Hi Ben,
Is it an issue with the planking or the framing?? I also notice that the pics seem to show 4 runs of planking landing on the same bulkhead
I think it is a bit of both on my part where I didn't duplicate the run of the gun ports on both sides as close as
I thought I did and then the laying of the planking may have had some minor creep to it too. We're talking
1/32" to 3/64". The good part is the run of the planks is uniform at the top of the frames.
The planks all landing on the one frame were due to my error in laying the first few rows at the bow I mentioned
awhile ago and instead of ripping off all the planks I only went back to the point that the run went astray. This part
will be covered by the second layer of planking so I took the easiest route to correct it.
Thanks Chuck. Having a lot of fun here when I can get some free time.  B)
Hi Augie, Thanks, imperceptible it's not, but acceptable it is . Once she's done 95% will be covered or blocked anyways! ;)
Thanks everyone for all the "likes" too it is appreciated.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
It looks better than "acceptable " to me Rusty. Well done.
Bob
I quite agree with Bob.   Lovely work.
Thank you Bob and Mark. Much appreciated.
Well I've commenced with adding the wales. The second layer is 1/16" x 5/32" just like
the first layer of planking. The black strake is 1/32" x 5/32". At the bow the black strake
is sanded down to 1/64" thick while the wales well be left slightly thicker than that.
The anchor lining was traced onto the wales and black strake. The lining over the wales is
1/32" thick while the portion over the black strake is 1/16".
Here all but the piece over the black strake have been added.
Rusty
Very impressive work Rusty. Really a nice job.
Jim L
What we ever hope to do with ease, we must learn first to do with diligence. - Samuel Johnson
     On the Building Ways:                           Launched:                                                 Contracts Signed:                    Member:
       The Nautical Research Guild
        The US Naval Institute
Thank you very much Joe, Bob, Ben and Jim and to everyone who posted a like too!
Ben, I didn't mix up the wood types but I could have as it's going to be painted. All
throughout the wales I used some old pieces I had left over and cut them up. The
colors varied greatly from gray/brown to light brown and grainy looking. I figured it
was a good place to use up some "scrap" boxwood up.
Here is the anchor lining done. On this side you will noticed I took a lazy way out. The
top piece over the black strake was about a 1/64" too narrow and seeing again that it's
going to be painted I just left the gap and filled it. :o
Now the directions call for painting the wales now prior to planking the hull. My thought
is I'm a rough hull planker as I put in my lap, tip it upside down ect. I usually scratch the
paint all up and have to repaint it. So I'm just going to apply one thin coat just to see if
any imperfections show up and then fix them.
Then it's on to laying out the planking belts for the hull, mill the wood and then plank it.
That will be good for 2-3 months of cussing. ;)
Rusty
I'll lay you dollars to donuts that you won't leave it at one coat.  The appearance at that point will disturb you and you won't want to leave it that way for 3 months !!!!!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
I agree with Augie on this.  We know you too well.... :)
Hey Augie and Mark:   :o     :blush:     :P
Rusty
I guess the only question is will it be 3 coats or 10????
No way I can do 20. I'm not as patient as Chuck and others. 10 would be my maximum.
I guess we'll have to figure the over under on this one!  :rolleyes:
Rusty
Chuck???  It's Ben who holds the land speed record for # of coats!  He's even gotten me up to 10 --- and I used to use a roller.
Augie
Previous Builds :
Very nice progress Rusty; haven't poked my nose in for awhile and was very pleasantly surprised.
Go on - just one more 'wafer thin' coat' won't hurt :)
Cheers
Pat
OK I've been continuing my work on the wales and black strake. The first picture you
will see one coat of black paint applied.
I then went over the wales sanding some and taking care of a couple of joints that weren't
as tight as I thought they were. Just put a dab of glue on the crack and sanded it.
And here you see it with a second "wafer thin" coat of paint. So far that is it! :P
I'll be spending the next few days trying to lay out the run of the planks and not bugging
Chuck to much while doing it.  ;)
Rusty
Voila ..... total transformation!  Beautiful.
I'll PM you my home address to collect my donuts for the 'more than one coat' wager.
Augie
Previous Builds :
How many coats of paint did this take? Sounds like only 2 or 3. :) Also did you thin the paint?
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Thanks for all your help Chuck!
Hi Bob, Thank you, you're too kind.
Thank you Greg.
Hi Augie, Still waiting for your address though they may be a bit stall by the time the post office gets them there.
Thanks Dirk.
Hi Floyd. So far just 2 coats though there will be many more before she's done. I use acrylic paint and thin it
about 50/50 with water. I'll eventually switch to artists paints in the tube like Chuck uses but I still have this black
paint left and I like it's matt finish.
Also thank you all for all the likes. It's very much appreciated.
Rusty
