
Link to comment
Cavalry   "Charge........"
OC.
Current builds
Completed works.
Link to comment
That looks bloody amazing!!!!
Brad/NavyShooter
Pending Launch: RMS Titanic - 1/100 - 3D Print - Pond Float display
Link to comment
Thank you so much.
OC.
Current builds
Completed works.
Link to comment
Seconded!
I could do with some lessons from you OC!!
Cheers,
James.
Current Builds
Occre Polaris 1/50
Completed
Link to comment
25 minutes ago, chadwijm6 said:
Seconded!
Thank you so much,      Lessons  about figure  painting  is  a  hard one,  think it  just  comes  down to  practice - practice  than more practice,  and  good  light  a  steady  hand  and  good magnification so you can see  tiny details  well.
OC.
Current builds
Completed works.
Link to comment
17 minutes ago, king derelict said:
The cavalry figures work so well in the landscape. great work
Alan
OC.
Current builds
Completed works.
Link to comment
52 minutes ago, CDW said:
Outstanding work OC. It’s epic!
Thank you  so much Craig,   it will   be  several  little adventures in one - around the different parts of my dio.
OC.
Current builds
Completed works.
Link to comment
After doing some  research  it looks  like  I need to  do a bit of scratchbuilding,  from some of the  photos  it  looks like  there  should have been  a  porch  building  on the  outside of the  farm house  around the  door  leading to the  garden,  I will  try to male one using  the photos like this  one, with  the  bits  of board  I  have to hand.
Photo  off the  net.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
Evening all,  I have set about  doing my scale drawing plans  for  my Porch building.
OC.
Current builds
Completed works.
Link to comment
Morning all,   so  after doing some  reading  up  on the  interweb,  it  looks  like  I will  be  doing some  landscaping  in the  farmhouse garden,  as it appears  to  gradually  slope  upwards  from a  retaining wall close  to  the  house, I will  need  to  research  how  I am  going to  construct  my wall  and  build  the  gradient  that  my  grass mat  and  sprinkles  will  go  over  to  make  a  kind of kitchen garden  -  grass  and  beds  kind of thing.
Here  is  a  view  off the  net  from  about Ten years  ago  and  also  a drawing  from the  1900s.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
