British WW1 Mark IV tank by King Derelict - Emhar - 1/72
17 minutes ago, Roger Pellett said:
It would seem that much of the reason for these early tanks would be in their shock value.  Why then would you be worried about hiding them from the enemy with camouflage?
Its a good point; I wondered if it was considered to be useful to reduce the chance of being seen by aerial reconnaissance when they were parked up behind the lines. But then netting would be better. I'm still learning a lot and it seems that there are some varied opinions out there on the British colour schemes. The Germans did use quite complex paint schemes by comparison. I think I have read that teh British abandoned repainting in green / khaki and just left them in as-delivered grey at the end.
Alan
Link to comment
Share on other sites
The picture you posted in #29 looks pretty monochromatic to me.  In the past, I've seen other photos of the early tanks at the front and they all seemed to be the same.  Camouflage really wouldn't have worked at the front as there was next to no green anything except maybe the stagnant water in the shell holes.
Link to comment
gee.......sorry I missed this one :(   cool look'in model!  camo wasn't a big thing during WWI.......toss on some dirt and branches and you were good for the party ;)   sophistication came into play towards the end....likely a few 'Picassos' started the fad :D   the use of camo was a gradual thing......unit markings was a big draw though.....
...as for the olive drab..........I have many shades of olive.  it all depends on how worn you want to show her.......faded was the rage,  as I recall.......
very nice looking model :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks for the kind comment Denis. Its a relaxing and fun build and seems to be painting up nicely.. I'm tempted to try another in a trench diorama.
The lack of colour photos means that evidence of the real colours on WW! tanks is very sketchy. I'm experimenting with the mud!
Alan
Link to comment
I painted the raised edges of the tracks with gun metal to show bare metal and dry brushed more randomly onto the track plates. I think the bare metal, remnants of paint and rust is a starting point for adding mud and dirt.
A thin coat of acrylic clear coat was then applied ready for oil based washes
I dabbled with the mud patch to see if I could improve the mud quality. A welcome break from printer voodoo
Thanks for checking in
Alan
Link to comment
That is looking so cool.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
very nice work
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
I air brushed a light mist of buff all over the tank and then deepened the spray over the lower hull to simulate a dusty vehicle rather than a muddy one (might try that next). Its done a nice job of knocking down the decal contrast too.
I made a ditching beam from some spare wood stock and dirtied it up. Its just placed for size at present. I'm wondering if it should have iron bands at each end but my pictures found so far are unhelpful on that issue. I have chains to secure it on the ditching rails.
First I will air brush a matte finish and then add the beam and chains
Thanks for looking
Alan
Link to comment
Nope, no Iron bands... one thing I would do is run a file down the corners though and make a few random chips in the perfectly flat surface... Also they would be dark like a freshly tarred railroad tie.... Not black but a very dark brown...
An image of the ditching beam and how it was rigged to help in crossing a trench on a Mk IV.... (no iron bands)
Another thing you could do for a Mk IV is a fascine, early ones were a big bundle of sticks... here is an image of the movement of Mk IV tanks into the buildup for Cambrai.... They have both the plain ditching beam and the Stick Fascine... The Fascine would be dropped into a trench before crossing and were non-recoverable....
mark_IV_tank_with_fascines_cambrai_first-world-war.jpg.7f33f4b612d9777ed5222f5600746145.jpg
It's the way they (the tanks) were issued...
Later, they used the Timber Fascine... But, it's rare to see a timber fascine on a Mk IV tank though, they came into use shortly before the Mk V became the main heavy tank... (although they were used on Mk IV's)
British_Mark_V_Tanks_With_Crib_Fascines_1918.jpg.c43d88acf43703194298f4753d9293ab.jpg
You can also see the banded ditching beams on these Mk V's not only were they double banded on the ends they were chamfered for their length on the corners and the tanks carried at least two and up to four of them....
As you can see later in the war they also had short timber bridge sections, (as they left the trenches behind) the timber fascine was used just like a ditching beam, chained to the tracks before they attempted to cross and recovered afterwards... the bridge sections would be left behind once the trench was crossed.... Of course in the last pic you can see the results of the first ideals of a "Tank Trap", ditches dug diagonally crossing the route of advance to high center the tank... A ditching beam doesn't work very well for a tank high centered like this... Ditching beams were mostly intended for exiting shell holes with steep sides that the tank couldn't get traction on.....
In warfare technology advances very quickly....
Edited by Egilman
Quote:
Link to comment
Superb work Alan,  that dusting  sure  makes a difference  - loving what you are doing.
OC.
Current builds
Completed works.
Link to comment
Many Thanks Egilman. That is great information and this photo finally explains to me how the ditching beam worked. I had assumed it was placed manually (like sand ladders) but now I can see that the tracks carry it under the tank and then back over to the front - explaining what the ditching rails are for. I thought the rails were just for securing equipment.
I did find this video showing the ditching beam in action. I have to caution that some viewer may find the gritty representation of WW1 trench life in the early part of the video to be unsettling
https://m.youtube.com/watch?v=Okahfp3GrWM
As always, your research is a huge help. I have shortened the beam to look more like the photos and I have distressed the rails now that I know what they are for
Alan
Link to comment
The information provided by Egilman was very useful and drove some minor changes. The ditching beam was shortened to be more like those in the photos. I also darkened the beam and added rust and paint chipping to the ditching rails with a slight dry brush of gun metal to suggest some scraped bare metal.
I added chains to the beam using the photo to gauge the length and made a trial stowage on the rails.
Thanks for Looking and Happy Thanksgiving to those in the US. I'm thankful that teh turkey looks like its defrosted on time.
Alan
Link to comment
My pleasure Alan, My pleasure...
Quote:
Link to comment
Oh the horror! :D:D:D
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
What a cool subject Alan, doing a great job on this one!  The design is so simple, it almost looks futuristic or even Mad Max-ish 😀
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thank you, Mike. It's been a lot of fun working on these Emhar WW1`tanks and learning a lot as I have been building them. They are simple to build but interesting paint and try new ideas out.
Alan
Link to comment
I air brushed the matt coat and tidied up a few details and installed the ditching beam and chains. I think this is complete. Its been a lot of fun and I am tempted to get another one and make a small base / diorama to show it rearing up on the lip of a trench - and then I could get a bit wild with the mud effects.
Thanks for looking and commenting
Alan
And to show the Mark IV and the Whippet with the Renault and the AV7
Link to comment
Very well done.  It looks good on it's base and a diorama has a lot of potential.
Link to comment
Really nicely done Alan  - they all look really smart.
OC.
Current builds
Completed works.
Link to comment
A very nice collection.
Great work.
Regards, Patrick
Link to comment
Nice battle of tanks, all of them are superb, Alan
Well done
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Well done
Thank you very much Edward. They were all a lot of fun. My thinking with these kits was to improve my painting skills which were horrible. The kits don't take too long to build so most of my time was spent painting and trying new ideas. They were also inexpensive if I made a real mess. I think my painting is slightly less horrible now and I really enjoy these little tanks so there is likely to be more.
Alan
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
