Another project that I had missed so far, perhaps because it is somewhat outside my 'time-frame' (19th century).
Very nice work on the slip-hook. Are the pieces for the shackles etched or stamped ?
Talking about the slip-hook: are you sure that it is attached that way to the anchor-chain ? I thought these slip-hooks were used at the end of chain-stoppers (short chains or wire-strops), hooked with the opening part into the anchor-chain, while the other end was shackled to an eyebolt on deck.
Thanks for your comments guys. A bit of update: didnt like the capstans, so made new ones (brass/wood) plus the chain deflectors .
Lashing chains (? English?) are now also there. Bit of work that as it required to remove the studs from the first two links of the anchor chain and then threading the lashing chain through it and finally getting small shackles through to fix it to the eye on deck. Will need to touch up some paint as it took uncounted tries.
some progress on the bridge with some interior „decoration“, glass for the windows. Built the 3m rangefinder and made my first piece of railing/handrail.
latest were the first bollards plus fairleads (rollers still missing) .
That is a very nice job, you did there like it a lot. !!
Again a little catch-up. Steel cables holding the mast i found to be wrong in my plan. Were drawn as passing the bridge structure, but that would have them blocking the LoS of the 6 in gun. Photo study showed they pass through the bridge…took courage and care to drill the holes without wrecking it. (Mast is just temporary for angle). Also started on the ammunition rails.
cheers sascha
  • 5 months later...
Hi all, the past months i had quite some work to do, so not much shipbuilding. Also study of the original builders plans revealed more differences to the model plan i started with. Long story short, i had to re-start with the entire bridge structure (lenght,width, position of supports, upper bridge has addtl deck level, steel girders for support, etc). Some photographs…
still work inprogress, loosely arranged for pics.
Glad to see you back and to admire your work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
That looks amazing.  I am in awe of the skill that you have.  This ship is going to be magnificent!
Brad/NavyShooter
Just a small update (not much time to buil) .deck torpedo tubes were made (no machines, so couldnt make gears etc). Spent time figuring out were the big vent goes (middle of picture) as model plan with which i started the build is very different from builders plans which i got some months ago. Also funnels are painted. As you can see, the colour is different. Shame, because its the ssme brand&code but they must have changed the recipe… annoying for work going forward (eg touch up, corrections). But this will be „crew re-painted on board“😎
cheers sascha
Nice, crisp work indeed. Are the rail stanchions around the platform commercial pieces or did you turn/drill them yourself ?
Edited by wefalck
Yes, it's these stanchions we are talking about. They seem to be of really good quality, etched from both sides with exactly aligned masks. They look almost like turned ones.
Saemann is known for good quality and they have been in the market for many years. Unfortunately they don't do anything in 'my' scale (1:160).
