15 minutes ago, mtaylor said:
I would think one hit would do it.  If your referencing the "88", that's the German gun.  Started off as an AA gun and became the main one for artillery and armor.
Thanks mark
I was thinking the Churchill was a beast but you are right the 88 mm was a highly feared weapon. I don't think there was much that could stand against it.
Alan
With the sand paint dry I masked up for the dark grey. I used tape on teh hull and a mixture of tape and blu=tack for the turret. The Blu=tack deals better with the uneven surfaces of the turret and is easy to mould to shape.
I used Tamiya XF-24 dark grey and I think its about right.
And with the tape off. Its interesting; the grey is sometimes hard to spot because it looks like shadows on the sand colour. maybe that was the intent to mimic the shadows on desert sand
The tracks will now be installed and the top sections will be glued down. Gun need adding and then its time to weather it up and start the base.
Thanks for looking in and for the helpful comments
Alan
That has come out well Alan.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Yep, Starting in late '43, the US army began issuing captured 88's to US units as foreign equipment... (even issued a service TM on it) they had problems converting our 90mm into an anti tank gun, (production issues) and they had thousands of captured examples with tons of ammo and all the technical advise they needed... (captured german crews were more than willing to teach everything about it to our engineers) they adapted it to our radar tracking for the AA role, and extensively used it on the southern France front... (the M1 90mm anti aircraft gun was slightly better as an AA gun, but was a leap forward better an an antitank gun...
It's why the ground forces were clamoring for such a gun in combat... It was the same gun in the M-26 Pershing which could destroy any tank made in the world at that time with a single shot... (including the vaunted Tiger at almost any range)
The only other gun that could come close to them was the 17lber in British service (Sherman Fireflys)
If you were staring down the barrel of a "88" at the start of the war your goose was cooked and served, and you knew it... At the end of the war it was the American "90" taking the role as the king of the battlefield...
Quote:
Nice work Alan, that camo looks spot on....
Quote:
Thanks EG
There is an extremely good WW2 novel called "Warriors for the Working Day" which follows a British tank crew from their training days through to the invasion and fighting in France.
They are given the advice "If an 88 fires at you and misses - bail out - you don't want to be in there when they adjust their aim" Peter Elstob is the author I think. He was a tankie in WW2 and saw action in teh same theatre so its quite realistic.
Alan
The elastic band tracks were wrangled into place. I hated that job with Airfix tanks when I was a kid. CA glue makes it a whole lot easier. The Churchill has a good length of contact on the upper section of track for the glue to grip. The side decks (as we will call them today) were glued into position and the guns and other assorted details were added and the paint touched up.
I have given it a spray of clear coat ready for weathering
I cut the base out of closed cell foam, added a card stiffener and gave it a coat of gesso
Thanks for looking in and the great feedback and likes
Alan
Thanks for that bit of history.  I didn't realize that 88 was used by the Americans. Nor about the Germans willingness to share the knowledge on them.
I made a homemade wash with burnt sienna oil paint and used it to pick out the panels. I think I like my own wash better than the Mig; it flowed better along the panel and detail lines. The Mig stuff needs more thinner to get the same result.
The few decals that go with the El Alamein version have been put on and some more detail paint applied. I dry brushed some bright metal onto the tracks and edges of hatches and likely scrape points along the skirts. I suspect i will lose some of that in the upcoming dust application.
I then air brushed several thin layers of light buff onto the model with the emphasis on the lower sections. Unfortunately I lost a lot of the panel detail but that was sort of expected.
The dull coat will be the last thing to do
I got impatient and instead of waiting for rock moulds I used the old crumpled kitchen foil method. I got some decent low outcrops (and a surplus) so they were added to the base and then blended in with toilet paper and diluted white glue
This needs about 24 hours to dry and maybe another coat of gesso.
The plan is to end up with something like this
Showcasing the Churchill's ability to climb.
Thanks for looking in and all the likes and comments
Alan
Coming along really nicely   - you have nailed the  weathering.
OC.
Current builds
Completed works.
I painted the rocks with a very light buff and then highlighted it with white while it was still wet. The sand is buff which a trace of yellow and some white worked into areas of it while it was drying. After it dried a sprayed it with craft glue and spread some ground ceramic dust between the rocks.
I gave the whole thing a coat of matte to get rid of any glue shine
The Churchill is placed. I need to paint the edges of the base and add a bit more "sand" around the rear of the tracks
Thanks for looking in and the likes. I hope everyone has a great weekend
Sprue Brothers has a 25% off weekend deal on a 1/32 Infinity Vampire - do I dare?
Alan
Alan
Coming along  great  Alan   - love dio's   you can go as  far as your imagination takes you..........
You know  you want to  (with the Sprue Brothers................resistance is  fut-al)   lol
OC.
Current builds
Completed works.
I fixed the Churchill to the base and blended the tracks in with some more sand / dust - and then dropped the whole lot. Thankfully it sustained almost no damage and was easily restored.
1060270216_RIMG1502(1280x960).jpg.934cdf17b321f8cb1abf9ad21ef6e93d.jpg237692001_RIMG1503(1280x960).jpg.19c95c764ca3b62893ec3c7319a838be.jpg
Playing around with the White Balance and the remaining images are more like the real colours
I need to work out a better set up for the photos. The colour rendition is too hit and miss this way although I like the black backdrop
While reading the BBC news this morning I came across this article. A rather counter=intuitive design really but interesting
The tank that could fly into battle - BBC Future
Now that would be a project to play with
I will declare this one to be finished. Many thanks for looking in and the likes and comments
Alan
Very nicely done Alan,  really coming out well.
OC.
Current builds
Completed works.
OC.
I resisted until Sunday evening and then somehow a 1/35 Rye Field Model Leopard fell into the cart as well. I still feel virtuous because I ignored the HK 1/48 Lancaster that was nudging me as well
Alan
Yeah, resistance is futile... {chuckle} WE understand.... The last time I was near a hobby shop an HK B-17F just happened to fall into my cart, on top of the 1/48 PT-109, A Takom M-46, and an HK B-25J glass nose....
Resistance is definitely futile brother....
I'm regretting not getting the Lancaster now
Alan
