This is something quick to fill in time waiting for the X craft PE to show up, This was a bargain buy. It claims to have new parts (2021) but it feels like an old kit. There is good detail on the main parts but there is some distortion at the edges and quite a bit of flash.
A decent number of parts and decal options. Elastic band tracks unfortunately
The undercarriage is interesting. Three pieces make up the road wheels, suspension and skirt. The assembly is shown at top
The turret was a real dogs dinner and needed a lot of cutting and filing and filling. I haven't followed assembly instructions which has you put the tracks on before adding the side pieces to the hull. Painting looks too difficult if you do that. So the plan is to temporarily add the top pieces to the hull and paint the camouflage then remove the top pieces and put the tracks on.
The chosen paint scheme will be a Churchill at El Alamein 2 so a dusty finish.
The major parts have had a coat of Mig One Shot Brown primer and look good to continue
Thanks for looking in and I hope everyone has a great weekend
Alan
Another cool project  - I'm  in  Alan..
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
All these  1/72 scale  tank builds  made me  think  - wouldn't it  be brill  ot see someone  take on one of those  1/72  Airfix  Battle sets  that  was  basically a  dio  in a box.
OC.
Edited by Old Collingwood
Current builds
Completed works.
OC.
You are right. I really like a diorama setting but they take up so much time. I have a thought for a small WW1 diorama that might be small enough to try
Alan
There have  been some miniature dios here.  If I remember right Jack12477 did several.  Basically a couple vehicles and bit of shattered building.
I'm here brother, those 1/72nd kits are looking much better than I remember them eons ago...
Never could get into them, but they do offer a lot more room for your battalions....
Looking forward to another masterpiece my friend...
Quote:
Yes, you're right Mark,  but at 1:35 scale.  Alan is right they are bulky, mine are about 12x12x12. Link is in my signature under Sherman tank dioramas
I'm in too, Alan.
Edited by Jack12477
Jack
Current buildUS Constellation
Gret to have you on board EG. This one is very reminiscent of an Airfix Churchill when I was a kid. Hopefully this one will turn out better.
I would like to try a few 1/35 vehicles but space is becoming an issue.
Alan
I'm in too, Alan.
I'm glad you're here. The Sherman diorama is spectacular. A great feel to it.
Alan
On 10/15/2022 at 9:36 AM, CDW said:
Interesting tank. Now I want to read up on its service record. Glad to see you doing this Alan.
Thanks Craig
The wiki article is pretty good.
Churchill tank - Wikipedia
Its an interesting evolution.
Designed to fight on WW1 type battlefields of trenches and shell holes it had great ability on bad ground. The road wheel configuration allowed for quite a bit of damage without loss of ability. It had thick armour that could defeat most German tanks up to the later Tigers even though it was not sloped in any way. It lost out on speed and firepower in the end. An interesting extract about Churchills at El Alamein
They saw action in the Second Battle of El Alamein in October 1942. This detachment, called "Kingforce", supported the attack of 7th Motor Brigade first with three tanks at Kidney Ridge (where one was hit "repeatedly" by anti-tank gun fire (including "friendly fire" from a British gun) and another took "a lot of punishment"), then the remaining five at Tell-el-Aqqaqir. The Churchills were fired on many times by Italian and German anti-tank guns, but only one was knocked out and partially caught on fire. One tank was said to have been hit up to 80 times.
So this one has to be an El Alamein tank
Alan
Alan
Thanks! The 2 ruins are old Verlinden cast plaster kits I had. The 3rd dio is freelanced scenery using rubber rock molds from Woodland Scenics.
Oops my bad ! The other Verlinden diorama is in my M16 Multi-gun Motor Carriage Diorama
Edited by Jack12477
Jack
Infantry support tank, they were tough, very tough, designed to take a direct hit from a 155mm artillery round and keep on going... About the only gun that could take one out with one shot was the vaunted "88"....
There was only one tank tougher, the Matilda, even the "88" had trouble taking those out...
Thanks Jack
I was pondering on a source of rocks and you solved it. Plaster casts
Alan
The crews ears must have been ringing after 80 hits. They were quite a beast.
Alan
Today the coat of sand paint went on. The track covers (whatever the correct AFV term is) were dry placed and stayed on quite nicely. Next I will mask for the grey. The kit calls for a dark grey but the one colour photo I have found shows something a bit lighter. Current plan is Tamiya XF-24 or a touch lighter.
Alan
15 minutes ago, king derelict said:
Thanks Jack
Alan
I recommend using Hydrocal casting plaster, it’s lightweight,  strong and easy to use. Woodland Scenics makes it. ScaleHobbyist is a good source for Woodland Scenics products including the rubber rock molds.
Jack
+1 seconded, best stuff for doing rocks and rock faces...
Quote:
Ditto. Great for your casting. Dries hard, although somewhat brittle for drilling/carving. Best do these operations right after removal from your molds.
An alternative is Sculpt a mold.
Ken
Started: MS Bounty Longboat,
Alan
I would think one hit would do it.  If your referencing the "88", that's the German gun.  Started off as an AA gun and became the main one for artillery and armor.
Thanks for the suggestion Jack and for the link. The rubber rock moulds look a better idea than pouring some plaster in a tray and breaking it up.
Alan
Thanks ken
I think I have some Sculpt a mold in the cupboard. I'll give it a try
Alan
