Blue Ensign
  1. Can't believe that it was 19 August since I last looked in on your build Grant, and now I've missed the completion party. Still it's been a joy to catch up and your boats are a wonder, what great job you have done on them. Love the look of your completed Victory, a great conclusion to a long build. So belated congratulations and well done. B.E.
  2. A long overdue return to view your progress Bob, and what progress you have made. The standard of your work is something to aspire to, you are creating a thing of beauty. Regards, B.E.
  3. Beautiful detailed shots Mike, what a fine model she is. B.E.
  4. Re the guns Alistair, I think you came to the right answer for the wrong reasons. Swans were nominally rated for 14 guns but pierced for 16, the foremost port at the bows was a Bridle port. According to Winfield it was from 1779 that 16 guns became the norm. Pegasus pre-dated this so I fitted only 14. Fly which dated from 1780 had the 16 guns, the extra ones in the aftermost port. I have to admit to making things that can't later be seen, as I fitted out the after quarters and beneath the Foc'sle, but I do have the photo's to prove it Cheers, B.E.
  5. Hi Mike, moving the aft hatch forward to encompass the jeer bitts may have one beneficial side affect - that is leaving more room for the Quarterdeck ladderway to clear the hatch ledges, but in terms of visual impact the modification won't been seen once the pumps and qd are in place. I decided not to fit the Fo'csle bulkhead as I wanted a view of the stove, but others have done it and it's quite a viable modification, down to personal choice I suppose. Like your approach to the deck work. Cheers, B.E.
  6. Like the stand mobbsie, - suits her, adds interest without distracting from the magnificent 'Aggie' B.E.
  7. Sometimes it's good to be away from log for a while, that way the progress made has so much more impact on return. Your progress has been wonderful Nils, very nice work indeed. B.E.
  8. Nice progress Frank, the planking runs look good. B.E.
  9. Nice job on the Cat blocks Michael, and the Foc'sle looks amazing. B.E.
  10. Been a couple of weeks since I last looked in on my favourite builds, and you haven't disappointed me with your progress Nils, puts me to shame as I've hardly moved at all on my build. She truly is an eye catcher. B.E.
  11. Neat work on the Catharpins Ray, is that the approach suggested by the kit instructions? I've always rigged mine insitu and a fiddly job it is getting them seized and taut without distorting the shrouds. B.E.
  12. Has it really been a month since I last visited your log Mark?..... but one advantage is I get the full impact of your progress and the wonderful full framing shots, a pleasure to view. B.E.
  13. It is surprising that a kit is produced without hawse holes, very strange. I don't think the hawse holes should be at the level of the wale, rather slightly above the the gun deck level. The cables run into the gun deck, are secured around the riding bitts and are led below to the cable tier thro' the fore hatch. An alternative is not to rig the cables at all, when at sea the cables we're unrove and the hawse holes were stopped up to reduce water ingress. Ps: the rope covering of the anchor ring is called puddening . B.E.
  14. Brenticus, I think you need to re-visit your anchor cables. They should feed thro' the hawse holes in the bow not over the cathead. It is the Cat tackle with a hook used to connect with the anchor that feeds thro' sheaves in the cathead and is belayed on the Foc'sle. Cheers, B.E.
  15. Belated Birthday wishes to you Bob, nice job on the head so far. B.E.
  16. Glad the ciphers fit the bill Martin, looking forward to seeing the finished product. My approach to fitting the ciphers was to clean the brass, glue the ciphers with ca sparingly, and then blacken. Overspill of ca shows up and where it happened I scraped the excess off with a scalpel blade and re-blackened the gun. Had to do this with one or two of the guns, but they all turned out ok in the end. Cheers, B.E.
  17. If you don't care about period differences and National practices, then it doesn't matter. Only those with a specific interest in the subject are likely to notice - including me B.E.
  18. Hi Martin, Daniel was kind enough to send me a full scale print of the cyphers so I may check them against the actual guns. I have not trimmed them too close so they show up better on the guns for demo purposes. On the left the RB 32mm gun: in the centre Chuck's Syren 29mm gun: and on the right the 15mm RB gun: (used for swivels) The larger cyphers will fit both RB and Syren guns, not too small and in fact a better fit on the Syren model which is a fraction smaller in diameter. The small cypher looks to just fit the 15mm RB gun, although I understand Chuck's model is slightly larger so the fit will be easier. As Alistair says the Amati etched cyphers are indistinct to the point that I found it difficult to decide which way up they should be, but it's all a bit academic because the very small size precludes clear detail and the main benefit is that 'something' can be seen where the cypher should be. Daniel's versions are much clearer and the detail can be made out so I think they should do the job for anyone wanting to enhance their kit guns. B.E.
  19. I also run a smear of pva along the line as serving progresses, helps keep things tight. ps: I love that last run of full model shots even more than the ones before. Nice work Ray. B.E.
  20. The GR monogram I used was part of a set provided with the Vanguard kit, a friend let me have a few he had spare. However, since that time Dafi has produced some etched GR monograms to suit the Heller 1:100 scale kit. The thought struck me that those suitable for a 32 pounder at 1:100 scale may be suitable for a six pounder at 1:64 scale. There are two sizes provided, and I understand the large ones are 3mm x 2mm. These are far superior to the ones I used which were unclear in definition. Have a look, here's the link. http://www.dafinismus.de/plates_en.html Cheers, B.E.
  21. Hi Martin, yes I would have ordered some from Chuck had they been available, and I did so later, sometime after I had completed my guns. As it happens, fine as they are I would have come to the conclusion they were not quite right for Pegasus. Here's a comparison photo. Both the Syren guns are excellent but the 29.9mm looked a little under scale to my eye, mostly in terms of its diameter, and the 37mm one obviously too large. I would suggest you make them up and see how they look as a set on the deck of Fly, such perceptions may then disappear. In reality these guns were quite small, it took me ages to get my head around the fact that the carronades on Pickle were only 2' long. Cheers, B.E.
  22. Hi Martin, I used the 32mm RB Barrels,have I said somewhere that I used the 29mm ones? I also used the 15mm RBs for the Swivels. B.E.
  23. Great job Grant, excellent stuff, a fine pair of Cutters. You've clearly demonstrated that important ship modelling basic of sticking with it until it comes right. B.E.
