There will also be an optional American flag. I'll post another picture next week showing the flag mounted to the model.
Ongoing:
5 minutes ago, Glenn-UK said:
Looks a great addition to the Vanguard range
I hope you'll try your hand at this one.
Ongoing:
Here's a pic I took of the optional flag. This is perfectly screen printed on both sides and has zero bleed.
I'll fit this to Grecian this week.
Ongoing:
That's a brilliant build and a brilliant design! A stunning ship with those "go fast" lines. Thanks Jim and Chris - I'll seriously be considering adding the kit to my (so far...) meagre stash.
Cheers
Alistair
Current Build -
Well done Chris and James - another great kit!
Current Build Hayling Hoy 1760 - First POF scratch build
Completed HMB Endeavour's Longboat by Artesania Latina
Completed HM Armed Cutter Alert by Vanguard Models
Completed 18ft cutter and 34ft launch by Vanguard Models
Completed Pen Duick by Artesania Latina
Extreme lines, not your ‘thirteen in a dozen’ ship. What a sleek hull, and that extremely long bowsprit 😍! Very beautiful and certainly on my wish list, too! Thanks, James, for this sneak preview into the building manual 😉
Current build: privateer brig Mars
Completed: Sperwer (Billing Boats; 1st wooden model)
                      Batavia (Revell plastic kit)
Fantastic looking ship. Seek. I really like the colours. Flag looks great. US subject will be popular I would think. A kit I will definitely purchase.
regards
Malcolm
Completed builds; Caldercraft Mars; Vanguard Alert, Amati Revenge
On the shelf; Vanguard DOK & the Sphinx
One last small update as I'm heading off to watch TV with my better half.
Grecian now has her flag. This is sprayed in a mild starch solution, weighted with croc clips until dry, and then small spots of PVA used to tack into final position.
Ongoing:
She looks fantastic.
Does anyone know a good beginners resource or a log on here on how to copper a ship’s hull? In particular, how do you get the waterline cut straight? I’m very keen to build Grecian, but I need to master coppering.
Many thanks
Dan
Dan
Current Build: Sherbourne (Vanguard Models, 1:64)
Previous Builds (All Vanguard Models 1:64):
Fishing Boats: Fifie, Nisha, ZuluSaucy JackErycinaRanger
Warships (and Yacht): HMS AlertGrecianHM Gun Brig Adder, Duchess of Kingston Yacht
Waiting to be Built: Speedy (Vanguard Models, 1:64)
Many thanks
Dan
The manual for this shows a couple of clear photos. All I did was run a single strip of tape along the keel, up against hull. From there I just added the plates in a brick fashion. That single run of tape can then later be scribed to fit the brick pattern. Add the tape plates above the waterline and then add a feint waterline over the copper. Use a fresh blade and cut along the line before removing the excess from above the waterline.
Ongoing:
Thanks Jim!
Dan
Currently on step 69 of my Grecian.    Please note that the two parts noted in step 69  ( 57 and 58)   are labeled  58P   and 5SS on my 1mm wood sheet.       As a future upgrade it would have been nice to see a close up picture of the bow tapering at this point in order to get the proper taper and alignment at the bow.     (I did find a useful close up at step 115)
