Wow... another one to boggle the mind.
3 minutes ago, king derelict said:
That is spectacular. That site has some gifted artists also
Alan
Indeed it does mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Some  amazing talent  around.
OC.
Current builds
Completed works.
Evening all,   more progress  - I  decided  to make  Three French men, and Three wondead  - they had been  made  before  and just need painting, so  my normal  routine  - primer  brushed on, then a  basic face/hands  coat  then hair/facial hair  then   a wash and soe detail painting.
OC.
Current builds
Completed works.
24 minutes ago, FriedClams said:
Just catching up OC.  Very nice progress.  Really like the cart and as usual, your figure painting is
superb.
Gary
Thank you so much Gary,     I will be back on it  - just giving my  HMS Hood  build some love.
OC.
Current builds
Completed works.
I'm back  folks  -  work on a couple more 55th  Ligne  French.
OC,
Current builds
Completed works.
Evening all,    more  paint being applied to these Three  French dudes  One is a Fusilier  and the other a Voltigeur  -  epaulettes, collors, cocarde, Shako plaques, buttons and trousers  - including a dead Voltigeur.
Three hours work just to this amount..
OC.
Current builds
Completed works.
11 minutes ago, AJohnson said:
And very fine they look to OC!  👏
Thank you so much  Andrew.
OC.
Current builds
Completed works.
Evening all,  right  thats Three  more  54th Ligne  done apart from some weathering and airbrush  top coat.
OC.
Current builds
Completed works.
Evening all,  Three  injured  2nd KGL   started  -
OC.
Current builds
Completed works.
Evening all,   washes  added  then dust  dry brushing   - think they are  dirty enough  -
OC.
Current builds
Completed works.
Evening all,   I have started  on another  group of  54th/55th  Ligne   figures   including  one who  is shot,   how I achieved  his pose  was to  use  the hairdryer  and soften the plastic enough  to be able to bend  the  torso, then I worked on his arms  and bent his  head back a bit.
OC.
Current builds
Completed works.
7 minutes ago, Canute said:
Good job on the Grognard.
Thanks Ken,    there are no  plastic pre-moulded  figures  in the  kit ranges  - to show  injured,    so a little bit of interpretation  is required  (and  heat)
OC.
Current builds
Completed works.
Evening all,   some more  progress  today  - firstly  I  had an error  to  rectify after doing more reserch  - my Tirailleurs   that I  had made  where  not  part of the attack on LHS  they were sent in to deffend  Pappolette  Farm  against the Prussians,   the  biggest  difference  is the different  Shakos  with extra brass  braids  and  Higher plumes,   so  I decided a little surgery  was needed  "off with there heads"   I was able to swap them over  for the correct heads.
I also  made up some more 54th/55th   including another  injured  fello.
OC.
Current builds
Completed works.
It's hard to do an action pose of wounded and dying people the fact that you can get the "moment" in realistic form is a testament to your modeling skills & ability brother... That's something I couldn't do, not in a million years...
Quote:
Thank  you  brother,   that  is  so nice of of you to say  - its  all  a  learning curve  that  we all   go through.
OC.
Current builds
Completed works.
Evening all,    more progress  with  my  Voltiguers   and  Grenadiers.
OC.
Current builds
Completed works.
Evening all,   this  small group is done  minus  flat coating.
OC.
Current builds
Completed works.
Just on a side note  -  the invasion of Belgium started  today  when Napoleon  crossed the border with his troops  leading to the  different battlles leading up to Waterloo on the 18th June.
OC.
Current builds
Completed works.
Evening all,   next bunch of French  started  -  primmed  then hands/hands  basic covering.
OC.
Current builds
Completed works.
3 minutes ago, AJohnson said:
Wow OC this really is going to be the proverbial "cast of thousands"!  How many soldiers  do you think you will do?
Thank  you Andrew,    so far  I  think I have made  about  Sixty  2nd and 5th  KGL  in and around the farm  complex,  I have about another  Fifteen I  can make,  then   there  will be my Three  Cuirassiers  about  Fifty  or so French  54th and 55th ligne  will be made  (but may  try to add some more  if I have the space)   and  I will add a  British Hussar  or  Two   and my  Five resin  5th KGL   wounded.
Will keep adding them till there is no more space.
OC.
Current builds
Completed works.
This dio will be epic, OC.
Thank  you kindly Mark,    I hope to build it  so there is  different pockets of action  going on in the different parts of the dio,  that kind of tell a story.
OC.
Current builds
Completed works.
Ditto!!
Are you going to put a soundtrack to it? Popping muskets, rifle cracks, drums, bugles and such😊😉😇
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
