Keith, the green is spot on. I really like the looks of the hull.
I think I would have had a cardiac arrest while the first paint went on ...
Loosk like my favourite green, British Racing Green or RAL 6007 Bottle Green. Difficult to get these days, but I had it mixed up in acrylics for the paint-jobs on my machines.
And I think this is enough paint to give a balance between the realistic impression of the real thing, while preserving the beautiful planking and varnishing job.
Edited by wefalck
Agree with Eberhard. Great job on the masking Keith, those lines look good. So, has the heart rate stabilised?
cheers
Pat
Glen, Rick, Keith, MCB, Ian, Eberhard, Pat - thank you all for your continuing support and thanks to everyone for all the likes and visits.
Eberhard, I don't get very stressed about paint it's drilling holes in the hull that traumatises me.
I have been making a bit of progress with the ships bow decoration.
A198B65B-A889-44DC-8CB5-EAC41A371B07.thumb.jpeg.55acca6f7c44d5bc632db2c3d3d0dbcb.jpeg.e53815bff26402520e425b61c596cc94.jpeg
I had previously made the oval feature.
I bought some .04" bearings to create the fringe. They were fixed in position with clear varnish.
I then applied 3 coats of gold paint.
I masked the carvings on the bow and painted them gold.
I also did a bit of repair work to the paint. In one position the masking tape had covered the very edge of the reinforcing plate. I applied a further piece of tape and painted the edge by hand with a very fine brush.
Then it was time to cut the hull from its building board. I used my pull saw to cut each frame in turn.
DSC03208.thumb.JPG.4c8377b4c770dbe59c122c7f77b3a518.JPGDSC03209.thumb.JPG.74d02cfecbb9e79eb81510e8a2988147.JPG
It took a while but eventually the hull was free and in its building cradle.
I now need to cut all the up-stands off.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
47 minutes ago, druxey said:
I presume that you counted the number of ball-bearings to match the original, didn't you? ;)
 And they're so evenly spaced. Terrific bit of work, Keith. The freed hull looks neat.
Nice work on replicating this 'granulation' or 'filligree' as jewelers would call it.
There is also a little-known tool called a millgrain-wheel that can be used to create decorative beaded wire. It's kind of a concave punch-wheel and sold for different bead-sizes and spacings.
Eberhard - I wasn't aware of that but I did find an interesting youtube video. Thanks for the suggestion.
Just pushed one against the other Keith.🙂
12 hours ago, Tony Hunt said:
I hope you had a glass of champagne handy when you finished?
No - just a cup of tea Tony.
Thank you Andy, Phil, Craig, Druxey.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Well here's raising a cup of very strong tea (only slightly laced with ...) to your success with the gingerbread Keith; that is some very nice work.  We are becoming accustomed to your very fine work but you continue to impress us.
cheers
Pat
Thank you Pat, Rick & Gary.
Another week has passed but unfortunately not all weeks go to plan - more of that later.
You will recall in my last post the hull came off the mounting board.
The next task was to remove all the up-stands to deck level. Those of you with long memories will recall that when I cut out the frames I scrolled along the deck line leaving only a small un cut attachment section. You can just about see the cut at arrow "A" in the next photo.
Removing the up-stand therefore only involved two vertical saw cuts at "B" and a horizontal saw cut at "C".
I tried doing the horizontal cut by plunging in a small Dremel circular saw. The saw did a lot of snatching so I tried a diamond cutting disc which proved to be a lot more successful.
I left a small section of building board at the bow to anchor the decoration with an elastic band while gluing.
DSC03217.thumb.JPG.f9e11d89e4d2ff8d34422e5f2d5296c5.JPGDSC03218.thumb.JPG.a61ef87585e663ed2da237a72a413636.JPG
I then went on to finish the wall cladding inside the engine / boiler room. This small section had been inaccessible from the outside while planking. The cladding is necessasary to produce a smooth internal finish as per the original. The cladding was glued in place using PVA wood glue. The cladding was held in place with pieces of up-stand and clamps while drying.
However this turned out to be a stupid plan because the PVA expanded the hull planks and damaged the hull finish. I am very stupid!
Fortunately only light sanding was required to get the hull smooth again.
Now I get some more varnishing practice.
For the cladding on the other side I have a different plan.
The workshop has been a bit warmer of late so I am hoping for 2 coats of varnish per day. Oh what fun!
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
34 minutes ago, yvesvidal said:
There is always a silver lining in every problem we face.
32 minutes ago, druxey said:
Sorry about the water content in PVA doing that. How frustrating!
Yves / Druxey - The most annoying bit is that it was predictable. I don't suppose I will make the same mistake again.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith, I hate to think how many times I've stared directly at situations with predictably unfortunate outcomes and walked right into them anyway. Many of which had nothing to do with model building.
Gary
Completed Scratch Builds
Thank you Rick.
Gary
Yes - I once arrived very early to work and parked in the completely empty works car park lit by a single lamp post. Just as was getting out of the car I heard a loud bang and looked up to see a car wrapped round the solitary post. With an entire car park to go at (with the exception of one space) the driver had managed to find the only solid obstacle available.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Something like that happened to me once: it was dark in the centre of Copenhagen and I reversed my 2CV into an empty slot of a car-park, when my progress was abruptly stopped. I looked into the rear and wing mirrors and couldn't see anything offending, either were there any walls or bollards. I got out of the car and bumped into a huge black candelabre - just couldn't see the thing in the dark.
I think a lot of us have been brought undone by the water content of PVA, I know I have, had to pull the bottom off my mahogany runabout model and redo from scratch!
These things keep our minds active, figuring out solutions is an important skill.
  • 2 months later...
Dear All
Apologies for my absence.  We have had the builders in doing some structural work for the last 10 weeks and as a result we have had to move into temporary accommodation. With agreeing the work scope, monitoring progress and making sure that the quality is up to scratch I haven't had much time for the more pleasurable aspects of life. The workshop is currently out of bounds as it is full for the stuff from the rest of the house. I can't see the shipyard reopening until autumn but who knows. The good news is that we have a tentative re-occupancy  date of a week on Saturday so hopefully we will definitely be back home by the end of June!!!!!!! I hope you are all keeping well and i look forward to eventually catching up with your builds.
I did re varnish the PVA damage hull before being evicted and it looked just fine. It would have been awful to have sent months worrying about fixing it.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Well, real life's necessities come in our modelling way - even as pensioners it seems. Good that you can see light at the end of the tunnel. Builders always take longer than they originally claim they would. I have something like that lurking behind the horizon as well ...
Thank you for the update, Keith. Good to know you're doing well even though inconvenienced. I look forward to seeing you once again in full control of your workshop.
