Sloop Speedwell 1752 by sfotinos - Syren Ship Model Company - 1:32 Scale - POF Sloop
Welcome...
I was very excited when i was able to get chapters 1 & 2 for this new project.
I already have my first question.IMG_0031.thumb.jpeg.689363b02d1e9912d861b801dd8de55a.jpeg
When test fitting parts of the stem assembly the instructions suggest only sanding slightly on certain edges of each piece.
However when I removed the pieces with no sanding, there is a slight gap.  Is it appropriate to correct the other end?
Link to comment
Share on other sites
What does the gap look like on the other side? Remember, the laser doesn't cut perfectly straight, so I would think that a slight adjustment on the other end would be appropriate. I'm sure that Chuck will chime in.
Best Regards .... Rick
Link to comment
Glad to see a build log.
Yes…i actually have a photo of that. Which you posted.  The circled areas (on one end or the other of a given joint) need to be sanded to close the gaps. The gaps are intentional and yes you will need to sand the end of the scarph on the opposite side to close the gaps.  This will be especially true with each frame segment as the thick wood when laser cut leaves a curved and bevelled edge  that wasnt easily remedied by just flipping the pieces on the laser cutter.  So each piece will have one end that needs just a hair of sanding.
See the page of the 1st chapter that explains this.
Just a few swipes should do the trick.
Chuck
Link to comment
Indeed it does. That is looking very good.  Hopefully we will have more build logs starting soon as well.
Link to comment
Maybe...but seriously we need more than two build logs.  If we can get that number up to ten or so then yes certainly.  But of those who bought the first dozen or so kits, if we see 3 build logs it will be a lot.   Lots of solitary builders out there unfortunately.
Chuck
Link to comment
Link to comment
29 minutes ago, sfotinos said:
What size drill bit for the treenails using 25lb line?
I think using the breaking strain of the line as a size measurement can be misleading. It would be better to look for a correct diameter rather than the breaking strain. That way you would also know what size drill to use.
Alternatively, measure the line with a vernier and buy the drill to suit.
Link to comment
I pulled out some of my 25lb line and with a #74 drill bit on a piece of scrap I got a nice tight fit.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Apologies if this is drifting from your build but I feel it’s worth noting for people looking to build to scale.
I just checked five different 25lb monofilament fishing lines and they were all different. The range was from 0.37mm to 0.52mm. Now 0.15mm which is .006 inch does not seem much, but the variation is actually more than 40%.
Hence me suggesting it is better to know the required diameter rather than the breaking strain.
Very nice start by the way.
Link to comment
Building has been continuing, I'm about ready to finish gluing the front apron.
Looking forward at the rising wood.  However laying it on the plans, the slots for the floors progressively get wider and wider and don't match my plans.  Sorry about the bad picture, maybe time to learn how to take a photo with the camera I bought six years ago?
Thoughts?
Link to comment
You are good to go...that one element (keel assembly) on the plans printed at the incorrect scale.  The laser parts are all correct so just keep going.   The plans have been corrected.  The guy at my printer must have grabbed the edge of that object in error and shrunk it horizontally (in Corel Draw).  At least that is what he said happened.  If you lay those pieces on the framing plan instead you will see they fit just fine.
Chuck
Link to comment
Wondering if someone can answer my question.
I'm getting to the end of the keel assembly and noticed this from Chuck's log.
Notice there is gap between the upper apron.
However the plans don't show this gap, mine matches the plans?
Another pic from Chuck's log.
I'm curious if I didn't this wrong or if things changed?
Any help is appreciated.
Thanks
Shawn
Link to comment
nope...You are good.  I changed that part of the deadwood later on after I built it.  The current plans are correct which match your parts which are also correct.
It just made sense to change it after I built it the first time and makes building that area easier for all of you.   My model and log will sometimes be slightly different as improvements are made after the fact....so just follow the plans and instructions and you will be fine.
It will make adding the wing transom and creating the square tuck much easier.
Link to comment
On 4/3/2024 at 1:15 PM, Freebird said:
Chuck,
Do you think a group build like the Winnie would be a good idea?  Thoughts???
 Best Regards ….Rick
Chuck are there enough participants that we can start a group build?
Shawn
Link to comment
Im not sure…i will check though.  Its a ton of work to set up.  Let me see what the guys think about it as well…meaning the mods and admin.
Link to comment
I just received my package and will be starting a build log next week or so.
Ian
Link to comment
  • The title was changed to Speedwell 1752 by sfotinos - Syren Ship Model Company - 1:32 Scale - POF Sloop
One completed keel assembly.
Still needs finish applied, I may opt just to use sanding sealer.  I'm not a huge fan of wipe-on poly.
Everything pretty much fell together once things were tweaked just a bit.
Couple of things...
  1. Be very careful with the knee of the head, I sneezed and broke one.
  2. When trimming the apron blocks, be sure to use a very sharp blade and very small slivers, as I chucked a couple
I popped the first frame out of it's sprues (and yes I think USPS played football with my box, as most everything was detached).  I'm going to look like Popeye after sanding all the char off these frames.
I need to probably tackle putting the build board together before I get to far ahead of myself.
Shawn
Edited by sfotinos
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
