Made two new templates for setting the chain plate angles. One is for the forecastle mast, the other for the other five masts. The top of the template corresponds with the slots in the channel while the bottom corresponds with the bottom of the chain plate, You just align the top section with the channel slots and use a pin or ,020" drill through the bottom holes to mark the position of the lower part of the chain plate.
Stack brackets are installed. These are made from 1/64" x 1/16" britannia strips bent over a jig (included with the kit) and trimmed. As an aside, forceps are great for holding items for painting. These are cheap ones that I toss in lacquer thinner after I'm done painting. They clean up easily and can last for years.
There are 120 holes in the cap rail for belaying pins. I decided not to laser them in because of the potential for breakage. So, you have to drill them but there is a template in the kit that will make this less challenging. You align the first two holes with the space between the stanchions, drill the first hole, stick a belaying pin or piece of rod in the hole to maintain alignment, hold the template in place, and drill away. It actually only takes a few minutes and everything is consistent.
The bobstay irons are going to be a bit fiddly to install. The arms are trimmed to length and a .020" hole drilled at the end of each, then through the stem. A pin is inserted through the three holes, glued to the arms and snipped off. By allowing them to pivot, it makes setting the angle easier when the bobstays are attached. Once they are in place, the irons can be glued in place.
All I can say is..... WOW!
This is an impressive ship and lovely model.
She is huge. Teehee, at least my 16ft work bench would be good enough....😀
Respectfully
The spring stay bails require a little patience and care to build. They are laser-cut .020" laser board but are surprisingly strong and flexible. They are best built off the mast. Two eyes are glued together, a light coat of thin CA is applied to them, then they are bent over a dowl (front bail) and 1/4" square stick (aft bail). The mast is drilled with a .022" bit, the bail is slid down over the mast, and a pin goes through the holes. Once everything is aligned, CA is applied to the end of the pin and the end is snipped off.
