HMS Pegasus 1776 by Mirabell61 - FINISHED - scale 1:64 - 16-gun sloop
Build log part 86
taking plans for positioning the ships boat, here dry fit trials.
There will be two spare topmast spars horizontal over the fore-ballustrade and the main gallows, on which the boat shall rest. The main stay-sail between the two masts is arranged and rigged in hight to enable free flying to either side without fouling the boat, and the hight between deck and the horizontal spare masts allows sufficient full hight crew`s move on the gun deck
Nils
the boat will be placed with a little assymetric offset to the port side I think
the spare topmasts here are only interim dummies....
the lowest stay-sail can swing free well above the boat
the boats bow in the background  peeping through belfry stool and the vertical lines
Hight for crew on gundeck is sufficient, even with hats on.....
Current builds
-Lightship Elbe 1
Completed
Link to comment
Share on other sites
Hi Nils - as you were kind enough to visit my log, I couldn't resist having a look at your builds, and I'm really impressed. Such wonderful work!
Thank you very much Jbwok,
I`l be looking at your progress with HMS Warrior with interest and wish you ongoing good success with it
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Nils,
I haven't been saying much as I've run out of words...  but your model is incredible and wonderful.
Mark.
I thank you very much for your nice appreciative comment and you`re always wellcome to drop in for catching up.....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Many thanks Yancovitch,
for dropping in to my log and your kind appreciation, you`re always wellcome....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Nils
Just had the opportunity to spend a few days at Venice and to visit the Museo Storico Navale there. (The admiralty including one of the junior admirals went shopping in the meantime – a somehow costly but altogether usable arrangement.)
Among a lot of interesting ship models they had two with full sails and braced yards. One had the yards attached directly to the mast and therefore rather brutally distorted shrouds on the lee side. This did look unnatural. The other fine model had the yards away from the mast by at least one mast diameter and the lee side of the yard resting on the hardly displaced shrouds. This did look quite natural. I remember you raising the question how to do this and I tried to find out your solution in your pictures but got lost in the wealth of details.
How do you fix the yards now?
Regards
Peter
Link to comment
Hello Peter,
very kind of you for using that opportunity in Venice and following up to the yard arrangement when bracing........., Thank you very much !
This is how I did it....
As unfortunately neigther Lees`s nor Lennarth`s highlight this point in their books, I did it by the truss-tackles, (loosening the weather side and tightening the leeward Truss until the yard gently touches the most fore leeward shroud), The pics will show....
At The leeward side the yard comes to fit about in the vertical level where the catharpin sits, just under the futtock shrouds, this is sort of a waist in the shrouds and allows maximum bracing on leeward side
In the vertical hight the yard is securely positioned by sling and jeers. I trust it looks quite realistic
I know in the meantime that also on some british ships the first one or two shrouds on each side had an integrated additional tackle to loosten these perticular 2 first shrouds, so they do`nt foul with the yard. In the german version of Wolfram zu Mondfelds publication (in case you have.... this is also shown on page 301 ). It was too late for me to adopt that at time of building...
Mostly the modelers do`nt brace the yards, so this point dos`nt raise questions for the unbraced....
Nils
here the weather side truss allows the yard to move a Forward distance at appr. a masts diam. (corresponds exactly with what you noticed in the museum)
Here the yard touching the first shroud, but not fouling it, in hight of the catharpin
under running # 3 on the scetch drawing (Mondfeld) it shows the first two shrouds ready for to fit an additional tackle, so the deadeye lacings at the channel need`nt be loosend as well
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thank you very much Bob,
I gladly would like to return the appreciation when sighting your outstanding "Essex" rigging Job, especialy when there are tricky details, and to see......Aaah, thats how he did it / solved  the point...
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thank you very much Thomas,
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Nils -- The point you and Peter discuss here clarifies something I'd wondered about on my last build as I was figuring out how to fix the yards.  It is interesting, and is now one of those details I can only hope to remember whenever I next get around to the rigging phase (hmm, a rough calculation would put it around 2018  :huh: ).
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Link to comment
Thank you Martin,
at the time I stood before this point, there was unfortunately no advise available, but I knew Peter`s mind went pregnant with the thought....., and you`re right, luckily now its solved
I`m sure that one is saved in your mind, If you have doubts, you can make yourself a Little mock up mast and Yard dummy with sling and trusses, so first : you did it and second : it stays in mind for your "Fly" build sooner or later anyhow   (do`nt take it seriously,  smile....)
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Nils,
Just looking at all the rigging detail on your finely crafted Pegasus, makes me cringe at the prospect of rigging my VOC ship.  I sure hope to come close to what you have accomplished.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Hi Piet,
thanks for your word,.....
I just had a look at your current Project "Surabaya", a very fine looking model, and all in own design, hat off, its going to be a beautiful representant for the VOC fleet. I also liked your introduction thereto....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Obsolete spanker sail...
dear fellow Swan Class modelers in 1:64 scale
I have here one obsolete, complete self sewn spanker sail (mizzen mast) for "Pegasus" or "Fly", with bolt rope all around, reef- and reinforcement patches at the rigging corner points.
It has become obsolete because I changed the cloth widths, ducks (from 18" to 24" ) on my model. The sail has 18" cloth width, resp. 7 mm for the model`s sail
I shall give this away for free, to whoever can make use of it it, whereby posting costs kindly will require refundment by Paypal in advance.
If interest, please dop me a PM.....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Beautiful model Nils.  I've been thinking about dressing my Pegasus in full sails, and after seeing your model, I'm definitely going that route.  Hopefully I can pull it off half as nicely as you did.
Congratulations on your really amazing work.  You are a true artist!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thank you very much Mike,
your words are much appreciated, I shall be happy to see another Swan Class under sails in due time....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
nice appreciative comment Lawrence,
thank you very much, and I`m sure that your "Annie M." is going to be a pride of a schooner under full rigged sails in not so Long time....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Nils
The follow up on the braced yards was not purely selfless – I’m tempted to follow your lead and do the same on my pickle.
You are doing great. Oh, by the way, – do you already know how you will top your stunning Pegasus with a next project? With your building speed Pegasus will be finished in just a few weeks. :)
Keep up the good work.
Cheers
Peter
Link to comment
Hello Peter,
Thats a great idea, please go ahead with it.... the "Pickle" under braced sails, must be eyecandy on the shelf (in Showcase ?), when done......
Shall love to see that hapens... in your shipyard
I think I`ll have to do some work around the house and garden when "Pegasus" is completed, its been postponed already for quite some time.
On the modeling side I have`nt made up my mind yet, I have though thrown an eye on perhaps a 1:48 scratch build of one of those single masted 15 British naval cutters 1777-1778, like "Rattlesnake", "Alert" or so....., some weeks ago I shot Peter Goodwins book The Naval Cutter Alert for a bargain at Ebay, on the other Hand I was always wanting to build one of those famous pre WW1 four-stacker passenger liners
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Build log part 87
Update
have started to coil up the line-ends  (separate coils)
Nils
several lines to foremast bits and to bow pin rails
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thanks Carl,
now its time for doing the fine type work, I`ve bought myself a mini flattend nozzle with flexible tubing for Adaption to the regular vacuum cleaner, together with  a suitable sized Paintbrush  I must try and get some dust out of the ship that has settled on the lower decks during the many months of build
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Nils
Of course I would like very much to see you build another sailing ship of the era of the Napoleonic wars – putting that wealth of experience you have now to good use.
On the other hand I did browse a bit to see what other four-stackers were there besides the well known Titanic and her sisters. And I must say those German liners like Deutschland, Kronprinz Wilhelm or Kronprinzessin Cecilie with her exceptional career were elegant and beautiful ships.
That’s a tough choice for you.
Cheers
Peter
Link to comment
Well done, your attention to detail has always been great.
Bob
Current build:  SS_ Mariefred
Link to comment
Hi Nils
Cheers
Peter
Hi Peter,
you had just the right sense with those ships you mentioned, I have a book of the Vulcan shipyard in Stettin which of course is also showing some plans of the ships. I am, next to a british Naval Cuitter, momentarily also grooving myself in on the twin-srew liner " Kaiser Wilhelm der Grosse" in scale 1:150, will be a beast of 1333 mm length, but no decision is made yet. I simply love the lines, the technique of those days, the luxiary of the fitting out, and the speed those liners could go, knifing their way through the Atlantic.
Here is a free available pic of a model built in card in scale 1:250, I borrowed from the web (HMV, Hamburger Modellbaubogen Verlag)
Cheers,
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Bob
Bob,
thanks very much for your nice comment....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
I just caught up with your progress Nils.....the rigging you've done on Peg is phenomenal!  the ship's boat looks great........such an amazing build all the way around.  :)   being so close to finishing her,  I'm sure that the next build you decide on will be just as fantastic!   you have tremendous skill at both ends of the spectrum :)
I've got the Academy Titanic in the closet...the admiral got it for me,  for Christmas.  of course,  I've been putting it off in order to catch myself up,  but the subtle hints are starting to surface.   how much longer it will stay in the closet.......I cannot say  :D  :D
love the work you do with these ships........really nice brass work ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks for your words Popeye,
I can feel with you concerning The Academy Titanic (scale 1:350 if I`m right)......
I have both "Titanic" (Mini Craft, 1:350) and Cunard`s "Lusitania" (Gunze 1:350) still sleeping in the cupboard. One reason both are frozen in at the moment is that in the meantime I have seen such fantastic detailed and incredibly well built models, in particular the Titanic, in a quality I will never acheave in that scale.
As I mentioned to Peter (Flyer) some days ago, I`m gathering information on a british naval cutter scale 1:48, and on the 1897 launched german passenger liner "Kaiser Wilhelm der Grosse" , probably in scale 1:144, for to make my decision wich of the two for the next project
For the cutter I have basicly all I would need already, for the liner not yet
Nils
Here is also a little update on the HMS Pegasus...
Build log part 87
I`m doing the coil-ends of the lines at the belaying points
jig for the line-coils, The pencillines are for the different coil diameters
at the handrails left / right to the Quarterdeck entrance
front pinrail, QD-ballustrade looking forward
pinrails left / right of the skylight
on spanker boom, for outhauler tackle (inhauler on stb side likewise)
at forecastle ballustrade, (stb side still "untidy" )
at main gallows pinrail, allowing pump-crank levers to turn free
Current builds
-Lightship Elbe 1
Completed
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
