Hello,
because I started with my Tiger in Dec 2017, and I should carve there the quarter pices now, to which I'm at the moment not in the mood. And at least I would like to build a ship or model readdy.
During the summer I bought the book from Werner Dammann about the Gokstad Ship, because these Viking ships interested me since my youth. To my birthday the book by Vibeke Bishoff about the Oseberg ship came along to that.
I started some time befor with the keel and then the plug for planking. Now the first two rows of planks are laid. I build in castello, the planks are 0,5 mm thick.
Regards,
Siggi
Recent build: HMS Tiger (1747)
Gokstad ship (ca900) scratch build
Captains Barge ca. 1760, scratch build
HMS Dragon 74 gunner 1760, scratch build
 This is going to be beautiful, Siggi.
Hello,
today I finished the 3. plank. The two parts up the stems are the most complicated parts. That part in the middle is ,at the moment, not so complicated. But this time I tried to bend the plankt before, and it's working. I just wetted the plank a little, fixed it, and then grilled it with my heating pistol. 😉
But also this part I glued on in two parts.
And these are the new planks, only 13 left per side. So, if you hear the next time not so much from me, I'm bussy planking.
Regards,
Siggi
That is not a very large model, to say the least.
13 plansk may not sound like much, but seeing the amount of detail you put into each plank I can see that it will take a while to do.
Very nice Siggi!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Hello,
and thank you for all the likes and comments.
And before my green kale gets ready, a small update. Yesterday I finished the 5th strake. This morning I took the ship from the plug, to eliminate the glue remains from the inside. It was't so bad as I first exspected.
Regards,
Siggi
That is a relief really. It would be very stressing having to clean up glue residue on that delicate structure.
I do wonder though how you did those fine lines on the stems? Did you use scrapers?
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
10 hours ago, Siggi52 said:
Hello,
And before my green kale gets ready, a small update. Yesterday I finished the 5th strake. This morning I took the ship from the plug, to eliminate the glue remains from the inside. It wasn't so bad as I first expected.
I built a 16ft cedar strip canoe years ago, on plywood bulkheads mounted on a T-bar of two 2"x10" boards. After fiberglassing the outside, it was time to lift the hull off to sand the inside. Don't recall the glue I used, but the glue runs on the inside WERE as bad, and as concrete-like,  as I expected. There's no joy like sanding a large concave cedar wood surface......🙄
And Siggi, your ship looks outstanding!
Good morning,
many thanks for the likes and nice comments.
Håkan, that is only one scraper, and he is a little too wide. Half an millimeter would be better, but this is the smallest one I could build. But it dominate the planking a lot as I saw at the last pictures. In nature it's not so much. Christensen measured these profiles, and it were 1600 m at all. Lukily they used at the Gokstad ship only one form. These were at least a little more complicated then the one I build. At the Oseberg ship they used 7 different molds!
At the picture you see also my test planking, now oiled. I don't know if I shoulld stain the oil a little.
Regards,
Siggi
 Siggi, I think the wood is beautiful and very pleasing as is.
Hello,
two more strakes are ready. Now I have 7 ready, two more and I can start working upwards. First I cleaned the inside this morning.
But after that, the ship went back at the plug
Regards,
Siggi
 The planking looks so nice, Siggi.
Hello,
thank you Keith, and all others thank you for your likes.
Yesterday I finised the planking of the "floor". The next plank is the Meginhufr, a strong plank like the wales. When the most planks have a thickness of 0,5mm, this one is 0,8mm thick. From now on, it goes upwarts. In this case downwards! The next four planks have a collecting piece (?) to the stems. That would be the next challenge.
But now the pictures from the last two strakes.
Regards,
Siggi
Hello, and many thanks for your comments and likes
Life was against working at the shipyard most of the week, but now I have all collecting planks ready. I started also with planking the meginhufr.
I hope to finish the strake tomorrow.
Here are some of the parts, who did't it  ☹️
Regards,
Siggi
 That sure is pretty work, Siggi.
Hello, and many, many thanks for your comments and likes
Today I finished the Meginhufr.
All other planks for now are 0,5mm thick ( 25mm ),the meginhufr is 0,8mm thick (40mm in real)
DSC03145.thumb.jpg.2365cf859dee0cab22cffde40d852294.jpgDSC03148.thumb.jpg.e11e34086249981261fc021826e37029.jpg
And for cure over night, a corset. That is a bicycle tires and a sandbag
Regards,
Siggi
