Nice progress Hamilton, neat job on the margins B.E.
- 69 replies
- fair rosamund
- occre
Hi Martin, I used the kit gratings. Once I had got the round in the head ledges I was happy with I inserted the made up grating and and simply sanded it from the centre each side to match. Here's a link to how the finished one for the Fore hatch looked. http://modelshipworld.com/index.php?/topic/332-hms-pegasus-by-blue-ensign-victory-models-enhancing-the-kit-a-build-log-of-sorts/page-2 It doesn't really matter that it is too thick because once in place it doesn't show. Cheers, B.E.
- 467 replies
- fly
- victory models
Nice replacement figure Lukas, that winged shield figure on Superbe is a pretty ugly device. When you come to rig the 'show' guns on the upper decks remember the French rigged their breeching ropes thro' the sides of the carriage, not around the cascobal or thro' a breeching ring as on British ships. B.E.
- 110 replies
- heller
- le superbe
Hi Martin, I used 5mm starting depth for the head ledges and 3mm for the coamings as I recall; it was a conscious decision as I wanted to achieve a visible curve in the gratings without making them too thin on the outer edges which would create problems with them breaking up. The grating sit on a 1mm square ledge glued around the inside of the ledges/coamings; the head ledges were rounded down to meet the coamings and the gratings now in place were carefully sanded down to meet the round in the ledges. I think the head ledges finished up at around 3.5mm at the central point. If you intend to have open hatches it is worthwhile gluing some square stock beneath the deck openings to represent the hatch framings and give a little depth to the hatches. Cheers, B.E.
- 467 replies
- fly
- victory models
A very beautiful build Pete, and how lucky your friends are to have such a fine model to display. B.E.
Hi Martin, re the gunport strip, I found it useful to also make up a gun to check that they sit squarely in the ports, don't want to find after the event that they are too high or low. I'm impressed with your journey into figure carving I think you have an emerging talent there. I like the holly decking, what are you using for caulking? Cheers, B.E.
- 467 replies
- fly
- victory models
Many of my golfing mates visit Florida for that purpose, I think I would rather visit Bob to look with amazement on his Essex. B.E.
- 1,477 replies
- essex
- model shipways
Great job on the Pinnace Grant, and those frames for the cutter look as delicate as butterfly wings, make mine look as tho' they've been hewn out of a tree with a chain saw. B.E.
Looking forward to seeing you work your magic on this new project hamilton. B.E.
- 69 replies
- fair rosamund
- occre
An interesting solution Nils, and one that doesn't look out of place. Those Foc'sle ladders that seem to foul the guns always looked awkward to my eye. B.E.
Pretty as a picture and smart as paint she looks B.E.
- 1,039 replies
- ballahoo
- caldercraft
10 coats of bulwark red paint Augie, I think I need to revisit my approach to bulwark painting. Looks wonderful. B.E.
- 2,191 replies
- confederacy
- Model Shipways
Hi Jason, Very nicely made up that sling, but as with almost everything to do with rigging there are variations and differing opinions as to the set up. Longridge certainly shows the Slings on Victory retained by battens forming grooves on top of the mast cap, whereas Lees indicates that the sling was supported by a cleat nailed to the aft side of the Masthead, as does Antscherl in the ffm, who also says that Steel did not specify slings for any rate below 32 guns. He also shows that the slings passed thro’ the foremost aperture in the top. On Victory there is a small square hole on the forward side of the top thro’ which the sling passes, but Lees suggest that this arrangement was perhaps more early nineteenth century rather than late Eighteenth. To my eye your arrangement looks a little awkward with the sling rubbing against the topmast. Can you install a small cleat to hold it back a little? I’d be tempted to have a play with it, and see how it looks passed around the aft side of the masthead, if you have sufficient length, but it’s a small point and I wouldn’t get too concerned about it. Cheers, B.E.
- 800 replies
- snake
- caldercraft
Nice progress Holty, she's looking great, I think that beam is a Breasthook, Pegasus has one situated just above the deck, below the capping rail. I note that in the aots book of the cutter Alert, she doesn't have one but has a deck hook (same sort of thing) below the decking, so it can't be seen. Because of the bowsprit arrangement on cutters I doubt there was room to allow the breasthook to be much above the deck line, and on your cutter it looks to be flush with the deck. B.E. ps. is there a profile view in the plans which may show whether the breasthook is flush with the deck or just above it?
- 123 replies
- lady nelson
- victory models
Nice job on the deck planking Eamonn, I think it looks excellent, and those things that catch your eye that you may think you could have done better will take on far less significance once all the deck fittings and the rest are in place. Those two planks that Jason referred to as king planks are binding strakes, slightly thicker than normal planking and are let into the deck beams so they still are flush. Their purpose is to aid the rigidity of the structure. Cheers, B.E.
- 1,039 replies
- ballahoo
- caldercraft
Neat job on the shroud cleat Peter, they really are a useful addition to the rigging process. Looking forward to seeing her in full shot with her full suit of furled sails. B.E.
- 431 replies
- pegasus
- victory models
Always a pleasure to see an update Augie, I just love your build. B.E.
- 2,191 replies
- confederacy
- Model Shipways
Topsail schooners are such attractive vessels, and you have captured the lines beautifully in your build Peter, lovely work. B.E.
