Hi Gil,
Thanks for bringing your Victory log back! She is really a beauty.
And thanks for your posting on hammock netting, since I'm going to be doing that on the Constitution in the near future. I do have a couple of questions.
1) Does your netting go one piece across the bottom, or is there an inboard and outboard piece of netting?
2) I like your idea of using the annealed wire at the top of the netting. But, in the last picture, the inboard wire looks a lot thicker than the outboard wire. Is that a trick of perspective?
Thanks again!
Harvey
also glad th see your build up as well..........such a superb ship to follow.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Gil
Thanks a lot for loading up again all your great pictures and especially all the drawings you made. It will be a great help for all modelers!
Cheers,
Rosmarie
In my shipyard:
HMS Victory 1:72, Caldercraft (wood): http://modelshipworld.com/index.php?/topic/416-hms-victory-by-romiol-caldercraft-172/
Schwarzer Rabe (Fluyte 1672) Shipyard, Card, 1:96: http://modelshipworld.com/index.php?/topic/424-schwarzer-rabe-fluyte-1627-by-romiol-shipyard-card-196/
Harvey, Popeye, Lawrence, Rosmarie and Grant. It's nice to hear from each of you and see the build logs coming back to life.  There are still some wonderful  logs that haven't reappeared, however, I'm only about half done sorting and posting, so perhaps most will reappear.  Cheers, Gil
http://modelshipworld.com/index.php?/topic/485-hmsHMS Victory by Gil Middleton - JoTika - 1:72
11.    BOW
Continuing in my attempt to recover the build log by arranging photographs for each area of the build.  The bow has a striking beauty that was missing in the late 1800's and early 1900's.  We've all seen pictures when the Victory's bow was boxed in creating a rather ugly entry to the water. The transmogrification with the restoration is what makes building the Victory (at Trafalgar) so much fun.
Building the roundhouses. Vertical planks were glued and sanded.post-68-0-22879300-1361735733.jpg
Once again, an example of the color change observed with flash photography.post-68-0-67288300-1361735914.jpg
Attempting to drill the porthole, the round house was shattered. Rather like being hit by a 12 pounder. A small pilot hole followed by a rotating abrasive worked better.post-68-0-31194100-1361736185.jpg
Fortunately, the ship's carpenter was at hand.post-68-0-84866500-1361736245.jpg
Forming false rails, contoured by soldering iron and curved wood plank bender.post-68-0-80720000-1361736442.jpgpost-68-0-91018600-1361736465.jpgpost-68-0-48888000-1361736498.jpg
Compound curvepost-68-0-40682500-1361736574.jpgpost-68-0-96386600-1361736598.jpgpost-68-0-95383300-1361736617.jpgpost-68-0-24879900-1361736655.jpgpost-68-0-64045000-1361736675.jpg
Building the Catheads. Base bevelled to the angle of the catheads. The three strips of lighter wood in each are temporary spacers for the sheeves.post-68-0-83695700-1361736847.jpg
Horizontal supports glued in place.post-68-0-43943800-1361736957.jpgpost-68-0-63818200-1361737814.jpgpost-68-0-57026600-1361737848.jpgpost-68-0-63756800-1361737882.jpgpost-68-0-14795300-1361737919.jpgpost-68-0-69099500-1361737953.jpg
Figurehead.  Parts were hand painted and look OK.  To see what is possible, look at Daniel's log (Dafi) who made individual lions to place on the crest.post-68-0-82026400-1361738258.jpgpost-68-0-75730800-1361738303.jpgpost-68-0-15888400-1361738333.jpgpost-68-0-08596600-1361738357.jpegpost-68-0-33826600-1361738389_thumb.jpegpost-68-0-40685400-1361738415_thumb.jpegpost-68-0-71888600-1361738443.jpgpost-68-0-45463000-1361738471.jpgpost-68-0-29591800-1361738497.jpg
More details on the bow will be added with the post on the Bow Sprit and rigging. Cheers, Gil
12.     STERN
When the stern details were added, my wife said  "It's beginning to look like a real ship."  A rewarding comment after four years. But on with the build.
The inner layer of the stern fascia.  Outboard windows are the quarter galleries.  Inner openings were painted white to try to achieve an appearance of depth, while the central white board was then painted black.post-68-0-99644600-1361739640.jpg
Back side of outer fascia. Experimenting.  Placing the windows from behind (opposite from instructions) gave much better definition to windows.post-68-0-04795800-1361739825.jpgpost-68-0-97763400-1361739878.jpg
Black painted using fine line masking, then touch up with reverse masking.post-68-0-62629800-1361740065.jpg
Ballisters painted yellow ochre before glueing in place.Horizontal black above and below windows is styrene strip painted black before glueing.  Spacers between windows ; styrene, painted black.post-68-0-24885200-1361740280.jpg
Painting stern decoration (was not on Victory at Trafalgar)post-68-0-24793700-1361740367.jpg
Tying the fascia (transome) to the counter of the hull required cross planking.post-68-0-33774600-1361740544.jpgpost-68-0-88769400-1361740579.jpg
Details added. Camera angle made appearance of stern look square. See next photos.post-68-0-27817300-1361740755.jpgpost-68-0-29963100-1361740782.jpgpost-68-0-58941100-1361740815.jpg
Real ship, quarter viewpost-68-0-85612000-1361740885.jpgpost-68-0-44029600-1361740920.jpgpost-68-0-18408700-1361741049.jpg
Natural light photopost-68-0-93039500-1361741284.jpegpost-68-0-84067300-1361741313.jpeg
Rudder.  Small addition to trailing edge to raise chain attachment above the waterline.post-68-0-27907700-1361741449.jpg
Preparing for copper platespost-68-0-81023700-1361741508.jpgpost-68-0-32961100-1361741539.jpg
Pintles and gudgeons.post-68-0-25653200-1361741680.jpgpost-68-0-05987700-1361741703.jpg
Pintles and gudgeons. "Bolts" are small rivets (0.035") placed in drill holes.post-68-0-95957500-1361741823.jpgpost-68-0-35763200-1361741849.jpg
14.    BOW SPRIT
The bow sprit and its rigging is logged as one section. It required tapering along with the yards.  The following is a simple rig for sanding and tapering a dowel (picked up from Donny. However, he has moved on to a much better  lathe). post-68-0-37228400-1361743151.jpgpost-68-0-79537100-1361743214.jpgpost-68-0-87725500-1361743254.jpg
Making the gammoning saddles. The dowel is cut half way through.post-68-0-63579100-1361743344.jpg
Approximately, 1/2 of the dowel removed.post-68-0-66952300-1361743413.jpg
Tapered dowel, "iron" bands, and gammoning saddles.post-68-0-17831700-1361743781.jpg
Tenon for cappost-68-0-22973300-1361743827.jpgpost-68-0-53850200-1361743996.jpgpost-68-0-25859600-1361744024.jpg
Added stop cleats for rigging, bees and cappost-68-0-31820700-1361744096.jpgpost-68-0-73078300-1361744126.jpgpost-68-0-56466600-1361744151.jpgpost-68-0-05441000-1361744202.jpgpost-68-0-58919900-1361744230.jpg
Sorting out the congestion and somewhat confusing rigging on the bow sprit. (plans from JoTika)post-68-0-13033600-1361744595.jpg
Fitting blocks and deadeyes to the bow spritpost-68-0-82999700-1361744672.jpgpost-68-0-15213100-1361744706.jpg
Bobstays served and spliced through the stempost-68-0-65277200-1361744885.jpg
Close up of bobstay attachment at stem (cutwater).post-68-0-61521900-1361744978.jpg
Attaching shrouds to hull eyebolts. Shrouds served at bolts.post-68-0-55950000-1361745099.jpg
Gammoning the bow sprit. Inner, outer and flying martindales attached by lashing to eyebolt on knightheads.post-68-0-21843100-1361745338.jpg
A trick to simpliy gammoning. Daniel (Dafi) would simply have one of his little men stationed in the bow timbers to pass the line through. Lacking the Lilipution crew, painting the gammoning line with C/A creates a long thread needle to pass the line through the bow timbers.post-68-0-74800100-1361745662.jpgpost-68-0-51097100-1361745689.jpg
Forestay and preventer attached at bow sprit by served collars with lashings (details in rigging section)post-68-0-95092200-1361746100_thumb.jpg
Forestay and preventer attached. Topmast stay and preventer passing through sheeves in the bees.post-68-0-07079200-1361746255_thumb.jpg
Topmast stay and preventer terminate at lower lashings at the starboard and port knightheads.post-68-0-29031400-1361746378_thumb.jpg
15.    MASTS
Rake of the masts. Foremast 0 degrees,  Mainmast slight and Mizzen more.post-68-0-66990200-1361746889.jpg
Lower masts are tapered athwartships but not fore and aft.  This is a simple jig for shaping the masts.post-68-0-48832700-1361747033.jpg
Dowel in the jig to progressively plane down the sides.  Small Stanley plane at left. The nail glued through a hole in the near end simply prevents rotation and ensures the same parallel planing to the opposite side.post-68-0-12034500-1361747362.jpg
Foremast narrowed side to side. "Iron bands" (styrene) placed with cheeks over.  Squared top with tenon for mast cap. Preparing fore top with styrene strips.post-68-0-16849900-1361747561.jpg
Side view of foremast and under side of fore toppost-68-0-59851000-1361747642.jpgpost-68-0-19054700-1361747683.jpg
Foremast. Additional "iron bands" over cheeks and vertcal batten along the forward side of the mast separating the lower yard from the mast.post-68-0-03135100-1361747954.jpg
Side view of foremast.  Dowel for main mast abovepost-68-0-51434800-1361748049.jpg
Details of mastpost-68-0-16248900-1361748136.jpgpost-68-0-39713600-1361748160.jpgpost-68-0-27909000-1361748192.jpg
Fore top and main top. Actually black, however, flash photo changes color to brownpost-68-0-72487800-1361748310.jpgpost-68-0-33985700-1361748332.jpgpost-68-0-87075400-1361748355.jpgpost-68-0-96989700-1361748382.jpg
Adding battens and iron bands to squared endpost-68-0-02766700-1361748591.jpgpost-68-0-47843100-1361748621.jpg
Battens and deadeyes.post-68-0-07013500-1361748685.jpgpost-68-0-39152700-1361748719.jpgpost-68-0-71606500-1361748747.jpgpost-68-0-24761200-1361748771.jpg
Top mast, hand mast and bolsters for shroudspost-68-0-20035500-1361748995.jpg
Topgallant mast to top mast.  Eight sided portions by sanding blockpost-68-0-11463900-1361749104.jpg
Blocks previously sanded, then stained "English Oak"post-68-0-67902500-1361749185.jpgpost-68-0-72412400-1361749220.jpg
Attaching blockspost-68-0-39654900-1361749279.jpgpost-68-0-28864600-1361749312.jpgpost-68-0-70465900-1361749337.jpg
At topgallant mastpost-68-0-20711300-1361749440.jpgpost-68-0-62128900-1361749465.jpg
Rigging a blumb bob to set the rake of the mastspost-68-0-12668800-1361749679.jpg
Edited by gil middleton
16.    STANDING RIGGING
For those who haven't yet rigged a full ship, a few thoughts might be in order.  For those who have, my apologies for the redundancy. My most valuable aid in rigging is the Lazy Susan to swing the ship back and forth while installing and tensioning shrouds and stays.post-68-0-06179800-1361772472.jpg
Another is a means of serving shrouds at the mast tops, the leading shroud at each mast and portions of the stays.  This is a simple rig from "Ships Ahoy" models.post-68-0-07115400-1361772643.jpg
Some form of third hand is virtually mandatory for complex splices, rigging blocks, adding a running line to blocks, etc.post-68-0-10043400-1361772754.jpg
My instruments concist of a heavy duty needle driver with cross serrations in the jaws for grasping (left), a fine smooth jaw needle holder for fine instrument ties (2nd from left),  angled forceps that can reach just about anywhere and sharp serrated scissors that will cut on the knot.  One hears comments such as "I hate C/A" or "Of course one can't usa C/A in the rigging."  I aggree with Ed Tosti, with his magnificent scratch built Victory, that there are rigging challenges that I could not do without it. Of course if it irritates one's nasal cavity or bronchi, better stick to white glue or work with an open window.  I keep a tiny cup of fast C/A glued to a piece of wood (non-spill) with a small applicator or toothpick, rolling each on a paper towel after each application. These will last for an all day session.post-68-0-27703000-1361773550.jpg
One can't have enough small clamps or alligator clips.  With a bit of masking tape over the teeth, they will hold the smallest thread.post-68-0-71863600-1361773676.jpg
Beginning with the shrouds, these were laid on following the JoTika plans and McGowan's book with McKay's drawings.  Each shroud with deadeye measured and labelled.post-68-0-48942600-1361773869.jpg
Shrouds attached alternating starboard to port to even tension.post-68-0-81912600-1361774007.jpg
Graph paper on cardboard to align the futtock stave and later for rat lines.post-68-0-58991000-1361774463_thumb.jpg
Deadeyes at main mastpost-68-0-56846700-1361774582.jpgpost-68-0-89052500-1361774627.jpg
Pendants made with served line around a bullseye and an eye splice. Good seamanship often favored a tapered splice.post-68-0-95661600-1361774772.jpg
To simulate a tapered eye splice, sieze the bight with several turn (I prefer repeated half hitches, alternating the diredtion of the turn with each hitch).post-68-0-46811100-1361775005.jpg
Follow by separating and cutting off one strand and sieze a few more turns.post-68-0-02267300-1361775097.jpg
Finally cutting the last strand plus siezing and one has the appearance of a tapered splice.post-68-0-72594400-1361775269.jpg
Another advantage of C/A glue.  If one is left with a protuding stump, a light clamping before the glue has cured will reshape it.post-68-0-11006100-1361775516.jpgpost-68-0-21593600-1361775540.jpg
Making the catharpins with eye splices at each endpost-68-0-31058500-1361775609.jpg
Catharpins can be seen lashed to the futtock stavespost-68-0-42785700-1361775678.jpg
Futtock shrouds in placepost-68-0-74917900-1361775735.jpgpost-68-0-40006300-1361775777.jpg
Top mast shroudspost-68-0-46955200-1361775913.jpgpost-68-0-86587900-1361775940.jpgpost-68-0-81054500-1361775968.jpg
Lining up fore mast, main mast and mizzen while adjusting tension port and starboard.post-68-0-07436900-1361776062.jpg
Bullseye attached to base of topmast shroud deadeye, to be swung inboard to receive topgallant shroudpost-68-0-71527000-1361776245.jpg
Topgallant shrouds pass inboard of staves in topmast shroudspost-68-0-12688200-1361776506.jpg
Terminate with lashing to bullseye attached to base of deadeyepost-68-0-78742700-1361776612.jpgpost-68-0-03498700-1361776633.jpg
Shrouds in place.  Ratlines will be shown as a separate topic.post-68-0-82215000-1361776721.jpg
I would suggest completing rat lines before tying down the topgallant shrouds, sliding backstay, breast backstay, etc. It's much easier to tie rat line without adjacent lines interfering.post-68-0-45924000-1361776901.jpg
To be continued................
Hi Gil,
I'd like to add my thanks for uploading the build log. It'll be a constant source of reference and awe as I strive to complete my Victory.
Best regards
Jim
Gil
Well this is exellent, over such a short period of time. I was only waiting for the fitting of the rudder to bring me back up to date. Thanks for giving my plans back. Regards DAVID
Great fun to review this!
Daniel
Hi Daniel,  I am remiss in not keeping up with your log and others, however, I'm still learning how to use the new site and above all to restore the build site.  It should be done in a day or so, when I can sit back and enjoy the work of our many friends on MSW.  I'll even have a few new photos to post.
David and Jim, It's nice to know someone actually reads all this stuff.  I've certainly learned my share before "the crash of 2013,"  We're all learning from each other and it will be good to get back in stride.  Cheers, Gil
On with reloading the build site.
RIGGING THE FORESTAYS AND PREVENTERS
Experimenting with a mouse and eye for the forestay.  Forming the eye with served line.post-68-0-27168700-1361831413.jpgpost-68-0-10816300-1361831465_thumb.jpgpost-68-0-85672400-1361831495.jpg
Attaching bow sprit collar with lashing between eyespost-68-0-50765700-1361831731_thumb.jpg
The forestay and mainstay are served at the mast to just beyond the mouse, and wormed from there on.  Serving the forestay.post-68-0-36455000-1361831869_thumb.jpg
Winding to build the mouse. A little C/A helps build the trailing end and serving continues just beyond the mouse.post-68-0-90894400-1361832050_thumb.jpg
Serving ended by passing thread through the stay.  I did not glue and cut this worming line until the three worming lines were passed. It is nearly impossible to pass a needle through C/A treated line.post-68-0-17191800-1361832339_thumb.jpg
Three strands passed through the stay to begin worming.post-68-0-29016800-1361832429_thumb.jpg
Served on right, Wormed on left.  Mouse to be added.post-68-0-80050700-1361832553_thumb.jpg
Mouse and eye (served).  Starting lacing line between stay and preventer.post-68-0-92006900-1361832807_thumb.jpg
Attached at bowsprit to served collars with lashings.post-68-0-64092800-1361832998_thumb.jpg
Main stay and preventer at main toppost-68-0-64914800-1361833062_thumb.jpgpost-68-0-82157700-1361833101_thumb.jpgpost-68-0-46153800-1361833142_thumb.jpgpost-68-0-39815400-1361833174_thumb.jpg
Attached to collars around the bow spritpost-68-0-97761600-1361833256_thumb.jpg
Main top mast stay and preventerpost-68-0-55122800-1361833698_thumb.jpgpost-68-0-57164500-1361833735_thumb.jpg
All stays and backstays were left adjustable until final tensioning and alignmentpost-68-0-57814500-1361834050_thumb.jpgpost-68-0-69242200-1361834081_thumb.jpg
PHOTO  BACKDROP
About a year ago, Mike Graff gave our Puget Sound Ship Modellers (PSSM) group a superb well thought out presentation on improving our model photography.  The need was obvious.  Here, the Venetion blinds obscure the rigging details.post-68-0-27504500-1361834331_thumb.jpg
I tried poster board which was totally inaddaquate.post-68-0-81250200-1361834399_thumb.jpg
Finally, I obtained a "baby blue" pull down shade which should improve my posts from here on.post-68-0-20868600-1361834524_thumb.jpgpost-68-0-09198500-1361834556_thumb.jpg
17.    RATLINES
My first thought on ratlines is to complete them prior to some of the standing rigging.  Here the topgallant shrouds, lashed to bullseyes just inboard of the topmast shrouds, play havoc with tying the ratlines.post-68-0-68970500-1361835021_thumb.jpg
The second thought is I rather wish I had gone with black thread.  The natural thread contrasted with the black shrouds makes the ratlines appear almost white by comparison.post-68-0-29270400-1361835225.jpg
The result is that one's attention is drawn to the ratlines rather than the more important rigging that supports them.  I tried toning down the contrast by painting the ratlines with a "black wash" (very dilute black paint) with some success.post-68-0-56101100-1361835417_thumb.jpg
Graph paper used to align the futtock stave and ratlines.post-68-0-17289600-1361835484_thumb.jpg
The color contrast appears less intrusive with less intense lighting.post-68-0-87948900-1361835589.jpg
I began with clove hitches but switched to overhand knotspost-68-0-74190000-1361835681.jpg
Overhand knots resulted in only one line around the dtay rather than two with the clove hitchpost-68-0-26983200-1361835762.jpg
Gil,
    I am thinking that second time around is better than the first time I see this part of the update. Keep the post coming.
Wacko
Joe :D
Go MSW :) :)
18.     RUNNING RIGGING
Finally the running rigging.  This will bring the build log up to date, with a few new photos at the end.  There are still a number of small details  to add on the ship such as boomkins (deferred in order not to knock them off), lanterns, etc. and much more running rigging so I'll probably be busy for another year.  Work on our real boat begins in March to prepare it for summer cruising, so priorities will change. Grant (gdale) will pass me by and I'll get to study his rigging before making mistakes.  It's a relief to have the build log back in place and to see others taking shape. MSW is alive and well, and our sincere thanks to all the moderators who have suffered through the trials. Our inconvenience is but a fraction of their increased work load, dedication and frustration. Thanks you!!!
On with the rigging.  On the right, the initial square jeer block.  Center: sanded and stained with "English Oak"post-68-0-98601500-1361837223_thumb.jpg
Lower and upper jeer blocks.  Indentations for double stropping.  These massive blocks were 26" long on the real ship.post-68-0-70193500-1361837367_thumb.jpg
Experimenting with yard lift and battens (styrene) at central yerdpost-68-0-80997100-1361837453_thumb.jpg
Double stropped jeer blocks (served)post-68-0-29276000-1361837585_thumb.jpgpost-68-0-50079100-1361837614_thumb.jpg
Lower: Main yard with battens, iron bands and yard cleats.  Next up: studing sail (stuns'l)) booms. Middle: Foremast yard, tapered by sanding with power drill lathe (ends to be cut off).  Supplied stuns'l rings too large.  Replaced by cut section of styrene tubing (5.5mm diameter)post-68-0-41889200-1361838095.jpg
Rigging for yard lift, jeer blocks (double stropped), all servedpost-68-0-49591600-1361838183_thumb.jpg
Supplied stuns'l boom rings and replacementpost-68-0-17798800-1361838261_thumb.jpg
Central yard, plus iron bands and yard cleatspost-68-0-71596100-1361838317_thumb.jpg
Yard cleats.  "bolts" are .035" rivets.post-68-0-63179200-1361838427_thumb.jpgpost-68-0-93974700-1361838456_thumb.jpg
Stuns'l boom rings.  Stirrups for foot rope (horse) from 24g dark annealed wire with thread lashing around yard.post-68-0-27605300-1361838764_thumb.jpg
Siezing around wire to simulate eye splice supporting foot ropepost-68-0-12899000-1361838892_thumb.jpgpost-68-0-34541100-1361838920_thumb.jpg
Styrene and square brass rod for stuns'l boom supportpost-68-0-85959600-1361839011_thumb.jpgpost-68-0-32431100-1361839076_thumb.jpg
Yard rigged with yard sling,jeer blocks, yard lift blocks, horse and stirrups and Flemish horses at ends.post-68-0-36140200-1361839231_thumb.jpg
Jeer blocks with lashing through eye splices from stroppingpost-68-0-31865600-1361839318_thumb.jpgpost-68-0-43952500-1361839430.jpg
Stuns'l booms addedpost-68-0-64598200-1361839497.jpgpost-68-0-94260700-1361839529.jpg
Brass wire to pin yard to mast (to stabilize yard for rigging)post-68-0-04618100-1361839607_thumb.jpg
At last, the build log is up to date.  The next few pictures are work done just before the crash and not yet posted.  Cheers, Gil
superb workmanship........as well as your picturesGil!  I am awestruck with this build....very well done!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
RUNNING RIGGING  Continued.   New posts
Foremast yard with yard sling.  Yard pinned to mast for stability with brass wire drilled into mast and yard, + C/A gluepost-68-0-94223500-1361852066_thumb.jpgpost-68-0-31604100-1361852125_thumb.jpg
Yard sling plus jeer blocks.  Timber hitch on yard leads to upper jeer block, and from blocks leads down to deck. Yard jeer blocks lashed to yard through eyes in tail of double strops.post-68-0-60689000-1361852326_thumb.jpgpost-68-0-18950200-1361852748_thumb.jpg
Truss pendants. Each passes around back of mast, through bullseye lashed to yard on the opposite side and down to deck.post-68-0-09748400-1361852796_thumb.jpg
Rigging truss pendants to block and tacklepost-68-0-58658200-1361853014_thumb.jpg
Main mast truss pendants terminate at block and tackle to deck eyebolt and finish at cleat at base of mast.  Jeer blocks line terminates through sheeve in the main top bowline bitts just aft of the main mast.  Yard topping lift terminate through sheeves in the kevel at bulworks (below forward shroud).post-68-0-37007600-1361853319_thumb.jpg
Foremast yardpost-68-0-24178000-1361853485_thumb.jpgpost-68-0-43732800-1361853509_thumb.jpg
Jeer blocks line terminates at fore top bowline bitts (aft of fore mast), truss pendants to tackle forward of mast and tooping lift to kevels at bulworkspost-68-0-43073800-1361853653_thumb.jpg
Superb craftsmanship as always Gil. Your posts on the early stages of the Running Rigging will be a great help to me - very soon! I was interested in your reflections on your ratlines. Indeed it was your comment that helped me to decide on going with black ratlines and I'm very pleased I did. I have however, stuck with clove hitches for all the ratlines. To be honest, I'm not sure that most observers would be able to tell the difference anyway.
I'm not sure I'll overtake you - somehow work and life seem to conspire to severely limit my shipyard time!
Cheers,
Hi Gil,
I'm Jerry and I just started bilding HMS Victory like yours.  I have a question that I hope you will answer for me.  Did your bulkheads fit the slots of the keel immediately or did you have to trim (sand) the slots to make the pieces fit?  Thanks for your answer or anyone elses answer who may read this.
Jerry
Jerry, mine fitted without any problems
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
