clearway
Everything posted by clearway
  1. Thanks Keith and Daniel- been fun with a bit of frustration along the way😁. Keith
  2. Still can't believe it is three years since Keith S prompted me to start my model of Terror which had been in my stash for a year or so, A big thank you goes to Matthew Betts whose building Terror blog enticed me to model her, and Keith S for the many convos especially in the dark days of lockdown one - really appreciated the back and forth Keith. I still can't decide what to do with the 2nd whaleboat so will leave it off (this might change)! Thanks everyone for the input, comments, likes and popping in for a view. Take care all, Keith
  3. the 1.5 mm refers to drilling a hole for the tiller not trimming the end- The rudderpost would indeed have been square at this period. I also drilled more holes in the rudder pintles and gudgeons to add more fasteners using Peco brand blackened model railway track pins which have a smaller head than the occre pins. Keith
  4. Makes a big difference when the closets are added to the deck hake. Regards the way the amati deadeyes are made you could alter the omega loop around the deadeye to fit the 3mm deadeyes- bit of work but not as bad as scratch building them. Keith
  5. the lamp discussion is nearly as involved as the great "ice bridge/ azimuth compass" debate on my Terror log Keith- i think you are on the right path with the lantern hoist/ downhaul. On their FD10 yawl billings have a lantern that runs up to a bracket on the mast doubling with an eyebolt on the base of the lantern for the down haul Keith
  6. The plating would have been fastened over the top of the planking as opposed to rebated. Keith
  7. Brings back memories of a sawdusty kind!- the "bumper does narrow slightly where it rounds towards the bows - coming along and looking more Terror like. Keith
  8. welcome back John- i see your shipyard is rail served too😉. how about gluing strips of wood at 90degrees to the keel with a couple of support pillars like in a dockyard? If using the pillars they would need screwed or pinned as there is a lot of weight causing stresses. Keith
  9. Coming along Hake- I must admit the scratch chainplates i built were a bit of an endurance test as you say there are a few to do- if doing again i would substitute the kits deadeyes for slightly smaller ones. Keith
  10. I am debating at the moment if i should either buy the metal blocks for the steering chains, or attempt to scratchbuild them- as to the wooden drum - still looks better than what occre instructs. Keith
  11. Really moving along now- really makes a difference with the more accurate stearing gear. Keith
  12. well into the twentieth century ships would have electric navigation lamps and emergency oil navigation lamps- hence why you see the boards port and starboard with two lamps each- usually bottom lamp electric and oil lamp above. Keith
  13. gotcha- think my eyes seen the small hole there and added an illuminator🤪 Keith
  14. Progressing nicely Hake- and yes once all the deck furniture is in place the illuminators arn't that obvious- regards the missing one it is on the wooden structure the capstan sits on though it was removed for the steam vent pipe (how i have depicted mine). Straightening dowel ..... not sure it can be done to be honest though i have never tried to be honest. Keith
  15. After a glorious first three days of long easter weekend working in the garden, day four equals rain so back to some more "last jobs" on terror. Using some blackened brass eyes from the kit added the empty davit mounts on the hull -Captain Crozier had the iron stanchions fitted at the waist removed but i very much doubt they would have removed the mountings. Still not sure what to do with that last whaleboat🤔 Also Crozier had the barge sent back, so should we have the larger ships boat there?!- also means you would be down to 8 boats as opposed to 9. Take care all Keith
  16. Coming along nicely- i wouldn't bother filling any gaps in the first layer though as when adding the 2nd layer the glue will help fill/ seal them. Keith
  17. 😵‍💫looks like a load of greek to me 😁, but seriously that would be one hell of a device to show off! Keith
  18. Ty Hake- i hope Keith S, Daniel and myself havn't scared you too much with all the altered details! Keith
  19. Thanks Hake- i did realise some things too late for example the lamp room and W.C. and the open deck under the anchor deck (forecastle). If memory serves me right i think yours was the first completed Endurance on MSW. Keith
  20. Hope it all works out in the end- this goes to re-estabilish why i never went down the rabbit hole of scale model rope making😉 Keith
  21. Thanks for looking in and the likes- not much happening with Endurance at the moment, but i have finished the altered engine room skylight. Take care everyone. Keith
  22. Thanks for the comments, likes and looking in- what a glorious weekend regards weather (been wave after wave of rain, mist, frost, snow and more rain through March)! Spent a little time amid gardening jobs in the shipyard with the stovepipe for captain croziers stove in place and one of the whaleboats stored on the skids portside (still not sure what to do with other whaleboat yet)....... i think the end of the build is in sight😜 on my Endurance log i posted a pic of a pair of black 5 steam locos simmering in below zero temps and will repeat it here- shows what it must have been like when they were using the steam engine on Terror! take care all Keith
  23. Pack plenty of waterproof clothing Tom! Cumbria is on the south western border of Scotland -the old county of Cumberland which was altered in the 1974 county boundary change forms a large part of Cumbria which was the first part of Scotland to be annexed by Henry 1 for England in the 1100s (no town, parish or hamlet from Cumberland appears in the doomsday book). Keith
