nice work on the gratings.........really like how you did the beak head  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Quick update on next step....channels, deadeyes, and chain plates:
1st photo.... all channels have been rough cut.
2nd photo....All knees have been shaped.
3rd photo.....used lathe to turn walnut stock and score each deadeye.
     There are two sizes needed (60 pieces of 1/4" for lower channels -  and 24 pieces of 3/16" for top mast shrouds).
     Each deadeye will be drilled and dressed before cutting off....then finish dressed with a fine file.
4th photo....shows channel, deadeye, and chain plate assembly.
     The chain plates consist of 5 pieces cut and shaped from 74mm black wire.  There will be 42 sets required.
I don't need to say what I will be busy working on for a next few days.
Edited by SawdustDave
Sawdust Dave -
Current build - USS Constitution 1:60th (scratch)....
Visit my blog site - All previous builds.... http://davesmodelships.blogspot.com
That's really looking great Dave.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Hi Dave
Just found your log and looked through it. Fantastic work - I don't have a patch on you! Now that I've penned in I will follow.
Cheers
Alistair
Current Build -
Hello Piet my friend.
Alistair....proud to have you join my little project.  Just wish I could make my work look as sharp as your Fly.
Joe....Here's the dime size reference...
Sawdust Dave -
Sure Thing Frank. Take a close look at the third photo and you can see my turnings.
Note that the one right below the cluster of deadeyes has been reShaped by sanding three sides fairly flat....careful not to take them too far because you don't want the tips to be sharp.
You might need to tell me if that helps, or are you having another type of problem.
Sawdust Dave -
Hi Dave
That helps.  What I've been doing is shaping a strip of wood using shaped scrapers - my larger deadeyes will be from 1/8 x 3/16 stock.  The bottom of the deadeye will be a 1/8 diameter semicircle, and the top will be 1/16 semicircle.  The two semi-circles will be joined by tangential lines.  This is all based on pictures I found in 'Historic Ship Models' by Wolfram zu Mondfeld.  I enlarged the pictures from the book, took some measurements, and then scaled them to fit the deadeyes in Chuck's plans.  I'm not even sure if I'll try to make smaller deadeyes or keep them all the same size - I'm a long way from rigging or even installing the channels, and just started playing with the deadeyes because I've been thinking of them a lot.
I think the biggest problem I'm having is that the wood I'm using splinters a lot - I think I'll need to change the wood I'm using.  I'm trying to use African Pear, since it's fairly dark, but splintering is an ongoing issue with that species.  I'll probably switch to castello and stain it darker.
Keep up the good work!  You're giving me lots of ideas and incentive.
Frank
As for the deadeyes....
1st photo.... better look at the profile of the turned stock.  Note the two boards used to keep the turned piece from moving around while being sanded.
2nd photo....better look at the scoring of the turning.
3rd photo.... the modified Dremel bit used to drill the deadeye holes.
Sawdust Dave -
Mounted starboard fore channel w/deadeyes / chain plates.
1st photo..... Shows brass pins used to secure channels to the hull.
2nd photo.... Close up of knees.
3rd photo....  Close up of installed assembly
Sawdust Dave -
Wow, that looks really ducky Dave, nice job!
Cheers,
                       VOC Ship Surabaya
Thank you Piet and Omega.  Just applied a thin coat of wipe-on poly to the channels and realized I should have done so before taking the above photos.  What a difference!
Think I'll re-shoot later today after I finish installing the starboard waste channel assembly.
Sawdust Dave -
Fabulous work Dave B) I love the scratch deadeyes B) Just one small point,the ones fitted are upside down,the point should face the channel at the bottom and the shroud at the top.Sorry to bring the bad news but I thought it was best mentioned now rather than later when you have more fitted :(
Kind Regards
Nigel
Currently working on Royal Caroline
OK, we have a pretty good ending to this particular brain f__t.
Shame on me for fitting those first deadeyes improperly oriented.  Having never used heart shaped deadeyes before, I've never worried about orientation at this point since round deadeyes can easily be rotated when ready for reeving the lanyards.
The good news....
*  Since the brass nails were pressure fitted, there was no big problem removing the five assemblies.
*  Before - There were three corners, requiring five bends, to the shaping of the wire tightly around each deadeye.
*  Fitted correctly - There are only two corners, requiring two bends!  Much easier and quicker.
These seven assemblies seen here were done much quicker than the original five first posted.
Sometimes there's a silver lining to them dark clouds.  :D
Sawdust Dave -
That's whats so nice about thus site.... MANY eyes to guide us through!!! :D ...  nice work Dave, she's looking real good!!
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
You are so right Frank. I hate to think of what it would have been if I had fitted all thirty of these chain plate assemblies as I was going. And there's no reason to think I would have found my mistake before completing all of them.
I can picture the Amiral walking into the room and saying to me....."What's wrong sweetheart? Why are you crying?
Thank you Nigel.
Sawdust Dave -
the second set of pictures was worth the like button ;)     saw the first set and said to myself.....oh...my!  but the solution and fix was quick and easy..........great recovery! :)    that's why this site is SO great.........the people in it!!  :D
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Yep, that's for sure Popeye.
What a great group of people.  It's a shame we can't actually come together occasionally somewhere for a big show-and-tell.  Wouldn't that be special?
Count yourself among the many mates I would love to meet over a few cold brews.
There are so many amazing models I would enjoy going over thoroughly with my magnifiers.
Thanks
Sawdust Dave -
Is there a little place for my little tent? I ll take some beer and good wine with me
Edited by Nenad M
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
