I decided to make a companion for my Sopwith Camel (posted here a while back)  The Fokker DR 1 seemed most appropriate choice. If I had to chose the most enjoyable build, I’d say it was the Camel. In saying that, I’m happy with the way the DR1 turned out.
cheers
Steve.
7DE36F1F-B076-4B5F-9383-A7DB51839AE7.thumb.jpeg.a999700911a7e90a18fffc634618f3fa.jpeg06114AED-E81B-4B55-872F-A7148C89553A.thumb.jpeg.0802d3b95a665001c948779a5103e471.jpeg33C973BD-C15A-49CB-AF45-8457B393FE0F.thumb.jpeg.7c7a65aa4299f478334c1c52e991e76a.jpeg0884DCF2-B5CB-46E2-A42E-6504CE4E25F0.thumb.jpeg.c6e8846a57c103953743ac83144f6fac.jpeg
Hornet
             Current build HMS Granado - Caldercraft
             Completed Ship Builds. - USRC Harriet Lane - Model Expo.
             Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
sweet look'in model..........very nicely detailed! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Very nicely done!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Sweet!
A few years back I tried to do a sopwith from model airways but the cast pieces were really a turn off and it is all sitting in a box in the closet.
Paul
Current Build: HMS Winchelsea 1764 1:48
Completed Build: HM Cutter Cheerful-Syren Ship Models 1/48
Completed Build:  Artesania Latina Bluenose II
Completed Build Lady Nelson
1 hour ago, PRS said:
Sweet!
Cast pieces on the Artesania Latina kits are quite well done. My biggest issue was that gluing was done with cyanoacrylate glue which I am allergic to. I used 5 minute epoxy which was awkward at times.
Hornet
1 hour ago, CDW said:
A lot of wing area, a lot of lift. Lots of drag, too.
True, but they were very maneuverable and with the engine spinning, they could turn really tight  turns to the right.  They did have their issues though
15 hours ago, yvesvidal said:
There is a gentleman who made a replica of that plane in one of the local airports, Franklin County Airport, NC. That plane can take off within 50 yards and is a pleasure to see flying.
Your model is remarkable.
Yves
There is also one at the Old Rhinebeck Aerodrome which fles every weekend in their summer airshows
Jack
Current buildUS Constellation
actually,  the more critical time was landing.  the pilot had to be steady,  because too much pitching from side to side,  would allow the wing to hit the ground.........and that could be very bad.  some did not end well.   there were structural issues down the road with the top wing strut mounts rotting.  this would cause the plane to lose the top wing in flight.  I think it happened to Lothar,  the baron's brother.   head injuries and engine problems added to the cons of this aircraft,  and when the D VII rolled off the assembly line,  all orders for the Dr 1 was canceled.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
