I remember those kit supplied window frames being one of the trickiest parts. I was never satisfied with my outcome. Good on you for looking for a different approach to match the rest of your models colouring.
Cheers
Alistair
Current Build -
CiscoH
As you know I recently started the AVS myself. I just wanted everyone to know I get more information, how to and problem solutions then the included instructions or even the Luck instructions.
Current Projects:        Completed Projects:
Armed Virginia Sloop - Model Shipways - 1:96                                      Muscongus Bay Lobster Smack - Model Shipways - 1:24
Phantom New York Pilot Boat - Model Shipways - 1:96                         18th Century Long Boat - Model Shipways - 1:48
        Norwegian Sailing Pram - Model Shipways - 1:12
        Lowell Grand Banks Dory - Model Shipways - 1:24
Happy Saturday afternoon MSW.  Today I continue trying to make windows.
Last time I made an oversized practice window which below I have trimmed down and I think it looks ok.  Here are my 2 oversized test windows and the kit walnut one.
This time around I made a new window the correct size although its still a practice version.
First off I copied the angle of an outside window and made a cutting jig, similar to what I did with my mitered coamings.  I used a large chisel initially but later used the largest of the 3 mini veritas chisels and it worked fine too.
Everything is very oversize to be trimmed down at the end.  The most difficult part wasn't cutting the angled lap joint, it was making the 2 opposite pieces of frame the same size.  Still working on the best way to mark this.
One other challenge is figuring out which direction the angled miters are cut.  Doodling pictures did not help me visualize; I bet if I had worked in Sketchup I would have eventually gotten it but thats even more free time gone.  It turns out if you cut all the angled joints on the right side of the above jig it makes the Left-side window (because I wanted the side members of the window (stiles?) to run all the way up/down.  Presumably when I cut the joints with with mirror image left side of the jig it will make the right-side window.
I formed the half-laps same as last post, which led to:
I marked the frame with triangles and then put it together with Elmers white glue.
Once it was dry I flipped it over and used a compass to determine the centerpoint of each side and then the big chisel to score a mark across the frame, then gently chiseled out the score to a V shape.
I purchased the smallest Vallorbe rectangular file I could find which turned out to be 2/64" thick.  I used this to file the V cuts into square.  Despite the tiny size it still makes the rabbits look too big.  But this is a test window so I soldiered on.
I added one window muntin.  Cut to fit the size of the slot its noticeably thicker than the previous test window muntin.
Once it dried I filed the transverse slot and added its muntin.
And once that was dry I trimmed the window frame down to its proper size.  I thinned the muntins by filing then equally each side which worked pretty well.  The window is surprisingly rigid considering how tiny it is.
And here is the new window overlaid onto the left side of the stern, kit window on the right for comparison.  It looks like I need the thin the frame edges even more but I am planning on adding some exterior window trim pieces which will take up some space.
I have to enlarge the stern window openings at the top some and I think I will put backers in on the top and bottom where there is a little more room.
Next up adding some window trim and deciding if I keep the muntin angles like the kit or change them so they follow the curve of the stern planking.  Or something inbetween.
thanks for reading
Cisco
Edited by CiscoH
That is really impressive! Especially when we see your thumb and realise how small these windows are. The alignment of the outer windows with the stern was also my problem - the kit supplied windows that go there end up looking crooked. I didn't try to fix that but it remains a vague  irritation every time I look at the bum of my AVS.
Cheers
Alistair
Current Build -
Love the generosity in sharing your process Cisco! The gorgeous results are one thing - how you get there makes it even better!
hamilton
Good Sunday evening MSW.  Here in Delaware Daylight Savings has struck so its dark at 5:30pm.  The drama those with kids call "Halloween" has receded, time for an update.  Today is Windows Part II and I am afraid there will be at least one or two more to come.  Like everything in this hobby they are a lot more complicated than I expected.
My big difficulty, besides simply the challenge of working with such small parts, was making the same size windows.  Its easy to make several Almost the Same Size frames but with all 4 of them side by side tiny differences are glaring.  So I tried to think up a way to make my parts identical.  I also wanted skinnier muntins; my previous beefy 2/64" ones weren't going to cut it.
My first solution is pretty practical and thankfully simple - a pair of stop blocks.  First I glued one on the closer side of my angled jig.  I pushed each frame part snug against the stop block and cut the angle with a Veritas mini-chisel as before.
Then I glued another stop block on the other side of my jig to push against so my second cut was at the correct interior frame dimension.  Repeat with another piece and now I had the 2 side pieces of the frame, both exactly the same.
I made another jig that cut the exact same angle but with closer stop blocks to make the bottom and top pieces of the frame (the window frame is slightly taller than it is wide).
Once I had my 4 frame pieces I formed the half laps same as before.
Once glued up with clear-drying white elmers glue I sanded both sides of the window flat with 220 grit.  The window frame is skittery and likes to escape fingertips but I finally got the frame to a consistent thickness.
Then as before I marked the center of each frame with my drafting compass and gently pressed the larger chisel across the frame on the pencil marks.
I used the veritas mini-chisels to cut a tiny wedge at each chisel incision.  In my previous post I used a file to cut the muntin mortises but my smallest file is 2/64" wide.  I couldn't find a thinner one so I went back to using my hobby saw (see the last pic in this post, its the red handled one everyone has) which is exactly 1/64" thick.  If you go slow and gentle it will sit in the tiny wedges and cut a perfectly even 1/64" mortise.
Then I used my veritas mini-plane (what would we do without Canadian ingenuity?) to sneak up on a 1/64" muntin.
I would get it pretty close then use some 220 grit on a small stick to smooth the muntin to its final 1/64" dimension.  I found it easier to work with if I left it big, as you can see below.
Once it had dried I carefully trimmed the muntin down until it was even with the back of the frame (chisels must be sharp and mind the grain) and very very carefully cut a mortise in the muntin with first a chisel and then the hobby saw, supporting the fragile parts with my finger from underneath, and then shaped and glued the second muntin, oversize, in place.
One it dried overnight I trimmed it up, a little more sanding to get it the correct shape, and inserted it into the stern.  Here I have both port side windows installed.
David Anstcherl talks about lining up the muntins so they make a perfect arc across the stern.  I don't think I have that in me this go around.
Below is my hobby saw and the 2 starboard windows with their vertical muntins drying in place.
Next up, assuming the windows look good, is trimming down the interior stop blocks so they don't show through the windows, trimming my panes of "glass" (I'm using mica) and then making some exterior frames to hold the windows in place and smooth out the silhouette of the raggedly cut window holes in the stern planking.
thats it, thanks for reading
Cisco
Edited by CiscoH
More Windows
Well I'm back.  Windows have been driving me crazy and I'm happy to say this update will finish them for better or worse.  Here's an example to remind us of how small the darn things are.  I have had good luck getting the muntins to 1/64" reliably so thats a plus.
I made all 4 windows and filed them to fit.  It was a great day!  And they looked acceptable to the naked eye, until I took a picture.
To my eye the furthest starboard and port windows looked off kilter.  Their vertical muntins seemed to be angled outwards.  And the inner and outer horizontal muntins were not lining up.  I think its more noticeable due to all the strong horizontal and vertical lines around the windows.  See my cartoon below - in a row of stern lights the line of the vertical elements should converge somewhere far above the stern, as in picture 1.  There is also the tapering edges of the stern, what the instructions call the fashion pieces but I think are called something else, that further emphasize this convergence.
My window axis are more like picture 2.  There is also the added lines of the stern planking which normally would be painted and less visible.  When the horizontal muntins don't follow the horizontal line of planking its glaring.
You can also see a small gap at the base of the the inner starboard window where I overthinned the wood between the windows.  Nothing for it but some planking re-do and window deconstruction.  In the new windows I exaggerated the angle of the outer vertical muntins and shifted the horizontal muntins in 3 of the windows so they followed the line of the horizontal stern planking better.  This made the muntins often not centered in each window frame.
Being a traditional-minded builder I wanted mica for my windows and found a cheap (10$ ish on Amazon) bag of precut pieces; they are the size and thickness of microscope cover slips.  I found tracing with a scalpel blade, then bending or cutting with scissors the easiest way to shape them.  Sanding or filing made the edges fray too much so i tried to slightly undercut the panes.  They are hard to see once in place in these pics.
And then how to make the window frames stay in place?  I tried making a sill but I don't think it looked appropriate in such a small vessel, see below, so no go.
All the other genius ideas I had for fitting a secondary frame were not working so I decided KISS and why note glue them directly in place?  First I tried putting glue in the window holes and then setting the window frame on top but it always smooshed the glue out onto the mica.  Eventually I found it easiest to put a very little line of white glue on the top and bottom of each window frame with a toothpick.  Using a tweezers I then set them bottom-first, then swung the top in.  They were already a snug fit and the glue filled the gap fine.  A veritas minichisel worked perfect to scrape any squeezeout, which if you use very little glue was mostly none.
Here's my finished product.  I am now tired of windows and this is whats going to stay.
I had to make some compromises to follow the line of the planking; none of the window openings are exactly symmetric to the other side and the windows are also each a little different.  I suppose it it ends up really bothering me I could hang a jollyboat over the stern to hide my sins.
Ok done with windows.
few other pics- I was at the Delaware Antique Show last weekend and saw this.  The base is amazing and way out of proportion to the fairly drab model ship and I thought it was pretty funny.
And yesterday I got my copy of Fubbs which I have been anticipating for the last year.  If you like David Antscherl's other books you will like this one too.
Here's the page on windows;  too late for me on this model.  His muntins are perfectly aligned, of course.
ok that it.  Thanks for reading all.  Have a happy Thanksgiving, those of you who celebrate it.
Cisco
Edited by CiscoH
Those windows look very good to me! So much better than my effort with the kit supplied ones and even the wonkiness of my effort doesn't bother me anymore.
Cheers
Alistair
Current Build -
Hi Cisco, I agree that your windows look very good. Really like how you used mica for the glass. We’ve all come to realize that cameras cannot be satisfied.
Best Regards……..Paul
Really nice explanation of how you made the windows. I remember that same challenge with my Haying Hoy. Now I am configuring the windows using cnc which should do a good job. The biggest obstacle is figuring out how to get a good enough bitmap and then converting that  to vectors. I really like your project.
Ian
Well on to planking the main deck.  The kit comes with a detailed picture and the LaukStreet practicum follows this scheme closely.  Basically all straight planks except the outside one which is curved to match the sheer.    The fore ends of the outside planks are nibbed into a secondary plank called the Margin, or Nibbing, plank which parallels the waterway.
I think this was done because its easier (all the planks are straight and the same width, again except the outside one), the Margin Plank nibbing looks cool, and maybe also because its how Dr Feldman did the original model.  (Although when I looked at the pictures in his book he has 4 nibbing planks per side while the AVS directions show 3.  Again, maybe to make it easier).
I have always liked the look of curved deck planking and I never liked doing things the easy way so off I went looking to make it harder on myself.  I have used Cheerful as a source of inspiration for this build and I really like the decking Chuck did which was curved and scarfed.  After a lot of thinking and the appropriate "mmmm hmmm" noises I came up with the following:
I changed from equal numbers of planks on each side to a center plank, shown in the drawing above as a 1/2 plank in the middle, and 9 roughly 3/16" wide planks each side.  I was having a lot of trouble getting the hook scarfs to cooperate especially the aft one which was weird and too long.  Then I realized the hook scarfs are only used at the bendiest parts of the hull.  In the Cheerful there is no quarterdeck or cabin so the deck planking runs all the way to the stern.  In the AVS the main deck is only 2/3 of the ship's length and the aft main deck section doesn't curve much atall so it probably doesn't need any fancy joinery.
So I did another template:
I like this one better.  From above its not as obvious but when you sight down the length of the ship the planking clearly curves.  I need the currently uneven hook scarfs to be the same length so a small adjustment pending there.  I got rid of the aft hook and now the planks flow much better.  And if I want it curvier I can make the central planks a little fatter amidships.
Throughout all this I found both Chuck's Cheerful instructions (Chapter 8 ) and Eric W's super clean (and well documented) Cheerful builds very helpful.
Next up is cutting the planking from my holly billets and not second guessing myself.
thanks all
Cisco
Edited by CiscoH
Planking the deck!  A mid-flight update.
After my last post I spent some time struggling with my planking plan.  I liked the hooked scarfs and curved decking but worried I was making it too busy.  The AVS also has that small extra grating, off center on the fore left side, that made life difficult.
Version 2 of hooked scarfs is below on the Left.   On the right I tried remaking the decking with nibbing and a margin plank (but still curved).  It got uncertain on the port side where that extra grating is, which is placed to exactly interrupt the flow.
Eventually I settled on the Version 2 curved hooked scarfs and by shifting the small grating a little I got it to line up with the planking better.  I was worried I'd end up with some bizarre wedged hooked plank cut in half.
I had drawn in the deck beams and traced the outline of each hatch and grate.  But these were not perfectly accurate as all were wider by the thickness of a pencil tip.  And they needed to be closely centered in a hull that (it turns out) is not completely symmetric.  After some agonizing over my planking scheme (I want a 3 plank shift) and realizing that  a mm or 2 either direction changed a lot of variables, I put having the plank shift finalized on hold until I was further along.
Below I used my drafting compass, which is quickly becoming my most important tool, to find the center on the deck. It wasn't an exact straight line.  Then i glued down the center plank.
And now that I had a definitive centerplank to mark from I penciled the plan onto the deck.   As I said before the sides are not perfectly symmetric so there will some fudging.
Next up is adding consecutive strakes to either side and navigating the forward central grate.  At present it looks to fit perfectly even with the next planks but we'll see.
at least its not another darn window.
Thanks for reading
Cisco
Tonight is another mid-flight deck planking update.  I had thought I was done with the Thinking Part but Lo I was mistaken.
I was still happy with the curved outside and straight inner planking run.  Then I tried to figure out my butt shifts.  The Model Shipways AVS plans don't have any butts, the easiest way to deal with them I guess.  I measured my hull planking and the longest plank was 7", or a scale 28' long, and a 3-butt shift.  So I decided on 7" long decking, no problems, but what about keeping the hooked scarfs from being too long and not having butts in awkward places?  A lot harder than it first seemed.  A week later, after studying Cheerful, Comet, and Speedwell's plans and a lot of erasing I settled on a) 4 shift pattern, and b) where this pattern would start.  This first butt of course dictates where all the other joints will be and I didn't want odd 2 foot planks at the ends OR a joint right next to the various hatches.  (As an aside, I have been thankful I purchased so many of David and Greg's books AND plans, even if I never end up building those specific ships.  They have been vital in helping me think through so many different tasks like this one.)
I also had to figure out how to integrate the planking with the hatches and coaming.  The fore grate is surrounded by notched planks.  Fitting the next outer plank so it slides into the notched areas took some slow repeat sanding and many fittings but went ok.  The port side went fine as I could leave the front end long and trim it later; the starboard side had to be fitted to the notches AND into the curved waterway.  Pictured is my second attempt- it was all too easy to oversand the pointy part and leave a gap like I did here.
Third time worked out though.  Also shown above is me using the wrong wood.  Both outer planks (the short ones) in the middle section are basswood, which is very hard to see.  I realized it last night and replaced them no problems.  The colour is very close!
Here is a pic of the deck with most of the furniture in place.  The big central hatchway is not square, its more of a trapezoid.  At the time I didn't want to remake those darn mitered half lap joints and as usual its come back to haunt me.  You can see the hatch skews to port a little when lined up with the decking (its even at the back, which can't be seen in this photo).  One of the upsides of the basswood planks mistake was the opportunity to replace it with a wider one to help compensate.
The fore grating fits well so now I'm notching around the companionway (which is thankfully actually square) and the large hatchway as my next steps.
I made some jigs to help with notching 45 degree joints (laying on the deck above) with more accuracy as I eyeballed it my first go around.
Well thats it for today.
Happy Holidays MSW!
thanks for reading, Cisco
Good Sunday evening MSW.  Another plank-the-deck update.
I thought I'd recap my plank preparation technique.  I have 2 billets of holly that I have cut aprox 1/8" thick slices from.  These are rough on both sides and too thick to directly plank with.  I don't have any sanding or thicknessing machines (and regardless prefer to do it by hand anyway).  To cut my planks I use the below device to slice off a strip a bit wider than what I need.  I really like being able to control how wide my planks are, as opposed to getting pre-cut planks that are all uniform.
After cutting off a plank I thickness it with my handplanes; basically a few strokes on either side to remove the roughness of the bandsaw.  Holly seems to be very forgiving and gives a glass-smooth surface even going against the grain if the tool is sharp.  I hold the one end with my finger while planing; it pays to leave the strip long to start so you have more to grab onto.
Both edges are planed in the same manner to get them pretty close to square; I also use sandpaper attached to thin strips of wood for final shaping.
The long straight planks are easy.  The tough ones are the wide miters and the hooked scarfs.  After several holly discards I started making the weird shapes out of scraps first.  This one was especially tough- a mitered section incorporated into an overall curved plank.  But once I got the test piece done it was easy (well, a little easier) to trace it onto my holly stock and trim it close, then fine tune the fit.
And here it the final holly piece after fitting.  I hope it can be seen the whole plank curves as well, so you have to fit the 2 miters while fitting the curved section.  I found it plenty challenging.
And below is that piece glued in place on the port side of the main hatchway.  But.  As I mentioned before my main hatchway is a trapezoid, not a rectangle.  I kept getting gaps that were driving me knutts until I turned the main hatchway 180 degrees and it overall fit better.  Except now the port back miter was off a little so in the below picture I have removed the offending plank and once a new one was fitted it looked much better.  But that now emphasized how off the rest were so the whole row of short planks clearly had to go.
I think I've planked this deck 3 times by now.  The miters around the main hatchway are (a little) different sizes but its as good as its gonna get; time to keep moving.
And here's where we stand tonight.  Some of you may be able to form planks perfectly so finger power alone holds them in place.  I still like to place brass pins and wedges, like I did on the hull, to tighten up any "gaps."
Once all the planking is in I will scrape it flat, then sand and finish it with water based polyurethane like the rest of the ship.  Then its on to planking the cabin which will have NO HOOK SCARFS or MITERS.
thanks for reading
cisco
Nice going with the planking! The holly looks great - those little planes are nice too - are they from Lee Valley? Also - that marking tool in your first photo - what is it? And where did you come by it? In any case - planking the cabin will be a nice relief after this exacting job.
hamilton
Thanks Hamilton.  The bigger brass plane is from LieNielsen, the tiny one is from LeeValley.  The marking tool is also Lee Valley- a string inlay cutter.  Very heavy duty and astoundingly cheap at 115$.  I use it and the tiny handplane (and their mini chisels) all the time.
https://www.leevalley.com/en-us/shop/tools/hand-tools/inlay-and-veneering-tools/69874-veritas-string-inlay-tool-system
Good Evening MSW!  Here in Delaware its snowing like crazy.  Time for Main Deck Planking update #3.
I got the last main deck planks in.  No new surprises once the hooked ones were fitted.  Only sad part is all the deck furniture will hide most of it.
Here's the initial finished state.  Some glue smudges, a lot of pencil marks, and the uneven thicknessed planks make it look pretty rough.
I tried using this tiny scraper I got a while ago.  It works surprisingly well - no tearout atall and it did the port side of the deck great.  But after a lot of tiny shavings and not much progress leveling the more uneven planks on the starboard side I switched to small blocks of wood with 180 grit sandpaper.
That got it leveled fine, so i switched to 220 grit, vacuum again, and first coat of water based polyurethane.
I'll do another coat of polyurethane tomorrow and then move onto the cabin planking.
thanks for reading
Cisco
Awesome work Cisco, you should be VERY proud! Didn't like the snow in Wisconsin so we moved to New Mexico. We'll get snow here as well but it's gone by 10 am! You are doing a wonderful job on your building log, I wish I had the talent to do one myself. Keep up the good work and God bless.
Top notch work, Cisco -
I really like how you angled in the planks around the hatches.
Dan
Stunning work Cisco!
This is turning into the bench mark for an unpainted AVS. My route, painted, was an easier way, but yours will turn into a much more admirable outcome!
Cheers
Alistair
Current Build -
Good Tuesday evening all
In today's post I am planking the quarterdeck; all 2 feet of it.  I wanted a fan-shaped pattern of decking which as you'll see didn't work out as well as I'd hoped.  I also wanted to try out my Veritas Inlay Thicknesser.  When I lay in the main deck my wood pieces started out a lot of different thicknesses.  I used my mini-plane to roughly make them the same, but as I ran short of acceptable planks I used a few that were significantly thinner.  It was much harder to bring the surrounding thicker planks down to the level of the thin ones and led to some unevenness of the deck which you can't really see but can feel if you run your fingers across it.
So how to get planking that was the same thickness without the tedium of hand planing or scraping each piece and measuring every 2 inches with a caliper?  (and no for now I am not buying any powered devices.  I want to learn to do it by hand first).  I had bought the Inlay thicknesser a while ago but it had to be sharpened which was Work so I had put it off.  No longer!
The instructions have you make all the planks all the exact same width, except the 2 side ones trapezoid to fit the last uneven space to the hull bulwarks.   My eye was always drawn to these edge planks as looking uneven so I tried a fan pattern.  (The Fore part of the quarterdeck is slightly wider across than the Aft portion.)
First I broke out my tick strips and measured the front and back of the tiny quarterdeck.
Then I drew in lines for each plank.
This looked slightly wonky to my eye but I figured I could adjust the lines some as I put in each plank to make them look more regular.  A lesson here - if the plan is off and you accurately build to the plan then the build will be off too.  I should have redrawn some of those lines.
Now to make even thickness planking.  I quickly discovered the Inlay thicknesser couldn't remove much wood at a time.  It worked best when you shave the stock to Almost Thin Enough with the miniplane, then use the scraper to bring it to final thickness.
The planks weren't perfectly the same thickness but they were a lot closer than before.  I added all the planking one at a time and used a pencil to indicate caulking and yellow glue, same as before.
Here it is before sanding and evening the edge:
And here I have sanded it flat (180 -> 220 grit), leveled the edge, and removed some glue squeezeout that formed underneath the overhang (which was a pain to get at), and applied 1 coat of water polyurethane.  I put all the oddly-shaped sanding blocks I used onto the deck so i remember them in the future.
It looks ... ok.  My fan shape didn't "fan" very well.  I like the port side but I may replace some the middle starboard planks with better shaped ones.  The wheel assembly goes directly on this deck so it will probably hide things but I'll have to see what my OCD does overnight.  Your eye really picks out Not Parallel lines.
Well once thats resolved next up is the entrance facade to the cabin.  I'm thinking flat paneled doors are boring; maybe doors with lower raised panels and upper windows?
thats it for tonight, thanks for reading, Cisco
Well OCD (and a gentle shove from BE, thank you Sir) won out.  I redid the quarterdeck.
Here's the finished version of Quarterdeck #1.  The starboard side is too uneven to leave be.  I marked the offending planks.
I ended up taking the center plank as well.  I had purposefully made it wedge shaped so each side could fan out and I think I made the fore end too fat.
Next some alcohol applied with a q-tip and gentle chiseling.  The strips came out fine; at this point I am depressingly skillful at errant plank removal.  I made some new planks (and did a better job getting them equal with the Inlay Thicknesser), redrew my planking lines, and then fitted all but the center plank.  Last time I glued in the planks one at a time which seemed logical, but once its glued in you are committed.  THIS TIME I placed all the planks in place, before glue, and thinned some of them until they looked more equal.  It took several adjustments; a little extra width really shows up I guess because the planks are so short.
Here are the new planks glued in place.  Not so pretty.
This round seemed to level really fast, to the point that the new planks were noticeably thicker when viewed from in front.  I had to deliberately sand them thinner to make the edge even.
And here is after 1 coat of poylurethane.  To me the lines are much straighter; ironically I don't notice the lines really now, whereas the last effort the crookedness really stood out.
Alright I'm glad I fixed that.  Looks much better now.
Ok, on to the cabin facade and doors.
thanks for reading
cisco
Edited by CiscoH
It looks superb! The upper deck is where I really applied the plank fan. Much more fanning needed there...But it doesn't look like you can do anything wrong!
Cheers
Alistair
Current Build -
Well its been over a month.  Vacation and work took their toll.  I'm trying to bring my AVS up to the Joint Clubs conference as an "in progress" so now its crunch time.  While anything beyond deck furniture won't happen in time; I don't want any basswood showing.
Next up is planking the cabin entryway.  Below is the kit door picture.  I tossed around how I could make the doors more aggravating to build- maybe a window in the top of each one?  maybe double raised panels?  After looking at my drawings I eventually decided a single raised panel looked better than any of my other wacky ideas.
The door frames were simple butt joints, highlighted with pencil.  If I had more time the half-lap joints I used for the companionway coaming would have been sturdier to work with.  But they turned out ok and were very solid once glued onto the basswood underlayment.  For anyone who noticed I deliberately made the door frames inset so they would stand out.  In reality this would have made the doors only open 90 degrees and been a pain to traverse but in this built artistic license overcomes functionality.
Next I test-fitted my raised panels.
The panels were challenging due to the flat reveal around the raised portion.  It took a few tries.  I scribed around the edges for a rabbit (shown below), then scribed further back for the borders of the raised portion of the panel.  Tricky work although you are essentially cutting to a line.  I don't know how I functioned before discovering my fine drafting compass.
After planking the sides and middle of the cabin entryway I made the small base trim piece.  Its fragile; I first made a "pretty close" version out of basswood (top piece), then a second try with holly.  Once I got the bottom scribed as closely as possible I used the above compass to trace the width I wanted and cut it out.  Then I attempted not to throw the base molding out (it looked exactly like cutoff scrap).
Then I glued the top part of the door frame in, final fit my raised panels and glued them in.  I forgot to say I pre-finished the door frames and panels, and pre-drilled for the handle and hinges before the frames were glued on; much easier to do that stuff on the bench.  The handle and hinges were added with a touch of epoxy, then I used the below scheme of go-sticks and rubber bands to keep the basemolding in place while its glue dried.  Sorry I now realize that pic is a little out of focus.
Well thats progress as of now.  This week I will be making the narrow planking to cover the roof of the cabin.  And if all goes well I'll bring her to the conference for laudits and critique.
thanks for reading
Cisco
Cisco -
Coming along very nicely.
Looking forward to seeing you and her in New London.
Dan
