Craft knife
Go to solution Solved by Jaager,
Hi everyone. Can someone can help me choose good craft knife please? There are so many of them on the market but I would like have a good one for PE.
Edited by Olaf
I find the ubiquitous X-acto knife with assorted blades works well.  Assorted blades for different materials and functions.
I used to use Xacto exclusively but after more than one episode of it rolling off the bench and onto the floor, or worse, onto a thigh, when it comes to blade holders I went to flat handles.   Saws and other attachments are not a problem for me with the Xacto, but definitely not scalpel blades.  My go to is Swann Morton handles and blades but there are others that are similar.
Allan
  • Solution
I like the shape of the Fiskars Softgrip Ergonomic Detail Knife for hand feel.
A very common blade is the #11 shape.  Getting a 100 pack of a high quality #11 blade, not the OEM version is my choice.
When researching this, I just discovered that XActo - which as not been my choice for blades - has a XZ series that has a zirconium nitride coating
Feedback suggests that the hard coating makes the tip prone to snapping off - especially with lateral force.  If your cuts are straight line they might work.
An alternate direction is a double bevel 1/4" violin makers knife.  #11 shape - just a bar of steel with no handle.  Expensive but it is lifetime for one.  There are maybe 6 widths.
With both disposable and permanent blades, very frequent shroping on leather charged with a green, red, or gold polishing compound crayon keeps a fine edge and reduces changes.  I do not know if zirconium is harder than the compounds.  It may require diamond.
Edited by Jaager
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Can I replace blades on this particular model @Jaager? Doesn’t say anything.
https://ritohobby.co.uk/knives-and-cutters/12571-fiskars-softgrip-art-knife-078484167113.html?gad_source=1&gbraid=0AAAAAC-ulnr6gOu3q3a8I5LVpN9nXtfzu&gclid=CjwKCAiA8sauBhB3EiwAruTRJpC3GRaEjNnSyjDYx3hNb-MV678eP35JtV3RlzYvRXQjFVkE78BTsxoCn3oQAvD_BwE
It will hold any blade that has the same insert as the #11 blade has.
This handle tightens using a knurled knob at the back end.
There is a larger and similar handle for the large blades - the router blades and similar - not what you need for the job mentioned though.
This is the one that I am discussing :
Edited by Jaager
NRG member 50 years
Current:
NMS
Other
One more question guys. I saw somewhere that curved blades are better than straight ones for photo etched parts? Someone is using them and can compare them please?
Edited by Olaf
On 2/19/2024 at 1:37 PM, chris watton said:
For PE, a Stanley Knife should do the trick. I have never used anything else.
Yep I'm the same - I have two types of knife which are the Stanley for tough work and Swann Morton scalpel blades for everything else.  There's no sharpening involved so I can just get on with the job at hand.
I am actually preferring the curved #10 Xacto blade for my work, including the removal of PE pieces.  I can "rock" the blade easier, rather than slicing with the #11 blade.
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
I use the #10 curved blade also.  Just press down and rock/roll over the attachment.  Plus, the #10 blade has better strength and stability relative to #11 blades.  I use #11 Swann Morten blades for pretty much all my other work.
Hi GGibson.Can you give some examples of this blades and what knife I can use for this blades please? I just getting nystagmus on websites🙃
Hi Olaf!  If I am understanding your question, the #10 Xacto blade I was referring to that I like is the 2nd one down from the top left in the picture on my post, that fits into a "standard" Xacto knife handle.  The lower right one is similar, but fits in a larger handle, as you can see the notch part (the little rectangle opening on the left side of the blades) is a bit bigger in that one.
EDIT:  Here's a "knife/blade matrix" I found that will help determine what blade goes with what handle...
x-acto-matrix.pdf (scene7.com)
Edited by GGibson
Gregg
