Hi everyone
Many thanks for all your comments and support!
Well, my initial intention of using Ticonderoga's hull and adapting it to 'fit' the original boat just didn't work. So, instead, I decided to bite the bullet and carve a half model of the proper hull. The reason why I did this was so that I can get proper frame templates. The half hull consists of slices of wood, lightly glued together and then sanded to shape. Once I'm happy that I've got a nice and shapely hull, I'll then separate the slices to get the exact frame shapes.
After that, I'll use those half frames to make full frames for a plank on frame hull. The photos below show the progress so far.
I hope this makes sense!
Cheers
Patrick
off to a good start Patrick!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Patrick,
You're following in the footsteps of old school naval architects and shipwrights. Your method not only makes sense, its a tried and true method for doing exactly what you want to accomplish! The main entry hall of the college I attended was lined with half hulls of all different ships, designed by the founder of the school and used for the purpose of lofting fair lines for making frames.
And, you look off to an excellent start. Keep on keepin' on!
Edited by BenF89
~ Ben
___________________________________________________________________________________________________
Current Builds:
'Doll-Boat' - 1:12 scale 40' Cruising Sailboat
S.S. Edmund Fitzgerald - 1:350 plastic kit w/ Photo Etch Parts (On Hold)
Patrick, just to reiterate what others have said, you're making an excellent start!
Looking at you second photo, that's an incredible amount of detail you're planning to shoe-horn in and I'm convinced you'll create a fabulous model yet again!!
Best of luck,
Row
1:28 Scale J class yacht 'Enterprise' (R/C)
Build log currently at: http://www.rcsailing.net/forum1/showthread.php?6264-1-28-J-Class-Enterprise-build-log
Hi Patrick, look like She's starting to take shape , Nice work
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
I see what you are doing, I understand what you are doing and all I can say is "WOW".
Bob
Current build:  SS_ Mariefred
No pressure here at MSW, Patrick... ;)   even though we know whatever you turn out will be great!!!!!    I got my chair and post-76-0-55157600-1430522184.gif
whoaaaaa.....wait!  Mark........where did you get the popcorn?
SJORS!!!!!!!!  we need you over here!  ;)
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
From a pure engineering point of view your method makes all the sense in the world!  Shape is looking very nice Patrick.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
The easiest way to do the frames.  The only drawback is going to the trouble of making a half hull then the pain of slicing it up.  I have always liked the look of a half hull.  You are doing it the traditional way.   This should prove to be an interesting build log.
David B
Hi everyone
Many thanks for all your comments and likes!
I've made some progress over the weekend. This includes cutting the half hull into sections so that I can get the frame templates. I've also cut the keel as well as a template of the side profile of the whole hull. This week I'll cut out the frames and glue them to the building board.
Slow work, but fun!
I hope you enjoy the photos.
Cheers
Patrick
Hi Patrick,
you`ve realy been busy These days, good looking results so far
Interesting technique with those semi-hull sections
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Thanks. Interesting method is true because this is the first time I've tried it. Hopefully it'll work. If it doesn't ...oh well...it'll be a case of going back to the drawing board.
I'm pretty confident, it'll be ok, though. Finger's crossed.
Cheers
Patrick
New methods is how we learn, and if it is better then the last, that's when others pick it up and say, "Isn't this great?"
Bob
are you making a separate template for the port side,  or make up both sides on it  {reverse procedure, of course}?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Dennis
Good question! I was going to do a port side, but the risk of getting variations between the exact shapes was too high. So, I'Ve decided to do the reverse technique; which should guarantee that the left and right sides match.
Thanks and all the best
Patrick
Hi everyone
Thanks for all your Likes and comments!! Greatly appreciated.
Well, Symphony's progress has been slow, but I have managed to cut the frames out of cardboard and glue them to the baseboard. I then cut the keel and dry-fitted it to the frames just to see how it all went together. Luckily, it all went pretty smoothly and minimal adjustments were required.
There's still heaps of work to go, but, hey, that's part of the fun of it, isn't it?
Here are the photos so far.
Cheers
Patrick
Good start, you can already see she'll be lovely.
Bob
nice progress Patrick!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
You know it Patrick, it is all about having fun , the frames are looking good Nice work
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hi everyone
Many, many thanks for all of your comments and Likes! Greatly and warmly appreciated.
Well, one of the hardest things I've found is how to ensure that the sheer line of the hull is exactly the same on both sides of the hull. It's always bugged me. So, this is what I did. I glued a template of the hull on each side of the building board and then glued horizontal pieces across the templates. Once the horizontal pieces had been glued, I then removed the side templates, leaving the horizontal pieces standing ready to have the sheer strake glued on later. The idea being that these will exactly mark the sheer line and therby ensuring each side is equal.
I hope this makes sense! If not, hopefully the photos will explain things better!
Cheers
Patrick
 Nearly missed the boat!!! You are moving fast again, Patrick ... Didn't know you were on the move again ... So far: Very, very promissing!!!
Carl
Interesting method for setting the sheer plank.  I'll have to try it.
Bob
